Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
My frig wont cool down
It is building up ice on the coil in the freezer but the frig wont get cold eather
  • Frigidaire Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratormy frig wont cool down - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 04, 2010
Refrigerator and freezer not coming up to temperature. replaced start device on compressor what else could be the issue
Some of these brand friges have a tendency to not defrost the freezer side properly. Ice builds up behind the freezer panel thus reducing air flow to the frig side. Having replaced all parts repeatedly on my WP frig, actually two of them, and losing food repeatedly, a WP repair guy said it was unrepairable. WP is crap. Their design is crap. Many side by sides are littered with cooling problems. The defroster coil, defrost sensor, and thermostat just dont work properly. In the end, I bought a diff. brand and will never buy wp again. Keep in mind how many brands are sister brands to wp and avoid them too.
Oct 12, 2014 | Whirlpool Refrigerators
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
We have a 1999 Whirlpool side by side refrigerator and Freezer. Model number ED25EQXFW02. Last night the Refrigerator and Freezer stopped cooling and freezing. After taking everything out of the freezer,...
Usually when the freezer is still giving cold but the frig is not receiving cold you have an ice build-up on the cold (evaporator) coil that is hidden behind the rear panel of the freezer compartment. If you push on this panel, you usually will hear a cruntch sound (this tells you there is ice/frost on the coil). There are 3 components that affect this problem: defrost timer, defrost stat, defrost heat coil. In other words, something is not working to remove the frost from the coil and it is building-up day after day (takes about 5-7 days to become full (blocked). When this happens, no air can move over the coil to take the cold away and blow it throughout the frig or freezer compartments.
To access the defrost coil or stat, you have to ren move the back panel (in the freezer) and remove all the ice with a hair dryer only or let the door open all day and allow it to melt. DO NOT PUSH OR PRY OR CHOP WITH ANY TOOL OR YOU WILL BE GARRANTEED TO PUNCTURE A HOLE IN THE COIL AND YOU ARE REALLY SCREWED. The time is either: under the front of the whole refrigerator, or in the frig compartment (towards the back or attached to the ceiling of frig compartment). If you have some experience with electrical parts, you can test to see which part is at fault. Good Luck. Macgivor
Oct 11, 2009 | Whirlpool Refrigerators
Frig too warm, freezer too cold
if there is ice build up you have a defrost problem. either the heater bimetal thermostat timer or evap fan could be bad. you could also have a stopped up drain. if the coils get too much ice build up the air wont beable to travel through them and the bad air flow will cause the fridge to become warmer
Sep 16, 2009 | Frigidaire FRT8S6EMB Top Freezer...
Part 2 for build up of ice on coil inside frig
Does your locale have high humidity? If it does, there is no true way of stopping the build-up of frost (and ice). Unfortunately, water vapor condenses below the dew point (temperature at which vapor turn to liquid). This happens at higher temperatures in very high humidity environments. It is not as noticeable in the winter months when humidity is low, but the summer months are another story. Just like when you see water vapor on the outside of a glass of ice tea in the summer; you don't notice it as much in the winter months.
Jul 29, 2009 | GE Refrigerators
Frig not getting cold
See if the coils are blocked with ice. Fridge gets cold air from freezer, ice would prevent this thus a warm fridge.
May 10, 2009 | Refrigerators
Frig warm, Freezer Cold
I have experienced this with other refrigerator freezers. The most likely cause is that the warming element in your automatic defrost system is no longer working. Ice is building up on the cooling coils and this prevents the refrigerator from getting cold. I have always called an appliance repairman to fix (~$150). If you're handy you can try yourself, but you still have to buy the part at retail. Good Luck
May 03, 2009 | Refrigerators
Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Mar 23, 2009 | Avanti FF1101W Top Freezer Refrigerator
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
161 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
