Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Battery will not charge
Have an L120 and the battery will not stay charged. Is it the regulator and is that the part with 2 wires mounted to the engine on the left side. Checked the wiring harness and all sems well.
Thanks
5 Suggested Answers
SOURCE: JD mower-only one coil firing
I just switched the coils around. The other cylinder went dead, so I knew I had a bad coil. Replaced the coil and mower runs great.
Posted on May 15, 2009
  • 4 Answers
SOURCE: 4020 w/ 24v system sparks when the battery is connected
I usually fix electrical problems by process of elimination. Disconnect the wires attached to generator and touch the battery cable to the battery if it still arcs disconnect the regulator. continue until you find whats pulling current from the battery.
Posted on Jun 05, 2009
SOURCE: I have a john deere L120 riding mower with about
have a john deere zero turn that will not turn all the way over
Posted on Aug 16, 2009
  • 5370 Answers
SOURCE: jd 318 tractor won't start
yes it matters.Take note of which color was on which tab.If you connect new solenoid, like how the old solenoid wires were connected.Then only it will work.Otherwise it will not work.--- Locate the positive wire that connects the solenoid with the starter. It will be virtually the only wire that runs from the solenoid to the starter post. One wire goes to battery the negative wire and other goes to ignition switch. ----------------
The red wire from the circuit breaker goes to terminal "B" of the ignition switch. On your tractor there should also be a light green wire in this terminal. Terminal "S1" should have the single purple wire that goes to the coil of the solenoid, Terminal "S2" should get the purple wire and the purple/black wire. ------------
This will help.Thanks.Helpmech.
Posted on May 11, 2011
Why my battery not charging
Have battery tested could have a bad cell. Check voltage regulator if battery tests ok
Jun 25, 2014 | 2003 Suzuki VL 1500 Intruder LC
Why dose my battery drain when motor bike is running
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test:
The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test:
Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
Stator ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity your stator is shorted to ground and must be replaced.
5. Regulator Test:
Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test:
This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Battery keeps draining HELP
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Jun 23, 2014 | 1996 Honda VT 1100 C2 Shadow Sabre
2001 Honda VT 1100 C2 Shadow Sabre not charging
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
5. Regulator Test:
Identifying Wires:
VT1100 Charging Problem
Apr 11, 2014 | 2001 Honda VT 1100 C2 Shadow Sabre
2002 Honda Shadow VT 750 won't stay charged, new battery
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
5. Stator Ground Check:
6. Regulator Test:
Identifying Wires:
Battery won stay charged
Honda 1998 VT750C Service Manual
Honda VT750C Owner Manual
Aug 28, 2013 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
2005 Honda VT 1100 C Shadow Spirit the battery keeps going dead
Hi, Joan before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
6. Regulator Test:
Identifying Wires:
Aug 31, 2012 | 2005 Honda VT 1100 C Shadow Spirit
95 suzuki ls 650 - just got it on the road after it has been standing a long time in a garage. it was running fine for a week and then suddenly shorted (?) during parking it. brought it to my mechanic, who...
Hi, Sabine you either have a faulty battery a serious drain on your battery or your charging system has gone south, before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test: The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test: Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Check Connections/Wires: Inspect the regulator/stator plug, and check the battery terminals for connection/corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Start motorcycle and change Voltmeter to AC volts.
Generic Specs:
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on system, check service manual for specification
Generic Specs:
Stator IB test or Ground Check:
If there is continuity to ground your stator is shorted to ground.
5. Regulator Test: Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Fwd/Reverse Bias Test/Diode Test: This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Star battery wont stay charged
http://www.sloneservices.com/SilverBack/Other-Stuff/VS-1100-chagre-syst.pdf
Suzuki LS650 Savage Service Repair Maintenance
OEM parts for Suzuki
http://www.savageriders.com/verslagen/transfer/2002_LS650P_Owners_Manual.pdf
Apr 26, 2017 | 1995 Suzuki LS 650 Savage
2005 Hyosung GT 650 R not charging
Hi, Gruntman before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced AGM types more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
5. Regulator Test:
Identifying Wires:
Hyosung Gt650R battery not staying charged
HYOSUNG GT 650 Service Manual
HYOSUNG GT650 PARTS CATALOGUE Parts Catalog
HYOSUNG GT650 Owner Manual
May 19, 2017 | 2005 Hyosung GT 650 R
New batteries and alt. still no charge.
Generator with Integral Rear Mount Voltage Regulator, Internal Fan Type With the key in the RUN position, voltage is applied through the charge indicator lamp I circuit to the voltage regulator. This turns the voltage regulator on, allowing current to flow from the battery sense A circuit to the generator field coil. When the engine (6007) is started, the generator (GEN) (10346) begins to generate alternating (AC) current which is converted to direct (DC) current by the rectifier internal to the generator. This current is then supplied to the vehicle's electrical system through the battery positive voltage (B+) terminal located on the rear of the generator. Once the generator begins generating current, a voltage signal is taken from the stator and fed back to the voltage regulator S circuit, turning off the charge indicator/lamp. With the system functioning normally, the generator output current is determined by the voltage at the A circuit. This voltage is compared to a set voltage internal to the voltage regulator, and the voltage regulator controls the generator field current to maintain proper generator output. The set voltage will vary with temperature and is typically higher in the winter than in the summer, allowing for better battery recharge. With the system functioning normally, the generator output current is determined by the voltage of the A circuit (battery sense voltage). The A circuit voltage is compared to a set voltage internal to the voltage regulator, which controls the generator field current to maintain proper output. The set voltage will vary with temperature and is typically higher in the winter than in the summer, allowing for better battery recharge in the winter and reducing the chance of overcharging the battery in the summer. A fuse link is included in the charging system wiring on all vehicles. The fuse link is used to prevent damage to the wiring harness and generator if the wiring harness should become grounded, or if a booster battery with the wrong polarity is connected to the charging system. Mitsubishi 215-Ampere Generator
The Mitsubishi 215-ampere generator is an internally regulated, brushless unit that is self-current limiting and temperature compensating. The regulator is integral with the generator and the fan is external.
VISUAL INSPECTION CHART Mechanical Electrical
  • Before attempting to test a battery, it is important to give it a thorough examination to determine if it has been damaged.
  • Batteries are tested to determine the state of charge and ability to crank an engine. The result of these tests is to show that the battery is either good, needs recharging, or must be replaced.
  • Preliminary checks to the charging system should be made regardless of the fault condition. These checks include:
    • Check the fuses/fuse links to the generator to ensure that they are not burned or damaged. This condition, resulting in an open circuit or high resistance, can cause erratic or intermittent charging system concerns.
    • Check battery posts and cable terminals for clean and tight connections. Clean the posts and the cables to ensure good electrical contact.
    • Check for secure connections at the generator output, voltage regulator and engine ground. Also check the connection at the power distribution point.
    • Check the generator drive belt to ensure proper tension and no slip between the generator pulley and the drive belt. Refer to Section 03-05 in the Powertrain, Drivetrain Manual.
    • Check battery for full charge.
  • Before performing charging system tests on the vehicle, note conditions such as: slow cranking, discharged battery, charge indicator lamp stays on with engine running, charge indicator lamp does not illuminate with ignition switch in RUN and engine not running, etc. This information will aid in isolating the part of the system causing the symptom.
  • When a relatively new battery is discharged, test for current drain. The following are some of the most common current drain concerns:
    • Glove compartment lamp stays on with the door closed.
    • Engine compartment lamp stays on constantly.
    • License plate lamp or interior lamp stays on constantly.
    • Other electronic component concerns.
Aug 14, 2009 | 2005 Ford F 350 Super Duty
Battery keeps loosing charge- kymco cruiser 125, 2005
I had this exact same problem on a hipster 125, it was a faulty regulator module ( mounted under the seat) I also found a short circuit (somewhere) in the wiring loom between the regulator output and the chassis (probably what killed the regulator in the first place!) I cut and replaced the entire wire to save removing most of the loom and after testing reg to ensure it was dead i fitted a new one (about £60) bike charges and runs like a dream now even with fully lights approx 80% of the time. good luck
Jul 14, 2009 | 2005 Kymco Hipster 125
Want hold a charge
get a test light and a schematic. unplug stator plug.start bike ,make sure battery has full charge. test each pin on connector that is attatched to the 3 yellow wires.should light on each pin. if all good check for burn marks around connectors, front & back sides, and on wires. if no power on yellow wires, stator problem. if power, plug connector together, now test for voltage in wires on the voltage regulator side of the connector, to see if the voltage is making it through the connector.if there is power to volt. regulator,test w/ multi meter across battery leads to see if there is charging voltage to battery,approximately 13-15 volts. if only battery voltage(12.2 or less) while bike is running,voltage regulator is no good.if charging good, but bike wont start after prolonged sitting(say overnight) a system amp draw test is needed to see if something is staying powered up while bike is not running, drawing down battery.
Feb 18, 2009 | 1994 Suzuki RF 900 R
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
172 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
