Question about Goodman PHKJ048-1 Air Conditioner
The freeon in my air conditioner has leaked out. i need to know if my air conditioner is under warrenty
    Novelist:
  • 117 Answers
Your going to need the unit serial number and you will need to contact either a local Goodman distributor/dealer, or you will need to contact the installing contractor.
Depending on the age, most Goodman units come with up to a 10year warranty on the coils from defect. But that all depends on the model and age of the unit. Older units were only subject to a 5 year warranty on coils.
Regardless, the warranty after the first year will only cover the cost of the coil itself. You as the homeowner will still be responsible for the removal of the old refrigerant, labor to remove and install new coil, new filter drier, a proper pressure test, evacuation, and recharge of the unit. Its still a pretty penny but hey, at least the coil would be covered.
You will need to get up with a local contractor. Check around. Some contractors will not due warranty work either because of permission reasons, liability reasons, or other reasons that cannot be explained by anyone but that contractor.
Posted on Jun 03, 2010
2001 tarus air conditioner hose
All you need is the line release tool. Watch the video at the link Ford Air Conditioner Quick Connect Disconnect tool in use
Jun 20, 2017 | Cars & Trucks
I put freeon in the system i had for 9 yrs about 2 months ago and the freeon is gone now. its not cooling at all. i realize theres a leak some where. what is a common problem for these systems when it...
I am sorry Sir but it more than likely the Evaporator Coil, sometimes it can be the valve at the outside unit that the gauges are hooked up to. If the cap is left off that valve it may be leaking from there. Look for black streaks of an oil substance
around the outside unit as well, it could be the outside coil.
Either coil would need to be replaced.
Sep 17, 2010 | Ruud Central System Air Conditioner
No cold air coming out of air condition just hot air
Check you ac belt under the hood is not slipping. Check that your ac clutch is engaging.
Check your freeon level.
It is possible you may have a freeon leak. The mechanics will use a dye to determine if you have a leak and where it is. The leak will be repaired and new freeon put in.
Aug 17, 2010 | 1990 Chevrolet K1500
What type of freeon gas does it take
There should be a nomenclature tag on the exterior of the unit by where the electrical enters the unit. It states the refrigerant type .
Nov 08, 2009 | Carrier 38CKC048 Air Conditioner
The compressure kicks on, amd the blower works and it let me put the freeon in it once and thats all it let me know it dont work kno more when i add freeon? and it blows hot air
you need to have a repair shop do a leak check/test since you r losing freon somewhere if you have to keep adding it. Once it all leaks out it allows air to enter and air IS NOT a good thing for a/c systems. They run under an initial 30 inches of vacuum for freon charging.
Jul 26, 2009 | 2004 GMC Yukon
AIR CONDITIONER ON 2002 JEEP LIBERTY IS LEAKING FREEON SOMEWHERE IT WILL COOL FOR FOUR DAYS AFTER CHARGING WITH FREEON AND THEN IT BLOWS HOT AIR. NO LEAK VISABLE WHEN I ADDED FREEON DYE. WHERE COULD THE...
its probley leaking in the evaporator you cannot see it without removing the dash see if anyone that you know has a freon sniffer then lacated the drain tube for the evaporator case most of the time its located on the fire wall on the right lower area with a full charge use the sniffer and see if indicates a leak
Jul 09, 2009 | 2002 Jeep Liberty
Air conditioner blow warm air after freeon
you could have a leak in the ac system which would be why you had to add freon. take it to a repair shop and ask them to check fo rleaks because adding more freon wont fix your issue if there is a leak.
Jun 29, 2009 | 2000 Volkswagen Beetle
After boost air conditioner started blowing hot air
BLOWING HOT AIR YOU MAY HAVE A RESTRICTION ON THE SYSTEM, OR MAYBE A REAL BAD LEAK THAT UR FREEON IS ALL GONE,
May 28, 2009 | 2006 Chevrolet Trailblazer
PINGUINO PAC-L90 PORTABLE AIRCONDITIONER
yes we charge freon if it leaks out, but we fix the leak first. but also it may have electrical problem only, better get it check with a technician
May 09, 2009 | DeLonghi Pinguino PACL90 Portable Air...
AIR CONDITIONER COMES ON BUT DOES NOT BLOW COOL AIR
It is possible that your unit needs refrigerant but Before I would have someone recharge it they would have to locate the point of leak and repair it. I would check to make sure it is not some other problem first, like is the compressor operating.
Jun 15, 2008 | Maytag M6P09S2ACOM Air Conditioner
Heating & Cooling Logo
173 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
