Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Garage door does not open,from wall switch or remote power is on, light on unit flashes but door does not go up or down
  • 504 Answers
CHECK TO SEE IF IT IS STUCK AGAINST THE BOLT ON THE RAIL.
IF NOT GOTO
http://help.chamberlain.com/help/en-us/InstructionManuals
DOWNLOAD THE FREE OWNERS MANUAL - READ THROUGH THE TROUBLE SHOOTING SECTION.
HOPE THIS HELPS
Posted on Jun 03, 2010
My garage door starts down then goes back and the motor light flashes 10 times. The owner's manual only refers up to 6 flashes.
Richard, what is the make of your GD Opener unit? However, make sure the antena wire on the unit is turned up. 2. sometimes direct sun on the sensors prevent operation from the remote. 3.adjust sensors on both sides making sure the green or red lights are on.4. check the remote battery ensuring red light works when you press the remote button. 5. finally, has on vacation switch on the unit has not been switched on. GL
Dec 01, 2014 | Building Materials
I have the same problem that is listed above with my 1/2 horse power belt drive garage door opener. The lights on the sensors are both green and the alignment works, the overhead light will turn on if the...
Sounds like you have a couple problems. The opener is in the lock mode which is the reason the remotes will not work. Press and hold for 3 seconds the button on the wall control that has the icon of a padlock on it. This will unlock the opener and your remotes will work. If when you try to close the door the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. One of the small lights on the sensor may be flickering ever so slightly. Tweak them a bit and try. If this isn't the case and the main light is not flashing you can try increasing the down force just a tad. This control is on the rear of the motor unit near where all those white wires go. Increase this just a bit and try. If this doesn't work you most likely have a bad RPM sensor board which is a small printed circuit board just in front of the motor. It will cause this problem.
Dec 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a door with two buttons and remote but only
On the wall control with the flashing light press and hold the button with the lock icon for 3 seconds and release.
Jan 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door wont go down.I habe to hold the switch down but if i let it go the door will go up again.
I have a Liftmaster garage door that won't go down unless you press and hold the wall button. The sensor lights are both on. The green light on the unit flashes unless I press the reset button. As soon as you press the wall button it flashes again and the door won't go down unless you hold the button the whole time. The remote wont' make it go down either. It begins to sometimes and retracts, but sometimes the light bulb just flashes (like it is obstructed). I tried replacing the wall switch and that did nothing. Help!
May 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
213 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
