Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
I cannot print or copy . i see error 51
I cannot print or copy . i see and error 51
  • 903 Answers
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Posted on Jun 04, 2010
Brother mfc240c #51 cant print error code.What to do
https://www.easyink.co.nz/support/brother-mfc-665cw-unable-print-51-error-solved/
Sep 14, 2017 | Brother Office Equipment & Supplies
How to clear error 51
Check type of printer it may need cartridge or special paper
roll to print.
Nov 14, 2013 | Brother MFC-640CW All-In-One InkJet...
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
UNABLE TO PRINT DOES NOT RESPOND TO TROUBLE SHOOTING PROVIDED IN USERS GUIDE THIS IS ONLY USED TO COPY AND SCAN & COPY
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 24, 2009 | Brother MFC-5840CN All-In-One InkJet...
Error 51
One or more ink cartridges may be empty. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} See page 143 of the manual for instructions on replacing the print cartridge. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Sep 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Error code
and even if you did get rid of error 51 that you have created, you will find that you still cant print in black, original problem is the print head is stuffed probally from dodgy non gen ink running threw it and the fix is to replace head. I don't know who is telling all you brother mfc owners to clean your print head but your paddling up the wrong creek, these heads are electronic deivices that dont take kindly to cleaning, they are not the same as other brands. Re error 51 goto different machine same engine post
http://www.fixya.com/support/t277162-brother_420
Dec 04, 2007 | Brother MFC-5440CN All-In-One InkJet...
Hp 4p printer related problem
Error 51 (beam detect error) Trouble shooting suggestions: Check seating on laser/scanner assembly Replace scanner assembly
Aug 30, 2007 | HP LaserJet 4p Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
613 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
