Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Center panel between doors in hot to the touch
We have vacummed out the bottom part of frigerator for dust build up. Checked water line to make sure it is circulating, but it is still hot to the touch. Any ideas what problem might be?
    President:
  • 949 Answers
This is due to the condenser over heating, if you have cleaned the coils then the most likely suspect is the fan that keeps those coils cool. See this link for more information on this.
Hot rail
Posted on Jun 03, 2010
Water/ice in the bottom of freezer
Matt, you have a frozen condensate drain tube. Now, the easiest way to solve this is to thaw the drain line. Remove everything from the freezer, drawers too. Now you can either leave the unit unplugged over night or hurry up the drain thaw by using a hair dryer ( heat gun is too hot ) and aiming it at the center of the back panel in the freezer, center, bottom just at the bottom of the metal back panel. This is going to take some time, 2+ hours until it is totally thawed. To check, using a baster, squeeze some hot water into the drain trough under and behind the pack panel, it should drain out, if not, add more heat and time. Once this drain tube is completely thawed and flowing, order and install the following drain tube kit.
Drain Pipe W10619951
This will solve this common problem on Whirlpool/Maytag bottom freezer refrigerators.
Apr 21, 2014 | Maytag MFT2771WEM
Our 8 year old refrigerator has recently begun making a continuous tapping sound. The sounds stops when you open the bottom freezer door.
the compresor fan is might make that sound or the fan in your freezer is tuching something like build up ice... see if you can reach it and clean it.
Jan 01, 2010 | Refrigerators
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Ihave a Galaxy side by side and the center metal strip where the two doors meet and the magnets connect is very hot to the touch, any suggestions?
It's has to be warm to keep out the moisture, but not very hot .It will help if you clean (or blow out) the dust out of the coil in the back of the fridge (you'll see it at the bottom when you pull out the cardboard cover.Always disconnect the fridge before do any work.
Aug 06, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice build up on freezer floor.
Hi, If ice is building in the freezer, you have a defrost drain hole plugged. Unplug the Fridge and then remove the rear panel off the freezer. There you will find ice built up in rain. Remove the ice (hair dryer works best). Once the ice is gone, you need to make sure the drain hole is open all the way. A baisting serringe with hot water works really well.
I hope this helps. Please let me know if I can assist you further. Please rate my answer so I know how I am doing.
Thanks
Vic
May 22, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator runs hot.
replacement is probably not necesarry. a good cleaning is usually the problem if you pull it out and vacume all the parts under it and in front make sure the condensor and coils etc. are not built up with dust. this is usually the problem.
Jan 23, 2009 | Kenmore 53642 / 53644 Side by Side...
Outside of refrigerator is hot - almost burning hot
The frame between the doors has a refrigerant line running through it to prevent moisture build up between doors (should be room temp. or slightly warm, not hot).
If that area between the doors is hot to the touch, you have two things to check: 1 - are the condenser coils under unit or in the back clean? 2 - is the condenser fan running in the back that is near the compressor running?
Aug 24, 2008 | KitchenAid KSCS25IN Side by Side...
Frigidaire side by side refridge
pull the kick plate off under the doors. if you look in behind the kick plate youll see alot of dust build up. this area needs to be cleaned once a year to keep air flowing properly over the condenser coils. if the dust build up is minimal then remove back panel of refrigerator and make sure the fan is running behind the refrigerator. if not, or if running real slow replace the fan motor. the heat is the because the condenser is getting too hot. it needs to be fix or the compressor life will be greatly shortend
Nov 20, 2007 | Refrigerators
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Maytag side by side fridge.
My Maytag side by side is 7 years old. Bar between fridge and freezer just began getting very, very hot also? What can we do to repair? Does the condenser fan motor need to be replaced?
Oct 23, 2007 | Maytag MSD2656G Side by Side Refrigerator
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
257 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
