Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have replaced the main board , have replaced heater, and termonsted is still frostest up and does not cool off... after defrosting and replacing the part it works good for 3 to 5 days
  • 248 Answers
Replace thermistor on eveaporator. It's tube shaped, white with 2 white wires. it's held onto top of eveaporator with silver clip. You have to cut the wires and wire nut new one in. Evaporator is the set of coils that you mounted defrost heater to.
Also check defroster hi-limit on top of evaporator. It's the round silver unit. Try the thermistor first. Should be pretty cheap. The thermistor tells the board when the evaporator is warm enough. When it goes it won't defrost.
Posted on Jun 03, 2010
Fixya manuals
It doesn't defrost
  1. Defrost control board
If the defrost function is not working on your refrigerator it could be an issue with the defrost control board. This control board oversees several internal conditions and regulates the activation of the defrost cycle. A faulty board can be the primary reason your refrigeration unit is not transitioning to the defrost cycle. Over time, the buildup of ice on the evaporator coil will prevent the refrigerator and freezer from maintaining proper internal temperature. It is advisable to first check the defrost heater and the defrost thermostat for continuity prior to replacing the defrost control board.
  1. Main control board
A possible cause for a refrigerator not defrosting, especially on more modern units, is the main control board. The main control board acts as a "brain" for the unit controlling the defrost cycle, compressor, and run time, and essentially acts in place of the defrost timer. The control board can be tested using an ohm meter for functionality and will need to be replaced if bad.
  1. Defrost timer
If the refrigerator is not defrosting the timer could be malfunctioning. Numerous times throughout the day the defrost timer should cycle the defrost heater on as a means to melt frost buildup on the evaporator coils in the freezer. If this timer does not cycle on, then it may be faulty and require replacement.
  1. Defrost heater assembly
If your refrigerator is not defrosting accurately this could be an indication that your defrost heater assembly has failed. This could cause the frost to accrue on the evaporator coils, eventually blocking the airflow resulting in the unit not cooling properly. The defrost heater assembly can be monitored for continuity using an ohm meter and will need to replaced if there is none present.
  1. Defrost thermostat
Another cause of your refrigerator not defrosting is a faulty defrost thermostat. A requirement for the defrost heater to activate to melt away frost on the evaporator coils is a functional defrost thermostat. The defrost thermostat senses the temperature of the evaporator coils and initiates the thawing process by activating the defrost heater. If the thermostat is faulty, it will not sense the lowering temperature of the coils and will not turn on the heater, resulting in an advanced frost build-up. The defrost thermostat can be checked for continuity by using an ohm meter; if there is no continuity the damaged part will need to be replaced.
  1. Defrost sensor with fuse
Another possible cause of a refrigerator that does not defrost properly is a defrost sensor with a fuse. If the defrost sensor fails, the fuse acts as a one-time-only fail safe for the sensor -- if the sensor does not shut off the defrost heater, the fuse will blow when the set temperature is reached. This safety precaution is to keep excessive harm from your unit by the heater and is a one-time use, resulting in the replacement of the entire defrost sensor.
Defrost drain problems
  1. Clogged or freezing defrost drain
If you are experiencing defrost drain issues, it is possibly due to a clogged or freezing drain that is blocking water flow to the bottom of the freezer. This will cause the defrost water to drain and drip down to the bottom of the freezer section. To correct this issue, thaw any ice or remove debris that could be causing the clogged drain or replace the drain heater.
  1. Drain heater
If you are experiencing defrost drain problems, inspect the defrost drain heater. A dislocated or burnt out drain heater will result in the drain tube freezing over. Attempt to return the part to the designated position or replace the damaged part to correct the issue. Search Over 2 1 Million Appliance Parts
Sep 06, 2014 | GE Monogram ZIRS36NM 36'' Stainless All...
Freezer is not defrosting properly , I already change the thermostat, my refigerator model is TBX74UL01 OR TBX74UB01.
If the thermostat is replaced, but still its not defrosting, then two possibilities, either weak defrost heater,Heater is the part which heats and it defrosts, if the heater gets weak, then unit will not defrost properly.And it will take more time to defrost, and till that time, again frost gets collected.---------- But if defrost heater is ok, then problem is defrost board.The defrost board is the part, which controls both thermostat and defrost heater.-----------
This problem is called defrost problem.-------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. IN YOUR case, defrost thermostat is already got replaced, so ignore thermostat, but other two possibilities needs to be checked.----------You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 19, 2011 | GE Refrigerators
Refrigerator side is not cooling properly
Its defrost problem.
The defrost is not working,.The evaporator coil in the inner section of freezer is got blocked by ice .
Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced. -------
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.--------- This should help.Thanks.Helpmech.
May 29, 2011 | Kenmore Refrigerators
Freezer works refrigerator is warm
If the freezer is getting cold and working properly, but fridge section is not getting cold, then it can be defrost issue.------------------ The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.--------- Try manual defrost reset procedure: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.This should help.Thanks.Helpmech.
Apr 28, 2011 | Amana Easy Reach 20.5 cu. ft. Bottom...
Refridgerator part of Miele fridge / freezer is not getting cold at all. Freezer part is workng fine with no issues. Have tried to reset but with no luck. Would like to know what the problem may be if...
It can be defrost issue.
Apr 27, 2011 | Miele Refrigerators
Lack of cooling in the lower section
It can be defrost issue.Try manual defrost reset procedure: ----
Apr 27, 2011 | Refrigerators
THe fridge on our fridge freezer isnt working
If the freezer is getting cold and working properly, but freezer is not the it can be defrost issue.------------------ The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.--------- Try manual defrost reset procedure: ----
I have a model gss25lgmb bb. Im having issues with (couple of months) my fridge randomly stop cooling. Causing everything to defrost. My fan still seems to be on but not cooling or freezing. PLEASE HELP
If its not cooling or freezing then the compressor has to be checked.The compressor is the part which controls the cooling and freezing in the refrigerator.If the gas / refrigerant in the compressor gets low/ less then compressor will run more but it will not cool due to less refrigerant in compressor.In that case the compressor needs to be replaced. -------------- Also it can be faulty defrost assembly parts causing this issue.The thermostat is got faulty or the heater is not turning off.This also causes every thing to get defrosted.
The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.------------
Before that you can try manual defrost reset procedure. The manual defrost reset procedure is as follows : ----First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again.Then go for replacing the parts.-------------------This should help.Thanks.Helpmech.
Apr 06, 2011 | GE GSS25LGM Side by Side Refrigerator
Top section not cooling on GE Side by Side
IF the evaporator is frozen then the defrost is not occuring. Probably the heater or the defrost thermostat.
Sep 10, 2009 | GE GSH22JFT Side by Side Refrigerator
GE DSS25 PFMDWW REFRIGERATER NOT COOLING
You have a defrost problem, which means the problem will continue to reoccur until you fix the bad part of the defrost system. Being that it's a GE, my first guess would be the heater, but you need to check to be sure.
Pull the interior panel of the freezer back off and check the defrost heater and defrost thermostat for continuity. The thermostat needs to be cold when you test it, so leave a good amount of ice around it. If both of those test good, then the main control board (which controls almost everything on that unit) is bad.
When you find out the problem, replace the bad part and defrost the system manually again with a hair dryer.
Here are some photos to help you identify the parts to check, just in case you're not familiar with them. The control board is located on the exterior back of the unit, behind a small panel.
Click here to see the main control board
Click here to see the defrost heater
Click here to see the defrost thermostat
Mar 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
104 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
