Question about GE Americana A4425GDTWW Side by Side Refrigerator
Fridge not getting cold
The coils behind the cover plate inside the freezer are cloged with ice
  • GE Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorfridge not getting cold - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 03, 2010
Fridge is not cold. Freezer working fine, damper door fully functional, but no air blowing through. No ice, but minor frosting on evap coils. Cannot locate defrost timer.
The most common failure is the fan that blows cold air from the evaporator coils into the refrigerator cabinet.
The defrost timer is usually on the back lower part of most older fridges, or behind the front "kick strip"
May 04, 2016 | Refrigerators
My ice maker does not work
Hi there one of the biggest reasons for not getting cold which will affect the ice maker also is -- low or no air flow.
2 areas - 1) inside the freezer section are vents and they should have some clear areas (our freezer often gets crammed full of stuff)
2) under and behind the fridge is a dust bunny breeding area - pull the fridge out and get as much dust and stuff off the coils as possible (I use a vacuum and a small paint brush). The coils transfer the heat out of the fridge like an air conditioner. Be gentle - coils are somewhat fragile.
Some fridges have a faceplate that pops off at the front.
Sep 19, 2014 | Pragotrade 83-4020-W Weston 18In Frezer...
What does an ice cover coil mean?? help please..
something wrong
extreme ice indicates door seal failure or freezer door being opened too often
Jan 24, 2018 | Magic Chef CTF1826AR Top Freezer...
Side by side refrigerator the refrigerator does not get cold but freeze works fine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Jan 01, 2010 | GE GSS25JFM Side by Side Refrigerator
My GE refrigerator GDS18LBPWW with freezer on bottom does not cool in the refrig. section. Yesterday, I pd $239 to have the Evaporator Fan motor replaced. The freezer is fine and back down to 26, but the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The ideal temp for the freezer is around 10 degrees F.
Look at the evaporator coils behind the rear cover inside the freezer and check the ice forming on the coils.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM
Dec 29, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Panel is hot and freezer does not work!
Check the condenser fan underneath the unit accessable form the back behind the cardboard cover. It should be running when the compressor runs. OR Check the evaporator behind the rear cover inside the freezer. Check for ice build up. . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Sep 09, 2009 | Freezers
Frigidaire frs22zgg Leak in Freezer and on Floor
no you could blow out the tubing that you see behind the fridge iot should uncloged it or fish a wire into it until your wire is free you may have ice buid up you may need to follow the tube where it goes in then see if it is not cloged with ice thanks from gilles
Mar 15, 2009 | Refrigerators
Fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
MW
Nov 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kennmore model 253
Unplug the unit, open the freezer door and look through the vents at the bottom of the back wall. With enough light you should see the alluminum coil through the vents. If there is ice/frost in the vents your coils are frozen up. Remove the cover on the inside back wall of the freezer you may need to remove the ice maker as well if you have one it just plugs into the back wall there is also a plug behind the cover to the back upper left corner. Once the cove is out of the way use a hair dryer to defrost the coils or leave the unit unpluged for a while. After all the ice is gone reinstall the cover and turn the unit on it will probably work for 3-10 days and then the process must be repaeted again. I replaced the defrost thermostat on mine 2 weeks ago and all is good so far. The defrost thermostat is a little round device that snaps onto the small copper line in the upper right corner behind back cover it has 2 blue wires and cost's about $20.
Hope this helps
Oct 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Fridge not cool
the coil is frosted over and no air is being pushed to the fridge it may clear up after a few defrost cycles or remove the food from the freezer and allow it to thaw completely (12hrs) the ice behind the back wall takes a long time to thoroughly melt or you will have soild ice instead of frost and then it will never thaw soild ice.
Sep 29, 2007 | Maytag MFD2560HES Bottom Freezer French...
GE Americana A4425GDTWW Side by Side Refrigerator Logo
205 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
