Question about Kenmore Elite HE4 Electric Dryer
Kenmore washing machine not empyting all the way during the rinse cycle? the machine washes fine but not empyting all the water during the rinse cycle?
    Novelist:
  • 160 Answers
Does it go into high speed spin? If it does and there is still water than check to see if the filter or hoses are clogged. The hoses the run from your basket to the pump and the drain hose too. A washer is only given so much time to drain all the water. Most of the time the filter or coin trap hose is clogged. If everything is clear u may have a weak pump.
Posted on Jun 03, 2010
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
When my machine goes through the rinse cycle it will only fill with hot water. It fills with warm water during the wash cycle.
Your hoses are reversed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Washing Machines
Water won't shut off during wash/rinse cycles & overflows
the clear tube going from the tub to the pressure switch probably came undone or has a hole in it
Apr 24, 2009 | Washing Machines
Agitator doesn't turn during wash / rinse cycle
top the top off the agitator,remove cap inside,you have 4 plastic dog ears you need to replace,your local appliance store has them for $2,let me know how you do-mike
Mar 24, 2009 | Kenmore Washing Machines
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Just a trickle of water during rinse cycle
HI thanks for your question. the cold water valve either has a clogged screen or a faulty water valve. remove the cold water hose and clean out the screen, try again. could be all you have to do. if its acting the same. replace the water valve. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Kenmore 24902 Top Load Washer
Kenmore Elite HE4 Electric Dryer Logo
108 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
