Question about Hitachi 50UX57B 50" Rear Projection Television
Hitachi projection tv seems to be stuck in surge protection? red light on front blinks then nothing. took back off and three green lights go on then off then red light flashes any ideas?
  • 1 more comment
  • survivor1 Jun 09, 2010
    Jun 09, 2010 - Hi have tried all these things, will try again to make sure. even took extension cord plug in different room and tried all these things.have friend at work that is former tv repair last worked in 90s, said to give him information were to look for specific set hitachi 60ux58b,please help thanks pat b I removed the back cover, plugged it in and all green LED's came on with a red one as well. The red light gets bright and then the power goes off. Red LED stays on and blinks
  • survivor1 Aug 26, 2010
    hitachi projection tv seems to be stuck in surge protection? red light on front blinks then nothing. took back off and three green lights go on then off then red light flashes any ideas? also have two other hitachi projection tvs all doing same thing, can there be a voltage problem in electrical in home?
  • 11,896 Answers
Sounds like the all to familiar power board problem. It is common for these power boards to go bad. Check to see if there are any swollen capacitors or resistors and any burn marks on the board. You can use a voltmeter to test the power from the board. You can use an analog meter to test and capacitors or resistors on the board. If there happens to be a relay, you can suspect that as a possible cause as well and you can test it with an ohmmeter.
Posted on Jun 09, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please try to reset the Projection TV by turning it off for 5 minutes. After 5 minutes unplug the TV power cord from the electrical outlet and let the television remain without power for more then 1 minute. Plug the power cord back into the electrical outlet. If the television is plugged into a power surge protector, remove it from there and plug it directly into the wall outlet. Turn on the television. If the issue is resolved, then the problem is with the power surge protector and not the TV. If the issue is not resolved then this might have happened due to over-voltage. Please check the power supply unit for swollen/bulged capacitors and burnt wires/components on the power supply board. You should try and turn off the TV for 8-10 hours to reset it. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in off condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
    Hi, Thanks for reply have did all these things before posting, wil try again to make sure,even have taken extension cord from different room, let off for more then 8 hours, have friend at work previous tv repair in 90s needed some instruction on this set but has experience in tv repair. tell me what else to look for so that I may pass on on him thanks Pat B
    Hi have tried all these things, will try again to make sure. even took extension cord plug in different room and tried all these things.have friend at work that is former tv repair last worked in 90s, said to give him information were to look for specific set hitachi 60ux58b,please help thanks pat b I removed the back cover, plugged it in and all green LED's came on with a red one as well. The red light gets bright and then the power goes off. Red LED stays on and blinks. Board says Protection. Any help??
HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
May 21, 2012 | Hitachi Televison & Video
Problems with Hitachi 57F500 57 in. Rear Projection HDTV-Ready I went away for 8 days and had unplugged the power surge from the wall. When I got home I plugged it back in and everything connected to the...
one of the fans is not starting up causing the error check youself or have a tech check it out for you common thing when the set has been unpluged and really cools down
Dec 03, 2009 | Hitachi 57F500 57" Rear Projection...
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
Hitachi 61UDX10B
I would check for burnt resistors as the 150s are interchangeable with the 110s however in alot of hitachis I have seen resistors blow after upgradeing to the higher wattage ICs. I Usually switch out the convergence resistors whenever I go to a higher wattage IC just to be sure. If you need more help let me know.
May 18, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 60fx32b is dead with no lights on front panel
The two other fuses look like resisters. My suggestion would be to check them first and if bad use a temp of the same rating to see if it was just a power surge.
Apr 14, 2008 | Hitachi 60FX32B 60" Rear Projection...
Shuts down after power up 50ux53k bought new 1998
Refer to owners manual will tell you what blinking light means. But at the front not at the back.
Dec 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50UX57B 50" Rear Projection Television Logo
82 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
