Question about Bosch Nexxt 500 Plus Dryer
Keeps beeping with error message either E12 or Cln
The lint filter is clean and if I restart it starts back up but when gets to the very dry stage - It beeps again with one of these 2 messages - It was just installed yesterday to replace an old dryer. I have dried a couple of loads but there is obviously something wrong since I have to keep restarting it.
    Novelist:
  • 160 Answers
Most dryers have safety features that detect air flow blockage. Check to see if the vent hose is clogged. Considering u just installed it yesterday it sound like the vent hose is clogged. Clear the hose al the way to outside. Sometimes it can be clogged on the exhaust vent on the outside of your house.
Posted on Jun 03, 2010
Ultrasense dryer sending lint filter red light, E01 message and it is beeping after starting to dry.
Try unplugging for a _full_ 24 hours. If problem still exists, bad computer board.
(I feel like I should copy this answer to a notepad and paste it every time I see these questions. This is why I avoid computerized appliances like the plague. Owning such appliances is _truly_ worth having extended warranties).
May 18, 2015 | Dryers
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Hoover washer dryer Error Code E12 during dry programme. How can I fix?
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
Nov 03, 2012 | Washing Machines
Bosch vision 300 gas dryer shows error E12 evry few min. Checked and cleaned lint. Checked exhaust vent. Still E12 every 10-15 min. The dryer is only 6 months old.
A friend of ours has a bosch gas dryer and she had the similar problem. She called the Bosch repairman and he came out to her house and sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Jan 17, 2011 | Bosch Dryers
My dryer keeps saying Lint Filter Problems and cutting off however the lint filter is clean. Because of this issue I the dryer will not stay on long enough to actually dry the clothes. It continuously...
try two things. first, run it empty without the lint filter installed. if it gives you the same error message, install the filter, but disconnect the flexible duct connected to the back of the dryer. try it again. if it still wont work, you will have to get it serviced and cleaned out. if it works with the ducting removed from the back, your dryer duct is clogged up. check your yellow pages for dryer duct cleaning. The lint filter error message is just your machines way of saying it is not getting enough air flow. It can be caused by a clogged duct also.
Nov 20, 2010 | Siemens Dryers
E 01 display and beeping
Hi
Check for the following if you get "E01" error message 1. Check for the vent hose whether it is clean which is less than two feet (to outside). 2. Check for the temperature sensor probes one in back at heating element and one in front by the lint filter for the temperatur rises resistance increases on both of them and visa versa. 3. Check whether the unit has been grounded. 4. Check for the element that turns off and on during drying process. 5. When first starting and dryer is cool it will dry one load of clothes, it also seems to work for at least the first part of the cycle, until clothes began to get dry then it over heats. display shows E01 and will not run until it has set for about an hour.
Thank you!
May 09, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer stops drying and lint error message...
try cleaning the vent line. if you have a flex vent line make sure it isn't kinked in any spot. make sure the outlet outside does not have a birds nest or anything blocking it
Nov 10, 2007 | Siemens WT79020EU Electric Dryer
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Bosch Nexxt 500 Plus Dryer Logo
1,464 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
