Question about Lexmark X75 All-In-One InkJet Printer
Printer pulls in paper crooked everytime, pulls to right.
Have had 5 years...worked great till today. Have to now feed 1 page at a time.
  • 241 Answers
Your feed issue could be caused by a change of paper type (too heavy) or the rollers are worn on the printer and needing either cleaning or replaced.
Posted on Jun 04, 2010
Testimonial: "Thanks..I'll try that"
I C309 printer not pulling paper correctly every time and crumple
HEY YO! THIS IS A CAR(YOU KNOW AUTOMOBILE)FORUM,NOT COMPUTERS FOR DUMMIES!!!!!!DUH!!!!
Dec 18, 2009 | 1996 Chevrolet Cavalier
My CX9400Fax printer has a paper jam every time it tries to print. As the paper starts to feed into the printer, the bottom left pulls in and the paper is then feed in crooked causing a paper jam every...
hi
hey i had the same prob til about 5 minutes ago ,, i kept pulling and playing with the jammed paper under the lid where you change the ink,, and finally on the left side ,,a blue piece of soft plastic material came out ,,now it works great ,,i have no idea where it came from but maybe it will help you lets hope
Dec 13, 2009 | Epson Stylus CX9400 Photo Printer
My Epson CX5800F is pulling the paper into the printer crooked
I had the same exact problem. Get a piece of fine grit sand paper run it though face up a coupe of times. It works!!! My printer now is great. A friend told me this because a printer repair person told her.
Jun 12, 2009 | Epson Stylus CX5800F All-In-One InkJet...
Paper ALWAYS feed crooked.
Defective rollers or you have something stuck in a corner...look carefully or try cleaning the rollers with robbing alchool (remouves grease)
Feb 27, 2009 | Dell 924 All-in-One InkJet Printer
"My Mom's 'Lexmark X75' Printer Does Not Load Paper to Printer".
Please follow these steps it may help you , ....Good luck..
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck
Feb 27, 2009 | Lexmark X75 All-In-One InkJet Printer
Paper Jams
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Nov 27, 2008 | HP Photosmart 2610xi All-In-One InkJet...
Lemark printer
Nov 09, 2008 | Lexmark X2500 All-In-One Printer
Paper feeds through crooked and comes out crunched
Make sure the blue slide device on the left side of the paper holder is tight against the paper. If not, the paper will feed corrked.
May 29, 2008 | Epson Stylus Color 740 InkJet Printer
Paper Jam on
most printers are pretty cheap now so replacement is always an option....on the other hand, I will spend countless hours trying to figure out what is wrong first. Remove all paper first, open printer and check for pieces of torn paper or debris, if you have a can of air you can blow out the insides to clean. Put 3 or 4 sheets of paper in, print a test page and watch carefully how paper advances...is it straight or crooked when being loaded? Is printer trying to pull more than 1 sheet at a time? Good luck
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Lexmark X75 All-In-One InkJet Printer Logo
209 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
