Question about HP Pavilion a1640n (RC663AA) PC Desktop
Bios Help? Motherboard? How to fix?
Hello i have an HP a1640n model desktop. I recently got a message that said "Drive A check,
Floppy drive a: system halt"
I dont know how to get past this?
the computer also beeps fast and constantly.
The keyboard also works, but nothing is lighted up when i get this black screen with the errors. can you help? please
    Scholar:
  • 67 Answers
The most likely cause is your hard drive has stopped being detected for some reason. You would need to go into the CMOS setup utility and check and see if the drive is listed there. Usually there is a shortcut key you push like F1, F2, Del, F12 (it varies from computer to computer). Start trying these keys right after powering on the PC (within one or two seconds). The actual screens also vary from PC to PC, making it difficult to describe further clarification on what these will look like.
If you're comfortable with opening your PC you can check and make sure the power and data cables are securely connected.
Sometimes inexplicably the simple act of blowing all the dust and other crud out of a PC helps with this. If you haven't done that for a while...stranger things have happened.
If all else fails you may have to buy a new hard drive and re-install your OS. Before that I would recommend taking the PC to someone who can look at it in person and really determine the issue.
Posted on Jun 04, 2010
The power light is on, but the monitor is off
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
 - Floppy drive
 - CD drive
 - Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:\> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Or:
Cause:
This is an expected operation. In the Boot Device priority setting in BIOS, you will see Removable Dev. (floppy), Hard Drive, ATAPI CD-ROM, and typically last is Intel® UNDI PXE 2.0. This setting will attempt to boot off a remote agent using the onboard NIC. By seeing this message it means the PC cannot find a boot partition on the floppy disk, hard drive or the CD ROM to load the operating system. Solution:
Install an operating system or put in a bootable device into the floppy or CDROM. If you do not plan to boot to a remote boot host, you may disable the Intel® UNDI PXE 2.0 option from the BIOS setup utility boot order. Relevant Information: No operating system installed
C drive does not have an operating system loaded
No bootable floppy diskette in diskette drive This applies to: Intel® Desktop Board CA810E
Intel® Desktop Board D810E2CA3
Intel® Desktop Board D810E2CB
Intel® Desktop Board D815EEA/D815EPEA
Intel® Desktop Board D815EEA2/D815EPEA2
Intel® Desktop Board D815EFV/D815EPFV
Intel® Desktop Board D820LP
Intel® Desktop Board VC820
End of Interactive Support Announcement
These products are no longer being manufactured by Intel. Additionally, Intel no longer provides interactive support for these products via telephone or e-mail, nor will Intel provide any future software updates to support new operating systems or improve compatibility with third party devices and software products.
THESE DOCUMENTS ARE PROVIDED FOR HISTORICAL REFERENCE PURPOSES ONLY AND ARE SUBJECT TO THE TERMS SET FORTH IN THE "LEGAL INFORMATION" LINK BELOW.For information on currently available Intel products, please see www.compaq.com and/or developer.qompaq.com
Comment by Beni S-P, posted on Oct 26, 2007
And i forgot :
check power suplay and ram???Let me know if u get help???
Oct 30, 2007 | HP Compaq Business nx7010 Notebook
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
How can I fix the "disk read error occurred" problem.
Hello omarnavarro4,
We need some more info on this.
What are the steps you taken beofore this error occured? Make sure you should not have any floppy/CD in your Floppy Drive/CD Drive.
You can go to BIOS and run the HDD Self test to check your HDD status.
Please inform us the model of Laptop/Desktop you using.
With regards
Pankaj
Sep 22, 2010 | HP Mini 1000 Netbook
Dell Dimension E520 problems Hello I have a Dell Dimension E520 PC. It boots up from the Floppy drive instead of the Hard Drive. I have changed the BIOS setting by disabling the floppy and have tried to...
In this case First Need to check in HDD Power is working perfectly or not then check Data calble is perfectly attached or not both side HDD and Mother board then check BIOS Setting and change settign boot piority make first boot from HDD
Mar 17, 2010 | Computers & Internet
When i start windows computer sounds a beep and a information screen opens with system specifications and shows "A: Drive error Press F-4 to rsume" whats the problem with my board please?
This error comes due to the Floppy Drive error..pls check the floppy drive cable connector prperly connected or not ...If there is no floppy drive ..Go into BIOS setup and disable the floppy drive..Then this error wont come again ..
Thank You for using FIXYA!!!!!!!!
Dec 04, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
Turn on and black screen says detecting primamy slave - none and
its could have various reson...
go to the bios and disable floppy drive then restart, if system start without any prob then may be your floppy drive is corrupt...
or check the wire are not loosed in your motherboard and floppy drive
Mar 29, 2009 | Intel Celeron -D 2.26Ghz Computer System...
For 2nd int. hard drive ? SATA or IDE -HP Media Center a1640n
You can contact your vendor. Or at ebay
( http://computers-networking.shop.ebay.ph/Computers-Networking__W0QQ_sacatZ58058 )
copy an dpaste the link your Internet browser address bar
melnavz
Feb 23, 2009 | HP Pavilion a1640n (RC663AA) PC Desktop
I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    Hi pc wont start
    - Floppy drive
    - CD drive
    - Hard drive
    All users
    Or:
    Cause:
    THESE DOCUMENTS ARE PROVIDED FOR HISTORICAL REFERENCE PURPOSES ONLY AND ARE SUBJECT TO THE TERMS SET FORTH IN THE "LEGAL INFORMATION" LINK BELOW.For information on currently available Intel products, please see www.intel.com and/or developer.intel.com
    And i forgot :
    Nov 03, 2007 | HP Compaq Presario V2000 Notebook
    HP Pavilion a1640n (RC663AA) PC Desktop Logo
    162 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
