Question about Kenmore 54512 / 54514 Side by Side Refrigerator
The ice chute trap door does not snap back. closed too slowly
The chute closed slowly causing ice to jam in the door. shouldn't it snap closed to shut off ice flor? Do I replace whole unit or lubricate in some way?
watugot
  • 290 Answers
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
peyton32034
  • 410 Answers
SOURCE: Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Posted on Dec 11, 2007
22yooper
  • 828 Answers
SOURCE: ice maker frosts over on the chute
This would indicate a problem with the ice chute door seal. Have it serviced. Air leakage would cause the frost-ice buildup.
Posted on Jun 15, 2008
Illeagle
  • 525 Answers
SOURCE: ice maker frost issue
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/0088_4_1.asp#Level1_11
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided.
Any time a door is letting warm air into the freezer, frost will develop. Manually defrost the area with a WARM setting on a hair dryer. DO NOT OVERHEAT! Inspect the ice chute door for proper closure. Possibly a spring may have broken.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
SOURCE: Ice Maker Trap door may be broken
I am having the same problem. My husband took off the front panel and we discovered there is a small piece of plastic holding the ice dispenser door in place that is broken so the door doesn't seal.
I called Sears to see if the part is replaceable -- it's not. I have to buy an entire freezer door for $464 because a .10 cent piece of plastic is broken.
This seems to be a common problem. My refrigerator is only 3 years old. Perhaps we need to make a complaint to Sears/Kenmore together.
Posted on Jul 18, 2008
1Model #795.72042.316
The ice chute door is not closing all the way is the most likely problem and will need to be replaced along with the springs that hold the chute door shut
APPLIANCE 911
Aug 21, 2016 | Refrigerators
How to fix water leak on GE Profile Refrigerator
I would look at the dispenser door for the ice (ice chute) I have seen this door not completely close and cause leaking the you are describing. This door is has a black seal, use a flashlight, from the inside of the freezer door, look for light on the outside of the door. I think you leak is there and replace the solenoid for the door to fix this issue. Good Luck, if you want more help please input a model number. Thanks
Aug 17, 2014 | Refrigerators
Model gd25dfxfw00 Gold side by side; air appears to be leaking around the ice maker ejection door creating a build up of ice inside the freezer at the bottom of the icemaker ejection slot.
I had the same problem, same Whirlpool frig.
There's damper/delay arm/plunger, similar to what you see on doors, that slowly closes the ice door to allow all the ice to escape. This is stuck/broken. You can order the parts on line and replace it. I actually just removed it and the door closes nice and snug again, and no more ice build up in the chute. It occasionally traps ice in the chute, as the door shuts real quick now, before the last cube(s) can come out. I'm use to it now and am quick to open the door without sending more ice out of the maker.
The replacement kit should be : AP3595356
May 21, 2010 | Refrigerators
Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
Aug 14, 2009 | Amana 25.8 cu. ft. Side-by-Side...
ICEMAKER FROSTING UP
Try to take some ice from the dispenser. Remove the glass and open the freezer door to look down inside the dispenser chute and see if the trap door has re-closed. If it remains open warm, humid air will enter the ice bucket and gradually freeze the cubes together. Trap door remaining open is generally caused by a rusted electrical coil which pulls the door open electrically then sticks, unable to re-close. Coil is located behind the panel that operates the dispenser. Relatively easily accessible.
Jul 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice cube flap door
try this site...input your model # and look for the ice door parts. Maybe a bad spring. They are also very helpful with their chat and phone assist., video repair etc. Make sure to get the model # though.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/62-5-1414685-/Whirlpool-Refrigerator-ice-maker-overflowing-WRX735SDBM00?r=%2fShop-For-Parts%2fa4b5c21i2659d1414685%2fModel-WRX735SDBM00-Whirlpool-Refrigerator-Gasket-Seal-Door-Gasket-Parts
Best to you.
Oct 22, 2017 | GE Refrigerators
Whirlpool side by side ice maker freezes up. can't get ice out of
Can you give more details?
If the ice chute is frosting up, chute door is not sealing, air , with moisture, is getting in and freezing. An ice cube getting trapped by the door will cause this also. Either case, replace door and delay mechanism.
May 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Ice dipsencer door flap
You have a Mechanism delay come out. it holds the flaper open and close it slowly. is the end with the arm on it broken you will have to disassemble the dispenser front to get the new one back in... let me know Thanks
Aug 18, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore 54512 / 54514 Side by Side Refrigerator Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
