Question about Sony Playstation 3 (PS3) Console
Hard disk corrupted
My ps3 was working fine until i turned it on in the morming. when i turn it on a message comes up on the screen saying the hard disk is corrupted to restore press ok, i pressed ok and and when it had finished it came up with the same message. can you please help me
  • 4 more comments
  • Albertgame Apr 26, 2008
    Get message saying rebuilding dadabase and freezes on 7%. I turned the power over night and same message. HELP!
  • patrick Apr 26, 2008
    Can someone please help i turned on my ps3 and it said disk corrupt after its finished restoring it it come up with the same message can someone PLZ help!!!!!
  • Anonymous Apr 27, 2008
    says needs to restore hard disk files when i do that it just goes right back to the same screen.
  • dandirect5 Apr 28, 2008
    my ps3 was working fine until i turned it on in the morming. when i turn it on a message comes up on the screen saying the hard disk is corrupted to restore press ok, i pressed ok and and when it had finished it came up with the same message. can you please help me?
  • airmax95 Apr 30, 2008
    two days ago i tried to send a friend request and then my ps3 froze, i then tried to turn it off by pressing the ps button and got no response so i just took out the power lead. when i tried to turn it on it came up with a message saying that it would restore hard disk, i press ok the bar that comes up when you download stuff appears but before any progress is made the console just restarts itself. I have no warranty, Im deeply upset as my preordered gta4 arrived yesterday, someone help. please.
  • Anonymous May 21, 2008
    same f''ing problem and Sony won't even help me with out my
    receipt....... two weeks and same problem
Whell hold on to x and d together
Posted on May 03, 2008
Hard disk corruption. says press x to resore but wont load past 18%
Try this:
turn on ps3 press x to restore on 0 % quickly pull out hdd. then wait may take up to an hour a message will come up to formate hdd. put hdd back in and press yes to format this process worked with in seconds for me but can take longer. it does work but you will lose all saved stuff but online stats will still be on the system. good luck hope it works for u to.
________________________________________________________
or this:
New fix (possibly), and it doesn't take a laptop or a friend's PS3 to do.
Simply remove the hard drive from your PS3, and turn on the console. It should display a screen saying the hard drive will need to be reformatted. Then, plug the hard drive back into your PS3, and allow it to reformat. Your save game data will be erased, but you should be able to use your PS3 again.
_________________________________________________________
whoever has a problem withe their ps3 needing to be reformatted just take out your hdd when the restore comes up, then press x, it will take a will before the ps3 tells u to insert a hdd to be formatted (took me 12 minutes)
good luck
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
Jun 03, 2008 | Sony Playstation 3 (PS3) Console
Godfather 2 does not play on my ps3 - freezes at title screen
Try to RESTORE FILE SYSTEM on your ps3.
Follow this guide,
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when it turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 27, 2010 | EA - Electronic Arts The Godfather: The...
Hard disk corrupted
vlynch2819
If you are getting the corrupted drive message on your Playstation 3 this means you have corrupted data on your hard drive. The link below will help you fix the problem with the corrupted data. Note if you still have trouble then you will need to replace the hard drive as there is something wrong with it.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or question
Issken
http://www.fixya.com/users/issken
Nov 01, 2009 | Sony Playstation 3 (PS3) Console
Hard disk's file system is corrupted.
Most likely your hard drive is completely corrupted. It could be as simple as a new Hard Drive replacement or as complicated as a motherboard issue.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 09, 2009 | Sony Playstation 3 (PS3) Console
My PS3's hard disk file system is corrupted
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
Blank Screen
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-4 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO markusmaritz@yahoo.com I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 and i amafrikaans BUT PLZZZ RATE ME
Dec 19, 2008 | Sony Playstation 3 (PS3) Console
PS3 HARD DISC CORRUPTED
i wonder if u have changed the ps3 hard disk or it's the original toshiba hard disk that comes in the ps3 ??
so if it's a new one u may haven't connected it right
n if it's the original one u can check on it by removing the plastic part at the bottom of the ps3 n try to check on it
Aug 24, 2008 | Sony Playstation 3 (PS3) Console
My ps3 hard drive is corrupted and a screen comes up saying the hard disk is corrupted it can be restored and then restarts and that screen keeps on coming up i want to know how to fix that problem
I see that you are getting the message saying hard disk is corrupted. The cause of the issue might be due to various reasons. to isolate and resolve the issue, I recommend you to perform the steps given in the below link:
http://www.ps3forums.com/archive/index.php/t-41928.html
If your not able to resolve the issue by your self
Please contact SCEA Consumer Services for technical assistance with a PLAYSTATION®3 computer entertainment system.
1-800-345-SONY (7669)
Monday - Saturday 6:00 AM - 8:00 PM PST
Sunday 7:00 - AM 6:30 PM PST
Please get back to me with observations and results because it is important that I resolve your issue in a timely manner. I would like to add that we value your precious time and would be here round the clock to serve you
Sincerely,
Geovanny
Sony Total Care
Mar 11, 2008 | Sony Playstation 3 (PS3) Console
Ps3 hard drive corrupted??
Access the PS3 recovery menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
..I did this and i got my ps3 Back !! :)
be patient and wait for those beeps.. they are important
Dec 27, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
