I am trying to synch my Clie handheld. A screen keeps coming up saying to check my connections. I have done so several times. Also, I have a 2nd interface connector to which I connect the mini B plug. Neither works. And yet, that interface connector works find for recharging the Clie. Please advise.
  • 6,993 Answers
please I don't get the question, can you please rephrase it?
Bye for now.
Posted on Jun 10, 2010
  • Walesarumi
    Walesarumi Jun 10, 2010
    sorry about my first comment, I read your problem and I can understand now.
    The problem is obviously a software fault. Now we need to know where the problem is coming from, if its from your computer or from the device itself.
    I would advice that you connect the device to another computer, and if the same problem occurs then you will know the the fault is from the device and the other way round.
    So, test the device with another computer first, and let me know what the outcome will be, so that I can direct you further on what to do.
    Bye for now.
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Jan 03, 2016 | Palm TX Handheld
I have not used my clie for a VERY long time. I
The manual is available here on Fixya for your handheld. I'm including a link to the page that discusses the on-screen keyboard, but once there you can flip back and forth through the rest of the manual at need. Hope it helps!
Manual
Oct 01, 2009 | Sony CLIE PEG-SJ22 Handheld
Just fully charged Sony Clie'---backlight is too dim..How to adjust??
You can set your pen drag function to adjust the brightness.
Click the drop down menu on the top right of your screen, then click "system", then "prefs", then click the button at the bottom of the screen that says "pen". Next, click the drop down menu beside the little icon that looks like your clie. Click that and select "brightness". Now, when you drag your stylus from the bottom to the top of the screen, a little slider bar will appear to adjust the brightness.
Sep 14, 2009 | Sony CLIE PEG-UX50 Handheld
How do I CLEAR everything on my Clie
Hard Reset CLIE Sony Series
  1. Connect the CLIE handheld using the AC adapter and take out the stylus pin by twisting the upper part of the stylus.
  2. Push down and hold the power button of the unit and use the stylus to slowly press and release the reset button on the back.
  3. When the Palm screen will appear release the power button.
  4. At the “Erase all data?” prompt, push the upper part of the scroll button on the front of the device to confirm OK. The Sony pda is now reset and you have only to follow the SetUp steps as prompted.
Feb 01, 2009 | Sony CLIE PEG-SJ22 Handheld
Sony Clie PEG-TH55
There are very limited original resources to get parts for obselete products. However you can check ebay.com time to time as frequently many sellers selling Sony Clie Parts.
Oct 02, 2008 | Sony CLIE PEG-TH55 Handheld
Screen Calibration
Check for protective film/screen debris build-up around edges.
Check for loose cabling plugs into the back of the Screen
Unscrew the four little fascia screws & lift panel out.
I had same problem after unable to enter password.
Did Hard reset, encountered the stylus calibration cycling error.
One of my screen cables had come adrift slightly at one corner.
Jul 29, 2008 | Sony CLIE PEG-N760C Handheld
Possible dead battery, but I'd like to be sure
This may sound silly, but make sure you didn't accidently spin the little wheel on the side thus, turning the screen down so low that it can no longer be seen.
I've had several co-workers do this and coming running to me to say they broke it... silly, but common.
Dec 17, 2007 | Sony CLIE PEG-S360 Handheld
Clie PEG-SJ22 does not charge battery
Have you tried resetting the unit? There's a little button on the back that you can press in with a paper clip. That'll cause the unit to reset (you won't lose data) and then you might be good for charging.
Dec 16, 2007 | Sony CLIE PEG-SJ22 Handheld
Help! My Clie Won't Work!
I had that happen last week. Just let it dry out and when the display started jumping, I did a HARD reset. Synced and it's now working like a champ. (Mine had a lot of moisture in it but did not have total emersion in water.) Good luck.
Oct 06, 2007 | Sony CLIE PEG-T665C Handheld
Sony Clie sj33 battery
If you haven't already done so. Try resetting PDA in back, if that doesn't work go back to battery and verify connections are correct and check connection wires (they may be frayed or damaged). I'm not sure that will solve the problem, but it worths a shot.
Sep 19, 2005 | Sony CLIE PEG-SJ33 Handheld
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
