Question about Microwave Ovens
Kenmore Elite 721.66463500 Microwave died. Didn't even notice until I went to use it. Changed fuse and screen asked to enter the time of day. Entered the time and hit start. The microwave buzzed for 0.5sec and it blew the new fuse I installed.. put in another fuse and the same thing happened.. what shall I try next?
  • rpjones5 Jun 03, 2010
    Very helpful!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Fuse inside the microwave blows off when there is something wrong with a part inside the microwave. To start with check the door switch as if that is stuck or faulty it will blow the fuse again. Another thing that can cause this is a bad fuse holder as if that is not holding the fuse tight enough the fuse will blow again. If everything else seems to be fine then it is the high voltage capacitor which is located behind the fan underneath the high voltage transformer has gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
  • 4 more comments
    I measured the resistance in the noise filter. Results:
    L1-L2 < 1ohm
    N1-N2 < 1ohm
    L1 or L2 - N1 or N2 = 0ohms
    I'm thinking I need a new filter but I also was unable to measure any resistance on the sensor (Blk to Red, Red to WH, etc..)?
    what shall I try next? I've read the TCO could be to blame but not sure how to test it?
  • Rylee Smith
    Rylee Smith Jun 03, 2010
    If you have already checked the filter then yes it should be replaced however, as I said earlier please check the high voltage capacitor which is located behind the fan underneath the high voltage transformer before replacing anything else. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    using a meter, 9V battery, and jump wires to the H.V. Capacitor and measuring from terminal to terminal I got 0V (when I should get 9V).. I guess I've got a dead H.V. Capacitor. Any other quick way to check it to make sure? Thanks!
  • Rylee Smith
    Yeah...thats what I thought, you have already checked how it should be checked now its time to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    do you think the noise filter is also bad? what are the chances of both being bad?
  • Rylee Smith
    Chances are good, and as you have already tested both of them then it seems replacing both is always better.
Kenmore elite microwave model no. 721.66339011 just stopped heating ...anyone know what or how to fix?
Hello, the fuse normally is located behind the control panel and easily accessed by removing the panel. Here is a schematic to assist you in locating the part...
Dec 17, 2016 | Kenmore Microwave Ovens
After pressing start, light goes on but not operating. Senor issue?
I had a similar problem once with an older Kenmore microwave, which at the time, were actually made by LG. After removing the cabinet, there was a small automotive type fuse in a clip-in fuse holder which proved to be "open" after checking it for continuity with a test meter. I replaced the fuse with the EXACT type and rating, and continued to use the oven for several more years until I gave it away. Please note, that microwave ovens are not something that you want to mess around with. Make absolutely certain that you have unplugged it before doing anything. In my case, I suspect the after several years of trouble-free use, the fuse had failed, -likely due to age. In your case, it may be a similar issue, so you might want to see if your microwave oven has a similar replaceable fuse. Beyond that, I would strongly suggest taking it to an approved service facility. Also, NEVER operate the microwave until you have replaced all covers, cabinet, etc. to it's original state.
Nov 12, 2014 | Kenmore Microwave Ovens
No power, no display power to unit
Blown fuse inside of unit. Must find out why fuse blew, something shorted or bad connections.
Oct 21, 2017 | Jenn-Air JMV9169BAS Convection Microwave...
The display screen has gone blank on my 721.80802400 Kenmore Elite. Of course since it is dial operated, this means we have basically lost all functionality other than adding time in 30sec increments. ...
The main displays are not fused, sorry, Also the display itself is not wired to the baord. It is either soldered on or has a conductive rubber pad under it to bring power to the crystal. Get your model number and either call sears or another parts company for a price and availability on the main circuit board.
Sep 29, 2017 | Kenmore 80809 Microwave Oven
Microwave died. Didn't even notice until I went to use it. Changed fuse and screen asked to enter the time of day. Entered the time and hit start. The microwave buzzed for 0.5sec and it blew the new...
As in your case the fuse keeps on blowing, thereare couple fo things that you will have to do fix it:
The problem your describing is most likely a cap problem. The transformers operate in saturation and therefore it's not likely to blow out the diode. The transformer is essentially energy limiting.
The capacitor or diode may be bad. Discharge the capacitor as described earlier in the article. Test the capacitor by removing the leads and setting the VOM to RX100. Probe the terminals. The reading should start in the low ohms and increase toward infinity. Reverse the probes and re-test. The reading should do the same thing. If not, it's bad. To test the diode, disconnect the diode from both the appliance and the capacitor. With the VOM set to RX100, probe the wires. Then reverse the probes and read again. You should get infinity for one reading and low ohms for the other reading. If not, replace. Another cause could be a faulty magnetron, but due to the sensitivity of that piece, it's best left to a professional.
http://www.doityourself.com/stry/repairmicrowave
You can see the diagram of you model in order to do further repairs by going to the below mentioned link:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1651
Choose you model no. and on the next page on the extreme left you will see the diagram of you model, click on the diagram to see a enlarged image.
Jun 03, 2010 | GE JVM1651 Microwave Oven
Kenmore Elite worked fine for months, then went dead. No screen, no power, nothing. Cord is plugged in, fuse is fine, circuit breaker is fine also. Any ideas?
This will require trouble shooting with power present and a qualified individual should do this. Verify power at the plug and trace to the board. It could be a bad wire, loose connection, open cavity thermostat, or a failed board assuming power is available and the fuse is good.
Eric
Apr 10, 2010 | Kenmore 63792 Microwave Oven
Owners manual for Kenmore Elite Microwave Model 66462
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
d:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgcaab351.jpg
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Jan 18, 2009 | Kenmore 66469 / 66462 / 66464 Microwave...
Connect microvawe vent to exhaust pipe on ceiling
I would call Sears service (and ask for the manager) every day until they send the guy back with the right parts!
If that somehow doesn't work, you can order the parts at the Sears parts site.
You can find out which parts you need in the owner's / installation manual. If you don't have it,
you can just enter your full model number at the Sears parts site.
Sears parts site.
Dec 25, 2008 | Kenmore 63792 Microwave Oven
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Display Screen / Control Panel BLANK
Please provide the correct model # complete. It is located With the door open, mounted to the door jamb near the control panel, or Mounted on the rear of the microwave
Aug 20, 2006 | Kenmore 80809 Microwave Oven
Microwave Ovens Logo
381 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
