Question about GE JVM1651 Microwave Oven
Microwave died. Didn't even notice until I went to use it. Changed fuse and screen asked to enter the time of day. Entered the time and hit start. The microwave buzzed for 0.5sec and it blew the new fuse I installed.. put in another fuse and the same thing happened.. what shall I try next?
  • 776 Answers
As in your case the fuse keeps on blowing, thereare couple fo things that you will have to do fix it:
The problem your describing is most likely a cap problem. The transformers operate in saturation and therefore it's not likely to blow out the diode. The transformer is essentially energy limiting.
The capacitor or diode may be bad. Discharge the capacitor as described earlier in the article. Test the capacitor by removing the leads and setting the VOM to RX100. Probe the terminals. The reading should start in the low ohms and increase toward infinity. Reverse the probes and re-test. The reading should do the same thing. If not, it's bad. To test the diode, disconnect the diode from both the appliance and the capacitor. With the VOM set to RX100, probe the wires. Then reverse the probes and read again. You should get infinity for one reading and low ohms for the other reading. If not, replace. Another cause could be a faulty magnetron, but due to the sensitivity of that piece, it's best left to a professional.
http://www.doityourself.com/stry/repairmicrowave
You can see the diagram of you model in order to do further repairs by going to the below mentioned link:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1651
Choose you model no. and on the next page on the extreme left you will see the diagram of you model, click on the diagram to see a enlarged image.
Posted on Jun 03, 2010
No power, no display power to unit
Blown fuse inside of unit. Must find out why fuse blew, something shorted or bad connections.
Oct 21, 2017 | Jenn-Air JMV9169BAS Convection Microwave...
GE JVM1190BY died
The keypad control board may be the problem, or the inverter board if 7 years old or less, cost should be considered.
Apr 29, 2012 | Whirlpool Microwave Ovens
I have a Simply Perfect For The Home brand Microwave Oven that I bought from the U.S. Military post here in Schweinfurt, Germany for $50 I live on the economy in my own apartment. The microwave is a 120...
Just as a NOTE: When I bought my Panasonic microwave from AAFES, before I took it home, they sent it through their maintenance department to adjust the internal voltage. Power for the US is 60 HZ. Power in Europe is 50 HZ. Long Technical Explanation shortened: there's more energy (Heat) in 50 Hz than 60HZ especially when used in anything that uses high power. AAFES adjusted the internal power down to compensate and keep from blowing up the unit. Look for a fuse inside. Replace it, then ask AAFES to reconfigure the product for lower power or 50Hz.
Also as a note, many, dare I say most, clocks from the US count the HZ to count time. So if your US clock, say on your coffeepot timer, looses time overseas; it's probably losing 4 hours a day (do the math: 50 hz/60hz=83.333_%. 83.3_%*24 hr=20 hrs or 4 hours lost). So, if your time is set for 7AM coffee start, when you get that cup of coffee at 7:10AM, set your clock forward to 11:10 AM; or at 7PM, make sure it actually says 9PM. It will loose enough time by the next 7AM to be correct.
Aug 11, 2011 | Microwave Ovens
Went to heat something up hit 30 seconds and microwave just went off..no power..won't turn on..
this is the normal way they die,,they some times go with a bang and some times go with a wimper,,this one went with a wimper,
its most likly to be a fuse blown but why did it blow??? they just dont do that unless there is a fult in them
however the fuses are not normal type fuses and trying to get to them your putting yourself in grate danger,, there is a very big capasitor inside the microwave its a real killer too, holding 1000,s of volts,,,,,,,,, tuch it,,,,,,, and your dead!,,,,,, be warned,,,
Mar 14, 2010 | Sanyo EM-P672W Microwave Oven
Same Problem - Suddenly Died ~2yrs old, very light use.
Probably a fuse inside the unit. Can be caused by overheating or by door switches not working properly.
Sep 10, 2009 | Panasonic NN-P794SF Microwave Oven
Need your insight and troubleshooting on problem w/ our microwave
This could be the breaker at the panel or the fuse inside the microwave.I would check the panel box for any tripped breakers and then the fuse inside the unit.
May 03, 2009 | Sharp R-1502 Microwave Oven
GE DIDN'T bring good things to life
If the fuse blew as soon as you hit START to begin cooking, chances are you have a shorted high voltage capacitor. If it blew a few seconds after hitting START, then it's more likely to be a defective high voltager transformer. You may notice a buring smell. It's also possible that you have a defective thermostat / thermal cutout on the magnetron (especially if the oven has ever been run empty, arced or sparked, or overheated). In cases where the internal fuse blows, there's usually a cause, even if it's just a loose fuse holder. You can find exploded view diagrams and order parts by entering JVM1190SY here: http://tinyurl.com/gv383 We have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 06, 2007 | GE JVM1190SY/WY/AY/BY Microwave Oven
GE JVM1651 Microwave Oven Logo
217 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
