Question about Canon PIXMA MP780 All-In-One InkJet Printer
PIXMA MP780 "WRONG CARTRIDGE" MESSAGE?
By mistkae I bought 3E MYC installed and have been using them for about a month with no problems. Today the "WRONG CARTRIDGE" message started to flash and sheets feed through but nothing prints. I replaced the 3E MYC with 6MYC (all are OEMs), but it still says "WRONG CARTRIDGE" and does not show full tanks on the display. I have tried all the maintenance options...no luck. Is this a print head thing too? I use new BCI6 cartridges and have had no problems for over a year. I just replaced the "M" cartridge and the message started flashing, along with the "alarm" light. I removed all of the cartridges and replaced them, making sure they were all seated properly. No luck.
  • Canon Master
  • 19,396 Answers
You will need to reset the printer
Posted on Apr 09, 2008
  • Ginko
    Ginko Apr 09, 2008
    Here is the reset procedure from service manual:
    "Service mode operation procedures -
    1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
    the Stop/ Reset button.
    2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
    service mode. (Waiting for menu selection)
    4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
    function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
    orange and green, starting with orange.)
    The number of the Reset
    button pressing
    LED Function Remarks
    0 time Green Power off
    1 time Orange Service pattern print
    2 times Green EEPROM print
    3 times Orange EEPROM reset
    4 times Green Waste ink counter reset See waste ink counter reset
    procedures below.
    5 times Orange Destination setting See Destination setting
    procedures below.
    6 times Green Print head deep cleaning
    11 times Orange Button / LCD checking
    12 or more times Returns to a menu selection"
  • Ginko
    Ginko Apr 09, 2008
    The reason for your problem may also be the following.
    Pixma has an intelligent way of controlling each cartridge.
    Each cartridge has a control chip that can be reset with this device
    If you have an other set of cartridges or an old set of cartridges with some ink, try it out.
    Try also unplugging printer from power, even if I do not think this will be enough to reset.
    Probably you will need to reset the printer from service menu, as above.
I put in a new 3e cartridge and it says wrong cartridge...whats wrong
It could be the printhead has done it's dash. Canon only rate the for a three year service life. Your chances of finding a replacement head are not good.
Sep 20, 2014 | Canon PIXMA MP780 All-In-One InkJet...
My MP780 is displaying wrong cartridge, I tried to use the ok button, and tried to turn the printer off and then back on again and the error message won't clear, I even went so far as to take all the...
I had the same problem on my pixma mp780. I cleaned the printer head. it worked for about a year, but then i had to replace the printer head. after you clean or replace it reboot it.
Dec 28, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Black 3e won't print, even with NEW printhead.
Hello!
Please check the "Rplacing an ink tank" part of the manual. Hope it will help you.
https://manualsbrain.com/en/manuals/1796179/?page=45
Oct 24, 2017 | Canon PIXMA MP780 All-In-One InkJet...
I changed my Canon PIXMA MP780 3e cartridge, and
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 10, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Error: ''Wrong Cartridge'' when no new cartridge has been installed
It is probably one of the cartridges. Usually, when the message "wrong cartridge" appears, the cartridge is faulty.
Apr 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Here is what I did and it now works just fine.I turned off the printer and unplugged the power cord, and unplugged it from my computer. I then removed all the ink cartriges and removed the print Head I got some rubbing alcohol put it on some toilet paper and wiped down the back and bottom of the print head.Plugged everything back in and It now works better then ever.
Feb 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
397 people viewed this question
old marine
old marine
