Ram problem i have installed memory card in expansion slot of my pc and upgraded main memory ram as well with 2 one gig cards but laptop only recoggnises total ram as 1 gig not 2 gig
  • 655 Answers
Kamel,
First of all you should know howmuch maxim RAM your board will support and which type of DIMM's it accepts. You can see on your motherboard manufacturer's site.
  1. Try each on in all slots one by one to verify all slots are well. if not try to clean and check again.
  2. If its ok then put both together and check out, if not then try to change the place and clean the contact point as well.
Thanks
Iqbal
Posted on Apr 09, 2008
HOW dO I aDD memory?
It really depends on what you have now. Go to crucial's site http://uk.crucial.com/gbr/en/ and use the scan computer tool and it will tell you how, if you can and the parts if possible.
Frankly this is the safest and surest way of doing this.
Sep 13, 2014 | Dell OptiPlex GX520 PC Desktop
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Can i upgrade this laptop with a video card?
The video card is part of the motherboard and there no expansion slots for video cards in a laptop. The only improvement that may be available is to change the video RAM if the BIOS configuration allows it. The video RAM uses part of the main memory (shared RAM) and you may be able to increase the size of the video RAM, but this will reduce the main RAM by the corresponding amount.
Oct 01, 2010 | Toshiba Satellite L505-S5966 Notebook
I have abrand new Dell XPS 8100 with upgraded memory to 8mb and an ATI 5770 graphics card. When I start the computer I get 6 beeps and the PC does not start. Fitted a replacement Graphics card, still the...
Depending on the main board, 6 beeps usually signify's either a RAM issue (like a bad connection or incompatible ram) or an expansion slot issue so check any other cards you may have installed and make sure that The new RAM stick is compatible with the main board.. The main board model code is printed on the main board. Use it to search for audible fault codes, or go to www.upgrading and repairing computers.com and search for the beep codes for the main board on this site. Also, try reseating all the RAM sticks and expansion cards, especially graphics card..make sure you have not dislodged any data connectors and double check everything..
Feb 05, 2010 | Dell XPS 200 PC Desktop
Can I install new video in my laptop?!!! My compaq presario CQ60 209 tu has integreted video card GMA 4500M. how is it possible? Someone on this site told me to replace my video card!!!
Video cards on laptops are on the motherboard, therefore it is not possible to change the video card, also there are not expansion slots for inserting a graphics card.
The video card usually uses shared memory ie. uses part of the main memory. It is possible to upgrade with more main memory and increase the available video RAM in the BIOS configuration.
Oct 06, 2009 | Compaq Computers & Internet
I need a list of compatible video cards that can be installed to upgrade the computer to make it run smoother and assist with games, I also need to know what processors can be installed in it ato upgr
I hope you realize the manufacturer recommends a maximum of 1GB of RAM in this system.
Since the system only has PCI slots, any kind of PCI video card should work without a problem.
May 31, 2009 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Want to upgrade memory
maximum memory is1GB for your motherboard, you can only install 2 x 512MB, sorry.
Refer to this page: Hp site
Alex
Mar 26, 2009 | Computers & Internet
RAM Upgrade
I think Acer notebooks will only accept in most cases two of the same , size, i removed my memory sticks and bought two x 1GB sticks instead and it's fine
Sep 10, 2008 | Acer Aspire 5315 Notebook
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Install 2 RAM modules of 1 GB
The other memory may be soldered in. Check your manual and see if it has any information on additional memory. If you only have on expansion slot you may have to buy larger memory chips. like instead of 2 chips 1 gig each you may have to purchase a 2 gig chip. Computer companies usually make the chip installation easy to get to on lap tops.
Jan 14, 2008 | HP Compaq nx6310 Notebook
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
