I have added expansion memory into my compac nc8230 and also changed main memory with 2 one gig memroy rams but the laptop only recognises it as one gig not 2 gig?
    Guru:
  • 1,342 Answers
Make sure they are both seated properly. Are there any beeps when the computer starts up?
Posted on Apr 09, 2008
Gateway desktop fx 7026 memory issue, has 4 slots came with( 2 )2 gb sticks = 4 gigs it came with. when i add 2 extra gig it doesnt recognize.
the specs i read says 8 gig is the max. here is what it says for RAM
RAM
  • Installed Size 4.0 GB / 8.0 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667.0 MHz
  • Form Factor DIMM 240-pin
  • Features Dual channel memory architecture
  • Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Feb 12, 2011 | Gateway FX7026 PC Desktop
Adding 2 gigs memory
try to install windows xP!! when the screen turns blue!! just press f7 until the setup is finnish!!
Jul 12, 2009 | Jetway 939GT4-SLI-G Motherboard
I have 1 gig ram added 2gig of ram to my P5VDC-MX mother board.
Your system might only be able to recognise 2gb of RAM. Tiger Direct has a RAM finder for almost every computer. Check it out to see if you have too much.
Jul 02, 2009 | ASUS P5VDC-MX Motherboard
Inspiron 2200 Memory Module not recognised
Are you sure its the correct speed/type of RAM? According to Google your laptop takes PC2700 DDR RAM, ensure you are using this in both slots to avoid problems. If you have it fully inserted into the slot and nothing happens when you swtich it on then the laptop doesnt like that type of RAM and you'll need to change it.
May 17, 2009 | Dell Inspiron 2200 Notebook
Model No AL-096 Sahara memory daul channel
2 slots does NOT mean Dual Channel, that just allows for 2 RAM chips
Apr 18, 2009 | Dell Dimension 8300 PC Desktop
Added new ram stick now monitor does not recognise pc tower
According to this page (a memory vendor which I'm using only for illustrative purposes) your machine only supports up to 1gb sticks of the 400mhz variety. So you would use 4 x 1gb for a total of 4gb max.
Feb 21, 2009 | E-Machines T6528 PC Desktop
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
Ram problem
Kamel,
First of all you should know howmuch maxim RAM your board will support and which type of DIMM's it accepts. You can see on your motherboard manufacturer's site.
  1. Try each on in all slots one by one to verify all slots are well. if not try to clean and check again.
  2. If its ok then put both together and check out, if not then try to change the place and clean the contact point as well.
Thanks
Iqbal
Apr 09, 2008 | Computers & Internet
Memory
if it is windos xp then it wont recognise
Feb 08, 2008 | Computers & Internet
Install 2 RAM modules of 1 GB
The other memory may be soldered in. Check your manual and see if it has any information on additional memory. If you only have on expansion slot you may have to buy larger memory chips. like instead of 2 chips 1 gig each you may have to purchase a 2 gig chip. Computer companies usually make the chip installation easy to get to on lap tops.
Jan 14, 2008 | HP Compaq nx6310 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
