There are two problems which are common with the line cord on appliances. Don't overlook these really simple things when troubleshooting your vacuum cleaner - or fancy electronic equipment! If wiggling the cord has an effect, then the following are likely causes:
Repeated flexing results in the internal conductors breaking either at the plug or appliance end. If flexing the cord/squeezing/pulling results in the device going on and off, it is bad. If the problem is at the plug end, cut off the old plug a couple of inches beyond the problem area and replace just he plug. If the problem is at the appliance end, an entire new cordset is best though you can probably cut out the bad section and solder what remains directly to the mainboard.
In either case, observe the polarity of the cord wires - they will be marked in some way with a ridge or stripe. It is important that the new plug be of the same type (polarized usually) and that the cord is wired the same way.
The prongs do not fit snugly into older worn outlets. This can usually be remedied by using a pointed tool like an awl or utility knife to spread apart the pair of leaves often used to form each prong of the plug. If the prongs are made of solid metal, it may be possible to spread them apart - widen the space between them. Alternatively, get a 3 to 2 prong adapter just to use as an intermediate connector. Spread the leaves of its prongs. However, a new outlet is best.
Bad connections on the mainboard. As you flex the cord, it is also stressing the attachment to the mainboard and affecting some marginal solder joints.
It is important to deal with these symptoms as soon as possible as erratic power cycling can lead to much more serious and expensive problems down the road.
Good luck...
