Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
MFD2560HEW Bottom freezer french doors. Top shelf in fridge is 52.2 degrees 2nd shelf is 45.7 degrees 3rd shelf is 38.5 degrees and the bottom shelf that slides out that sits above the freezer is freezing everything and is 19.6 degrees--the freezer is freezing even at the lowest setting what's going on?
  • Maytag Master
  • 4,655 Answers
At this point I am not sure if your Auto Damper that regulates the cold air is stuck closed or if the thermistor that controls the damper is responsible. You could also be having a defrost problem restricting the air flow to the fresh food section. Look into rear of freezer to see if there is a layer of frost building on rear panel. If yes then we will need to focus in a different direction. First by manually unplugging fridge and then using a hair dryer to help speed things up. The manual also has diagnostics test that you can do to locate a problem area like thermistors or many other errors will show once placed into diagnostics. Sea Breeze
Posted on Jun 03, 2010
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
Maytag MFD2560HEW refrigerator. Refrigeration section not cooling... Freezer appears to be fine.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 15, 2011 | Maytag MFD2560HES Bottom Freezer French...
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice build up in freezer and temp in fridge section not very cold
just needs to be defrosted ice is blocking the vent for the bottom defrost it and should be good
Aug 28, 2009 | Samsung RF265AA Bottom Freezer French Door...
Everything in my frig is frozen
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .. I don't know what he was doing with the putty unless he was stopping up the vent which won't work because you have to have the air circulation for the fridge section to work. The fridge temp control may be the problem.
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Refridgerator (Bottom Frzr-French Door) not getting cold....Freezer is o.k.
could be a few issues, id open teh freezerdoor at looka t back panel id tere frost building up??? if so youhave a defrost issue, can you here the fan in freezer conmpartment spinning you may have a bad evap fan
Mar 16, 2008 | KitchenAid KBFA20ER Bottom Freezer French...
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
547 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
