Both batteries expired -i replaced both batteries; one at a time;turn it on screen says DATA ERROR
  • gene71299 Apr 09, 2008
    the old batteries are dead-dont understand why you would say to reinstall them
    and reinstall what firmware??
    are you even familiar with the casio 5500b; it came complete, there was nothing to install
  • gene71299 Apr 10, 2008
    found a small hole on left lower left edge
    tried several times the message doesnt go away
  • 19,396 Answers
You need to reinstall the firmware, which model is your PDA?
Posted on Apr 09, 2008
  • 1 more comment
  • Ginko
    Ginko Apr 09, 2008
    try first putting back your old batteries and see if it starts with no message. There may be a problem with new battery. If you cannot get rid of a message then is a software problem, and you will need to reinstall it. The most likely is that the system had been damged when the battery went off.
    To troubleshoot it further we will need your PDA make and model.
    Regards
  • Ginko
    Ginko Apr 09, 2008
    Apart that I could not know in any way that it was a casio 5500b, as you did not post the model (thanks for letting me know). Your device has firmware (and also a basic OS) installed like any system based device. Your casio has a copy of OS and firmare stored in ROM. To restore it to original settings you need to follow the reset procedure below:
    All-Reset procedure
    Turn power off.
    Press reset button, this is a pin hole buttona t the back of your casio use a pencil or a thin pointed object.
    At this point you should get displayed "are you using the unit for the first time?"
    Press N, if you say Y it will delete all your data and restore factory settings.
    You will get set time, and then home screen
    If the above did not work you will need to repeat the procedure answereing yes at first question, but this will delete all data in your diary.
    Here is Casio support page, in case you need a repair service, but in your case you shouldn't. Do the reset above , if it does not work repeat procedure.
    Regards
  • Ginko
    Ginko Apr 09, 2008
    If you have the manual, the reset procedure should also be illustrated in your manual, check troubleshooting at the end of your manual.
DELL INSPIRON M5030 frusturating issue (tried almost everything)
A) How did the Power Button Module get broken?
B) Error indicates losing data and unable to leave Hibernation Mode.
It's a long shot, but let's see if you can reset BIOS Settings back to default, without being able to see the BIOS Setup screen.....
Remove the AC adapter (Charger)
Remove the Battery.
Remove the RTC Battery. (Real Time Clock. Same as CMOS Battery, but with a new name)
Oh, excuse me.....Dell = Coin-Cell Battery
Power Button Module flat flex cable installed in motherboard connector, press the Power On button, hold it down for a count of 10 seconds. Let go.
Do this same procedure two more times.
Reinstall Coin-Cell Battery
Reassemble laptop.
Reinstall Battery, THEN AC adapter, and THEN plug AC adapter into power.
Let's see if we can revert the BIOS Setup settings, back to the factory default settings.
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-15-m5030_service%20manual_en-us.pdf
C) Dell refuses to help you since your warranty expired.
Not sticking up for Dell, but Really?
You're telling me they're not going to take your laptop, and fix it for a specific amount of money?
"No thank you Mr.Robertson, we're a laptop manufacturer, and money is of no consequence!"
We get by just knowing people out there like our laptops.
That, food stamps and the occasional barbecue Gates puts on at his place, gets us by."
Right.
Did you know I'm Brad Pitt? Angelina is in one of her moods again, so I come on here.
(Just trying to be funny)
D) LED lights 2 & 3 stay on
LED 2 is the Harddrive Activity LED.
Should stay solid as the harddrive isn't active
LED 3 is the Battery Status LED.
Solid amber indicates ON, or Standby.
Did you follow Anti-Static Procedures, during the Power Button Module replacement?
Plus, I'm willing to bet the Power Button Module, didn't come from Dell. Another reason they would not want to work on the laptop.
They can't guarantee the replacement part is good.
(They can, but there are too many liability issues)
Power Button Module being broken, is what I'm concentrating on at the moment.
This was the start of the problem. From it all other problems have issued.
The Power On switch is a Momentary Contact Switch.
The carbon contact Power On switch on that Power Button Module.
http://www.parts-people.com/index.php?action=item&id=9908
Was it broken so it stayed pressed to the on position?
Also need to know the full extent of damage caused by the Power Button Module being broken.
In my estimate it took a pretty hard hit in that area, to break that board.
Lastly for now; The Power Button Module has a FFC.
Flat Flex Cable.
Is it replaced back in the SAME position? Not flipped over?
It will go in either way. Right side up, or flipped over.
Please post back in a Comment.
Regards,
joecoolvette
Mar 13, 2013 | Dell Inspiron 1300 Notebook
My wife is complaining that every time she turns off/on the camera she has to reset the data/time. I understand that when the batteries are changed the settings may be lost, but not simply when the camera...
Sounds to me that there may be another battery inside the camera that is going bad.
Issue: Everytime I power on the camera the Date / Time needs to be set.
Solution: Replacing the Date Battery for the PowerShot A480.
Replacing the Date Battery. If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids can damage the stomach or intestinal walls. 1. Confirm that the camera power is turned off.
2. Open up the battery door / cover and remove the AA Batteries.
3. Remove the date/time battery holder.
4. Grasp the battery and slide it in the direction of the arrow.
a480backupbatt.jpg 5. Insert a new battery with the (+) side facing up.
6. Replace the battery holder and battery cover.
7. When the Date/Time menu appears set the date and time.
note.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your area.
Dec 31, 2010 | Canon PowerShot A480 Digital Camera
My Sharp XE A203 has ceased operation and shows IPL on the screen. Nothing works! Help!
im several time face to this problem. i think this is common error.
turn on machine
then open the printer cover
open the battery cover
remove battery one by one
then machine display NO BATTERY
then put battery again one by one
then machine goes to the mulfunction.
display ***MRS***
turn off machine and turn on it
didnt came to normal condition press CL KEY.
thats over
but ua data is totaly lost you have to put all your data again
May 18, 2010 | Sharp XE-A402 Electronic Cash Register
Error 163 173 ibm 600e laptop when turned on these errors occur
this error is the battery by the sound of things, you need to replace the cmos battery , then enter the configuation utlity and set date and time, hope this helps
Nov 29, 2009 | IBM ThinkPad 600E 2645 Notebook
What is error 00173, 00192, and 00163
Error 192 means a fan error, to test this measure the voltage of the backup battery. If the
voltage is not correct, replace the backup battery. Check the fan and the system board.
Error 163 means the time and date is not set, to set the time and date hit F1 when you see the IBM logo and set the time and date.
Error 173 means the configuration data is lost, to sort that select OK in the error screen and set the time and date.
In most case its the CMOS battery that's run low and need to be changed for a new one, so for the time being you will have to keep setting the time and date and it will boot to windows.
Good luck
Jun 15, 2009 | IBM Thinkpad 600 System Board Motherboard
Certificate of Sercuity has expired
Have you tried resetting the time and date from the system tray? Double click the time on the system tray and change the time and date to what it should be!
Apr 14, 2009 | Microsoft Windows 2000 Server
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Jan 20, 2009 | HP OfficeJet d145 InkJet Printer
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the voltage is not
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Casio BOSS SF-5300
Once the DATA ERROR DISPLAY appears,You will not be able to INPUT or EDIT DATA, though you will be able to recall Data after pressing CLEAR to clear the error message.**YOU WILL
WANT TO SAVE ALL YOUR DATA OR WRITE EVERYTHING DOWN AT THIS POINT, BECAUSE THE ONLY WAY TO GET
THIS DEVICE BACK TO NORMAL OPERATION IS TO PRES RESET IN THE BACK -IF YOU PRESS RESET YOU WILL LOSE ALL INFORMATION PERMANENTLY.
In order to return the memory to normal (allowing further input and editing of data), you must perform the RESET OPERATION to clear the memory of all data-Make sure you have backed up or taken a hardcopy of this information before Resetting or it will be gone and there is nothing you can do to get it back.Once you have RESET you can re-input the data you have written down.
WHAT CAUSES THE ERROR MESSAGE?Interruption of battery power.Severe electrostatic charge,impact,change in temperature
or humidity.Hardware Problem.
Recommendations:Replace batteries every 2 years, regardless of use.Use only CR2032 Lithium batteries.Replace all batteries-Never mix old ones with new ones!
Caution: All data stored is lost if you remove more than 1 battery at a time. The following Info is per the instruction manual-WHICH ALSO SAYS :Be sure you keep a separate copy of all important data that you store in the SF-5100/SF-5300.Hope this helps.
May 28, 2008 | Casio Boss Business Organizer
White screen
Unfortunately this seems to be a problem that happens to all sony ericsson z525a phones before too long. (And it seems sometimes it happens on the anniversary of the expiration of any and all warranties)
I do have some codes for running service tests on the sony z525 but with a blank screen they wont do you much good. anyway..
I'll post them here and let you know that when I tried them on my phone (when the screen worked) they did exactly what they were supposed to. You can test the screen...but only if the screen is working.
Unfortunately none of these codes will work if you have a phone with a blank screen...
THANKS SONY
Nokia anyone?
To check the IMEI# = * # 06 #
Secret Service Menu= > * < < * < * (< is left, and > is right)
To reach last dialed numbers= 0 then #
Info about Simlock= < * * < (use with caution)
again...none of these seemed to fix the problem of the blank screen...but if you should get another z525a you can use these commands to do what they're listed to do....until the screen goes blank....
Now, to retrieve your numbers you would need to follow these key strokes...
center, toggle down (1 time), center, toggle up (2 times), center, toggle down (5 times), center, toggle down (5 times), center (3 times)
then wait for quite some time...it takes a while to copy all of the contacts...I would say anywhere from 5 to 10 mins...
this should work to save your contacts.
To save your pictures (and any other data you might want to retrieve) you could buy Sony's data cable2.gif for the z525a. I haven't tried this but it should work since that is what the cable is for.
Its called a DCU-60 USB data cable, and is listed as being compatible with the z525a.
You could also try getting a T6 Torx bit screwdriver and taking it appart to replace the flex cable that runs to the screen...but I would suggest getting all the data off the phone first.
Jan 03, 2008 | Sony Ericsson Z525a Cellular Phone
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
