I can't get my Firelite USBFLB8250 external hard drive to work. The laptop says it doesn't have driver and then can't find it. It says Cypress AT2LPRC58. I've tried several laptops and PC's
  • lwahl410 Jun 05, 2010
    I tried that and it does not show up under disk management. However it does show up under Device Manager, Other Devices and then it shows me Cypress AT2LPRC58. When I open that up it tells me "The drivers for this device are not installed (Code 28)." When I click Update Driver, I then click search automatically for the driver and it says: "Windows could not find driver software for your device. If you know the manufacturer, you can visit its website and check the support section for driver software." That was smartdisk, but is now verbatim. I can't find the driver anywhere at the verbatim siite or anywhere else.
    President:
  • 1,561 Answers
I advice you try this, Turn on your laptop or computer.
Press the "ESC" key repeatedly while the laptop is starting up. The "ESC" key is located on the upper left-hand corner of your laptop keyboard,
View your laptop's BIOS. Use the arrow keys on your laptop keyboard to navigate the menus of the BIOS program. from here you can change the setting of the bios setting. set the hard drive on the laptop or computer as master on the system while you set the attached usb hard drive as slave, with this settings from the bio settings, your system should recognize the usb hard drive.
Take care.
Posted on Jun 05, 2010
    If you're talking about making the "Notebook Hard Drive" as first in the Boot order I did that (there was nothing else in the bios that said anything about making the laptop hard drive a master). However, that didn't change anything. I still doesn't recognize the drive. When I plug it in it makes a sound like it recognizes that something has been plugged, but there's nothing else that shows it being connected. This is a fairly new laptop with Windows 7
    Brigadier General:
  • 3,513 Answers
Guess you have verified that the FireLite has power and the USB connectors are secure both at the Firelite end and the computer end.
If all that is in good order, then you can follow these instructions.
When you plug in your drive you need to do the following to see if the drive is connecting to the computer.
Right Click on "My Computer"
You will get a menu, chose "Manage"
You will then get a Computer Management window.
On the left side of the window will be a menu.
Under the Storage section, chose "Disk Management"
This will open in the right side of the window and will show you your main hard disk, CD-Rom disks and any other disks connected to your computer.
If you see your Firelite hard drive, then it is connected. The drive may need to be formatted. This window should tell you if that is the case. If you see the firelight and it shows that the disk is unformatted, you can right click over the large section on the lower left window which is located to the right of the smaller area that describes the disk. You will get another menu that will allow you to formate the disk. You can also assign or change the drive letter assigned to the Firelight using that same right click menu.
let us know if you want somethin more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jun 03, 2010
  • lwahl410 Jun 03, 2010
    It does not show up under disk management. However it does show up under Device Manager, Other Devices and then it shows me Cypress AT2LPRC58. When I open that up it tells me "The drivers for this device are not installed (Code 28)." When I click Update Driver, I then click search automatically for the driver and it says: "Windows could not find driver software for your device. If you know the manufacturer, you can visit its website and check the support section for driver software." That was smartdisk, but is now verbatim. I can't find the driver anywhere at the verbatim siite or anywhere else.
SmartDisk FireLite XPress 120 GB USB External Hard
Hola!!!
I have this external drive and the truth is that it is very good. But I have a s e doubt that the digital display does not turn me, and I do not know if it is broken or is it because only you connect the USB cable and did not put the current transformer 5Volts. I need someone to help me and tell me what has to be repudiation. Thank you very much!
My Email: @ gmail.com rodolfo.gomez1990
Mar 24, 2010 | SmartDisk FireLite® XPress 120 GB USB 2.0...
USB DRIVE IS NOT DETECTED.
you may have to download a driver for it, but do check that all leads work find and you usb 2.0 and 1.1 connections are working fine too, cheers
Dec 12, 2009 | Verbatim 160GB USB FireLite: The "drive...
My computer is asking for a driver for cypress at2lp rc42.The drive in question is an iomega usb drive. where can i locate this driver
Please follow the below link and download the zip file.
It contains drivers of all the Cyberpress product.
http://www.cypress.com/?rID=14453
It supports AT+ family.
Install the drivers when prompted by your computer.
Cheers
Nov 03, 2009 | Iomega Silver Series 320GB 3.5 External -...
New computer won't recognize my Firelite, works on old computer
You need drivers for USB, if you remember when you bought smartdisk you got the installation disc, that you now need for a new computer.
Oct 31, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Computer not recognizing external HD
1st try a different computers make sure its not your Hard drive!
2nd if that works then go to the hard drive maker and download a software driver for it that should fix the problem
Aug 10, 2009 | SmartDisk FireLite 40 GB Hard Drive
Need drivers
Below is the link for the FireLite 160GB portable HD. Drivers are only needed for win98. 2000/xp/vista are plug and play. The manuals are included at this link.
http://www.verbatim.com/support/support.cfm?part_number=firelite+160gb+usb&x=56&y=11
Additionally, there could be a problem with power supply. A switch is on the back...USB or EXT. EXT is for an external supply. (http://www.verbatim.com/products/detail.cfm?product_id=38819801-1143-3415-5FE3682C49A8E37F&cat_id=3883B708-1143-3415-5FB9F3C74069A098) USB is naturally for a USB cable. Clicking might indicate low power when using USB. Switch to the external adapter or get a USB cable with two connectors for the computer (the extral cable draws more power),
good luck.
Jul 10, 2009 | Verbatim 160GB USB FireLite: The "drive...
I have a mad do multimedia external hard drive and is asking me for a cypressat2lprc42 driver can you help
You can find the info about this in
http://app.cypress.com/portal/server.pt?space=CommunityPage&control=SetCommunity&CommunityID=285&PageID=552&drid=80310&shortlink=&r_folder=&r_title=
For windows drivers go here
http://app.cypress.com/portal/server.pt?space=CommunityPage&control=SetCommunity&CommunityID=285&PageID=552&shortlink=SD1027
For Mac Os 9 driver go here
http://app.cypress.com/portal/server.pt?space=CommunityPage&control=SetCommunity&CommunityID=285&PageID=552&shortlink=RD1032
For Mac Os X driver go here
http://app.cypress.com/portal/server.pt?space=CommunityPage&control=SetCommunity&CommunityID=285&PageID=552&shortlink=RD1033
Jan 18, 2009 | Computers & Internet
Firelite USBFLB 160 won't mount
Problem is just external...First try in another pc,if it still wont work so just buy new external and put that hdd in new external...
Feb 16, 2008 | FireLite (USBFLB80) Hard Drive
Computers & Internet Logo
David Payne
David Payne
