Question about Garden
I need to see a diagram where the chain oil feeder is on a mcculloch eager ****** chain saw
    Brigadier General:
  • 4,088 Answers
Remove the rear case cover which exposes both tanks, the oil pump and the short coupling line that goes from the pump to the bracket that the bar assembly bolts to. If you remove the bar and chain, that exposes the side port that is coupled to the hole in the bar that distributes the oil to the chain. There is a screw in the case back near the bar that adjusts the oil volume. When the bar/chain is off, clean the side port on the engine, and start the engine. It should ooze out oil when running at moderate speed. Clean the oil passages in the bar end including the two small ports that go out to the chain groove on each side. After everything is back together, run the saw bar tip at speed near a piece of cardboard for several moments--it should throw off a thin line of oil. Hope this helps!
Posted on Jun 05, 2010
Need to know carb mixture
fuel mixture for 2 stroke' s is 20:1
100ml of oil in 5L of fuel
Mar 13, 2015 | Oregon McCulloch 12" Chain Saw Repl. Chain...
Where to find the model number on the eager beaver chain saw
You'll need to contact your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
May 08, 2013 | McCulloch Eager Beaver 2.1 Parts List
McCullough Eager Beaver model#40010205 392 chain saw manual/parts
Contact us
User manuals
McCulloch Service
Nov 19, 2012 | McCulloch 14" Electric Chain Saw Mcc1514
Exploded parts view of mculloch 2014 eager beaver
Refer to your service manual.
Contact us
User manuals
McCulloch Service
Nov 07, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is gas/0il mixture for mcculloch 2.1ci eager ****** model 60013203
Good quaility two stroke oil designed for chainsaws ( not out boards ) and designed to run at 50-1
May 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Mcculloch eager ****** 2318av what fuel mix does it use
chain saws are 40:1
3.2 ounces 2-cycle oil per gallon gasoline
Oct 25, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Where do I find a replacement chain for my McCulloch Eager ****** 2318av chain saw (model # 600038-12)?
Your friendly neighborhood chainsaw shop can fabricate one in about 5 minutes. Take your existing chain for use as pattern.
McCulloch.com
http://www.ordertree.com/modelinfo/MCC/11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318/139.11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318.1.59.1.html
If original 18" bar.
part number(pn) MCC 21927533
Oregon Bar & Chain Selector (again original 18" bar)
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Your saw with 18" bar returns
Oregon pn 91VG060G.
This can be easily crossed to other manufacturers chain. You might consider a more aggressive chain (dependent on your level of expertise). HTH
Lou
Jan 20, 2010 | McCulloch Garden
Mcculloch eager ****** no oil going to chain
The oiler pumps on Macs are the usual suspect, try this:
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Build an IPL number like this:
McCulloch Manual
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
If you can not find parts please repost with the IPL number and I will share my secret Mac parts source.
Lou
Dec 03, 2009 | Drills
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
