Question about Lexmark X6100 Flatbed Scanner
Deleting Files from spool after they have printed
Be patient if I don't use terminology correctly. My lexmark x6100 works pretty well with my VISTA HP computer - I downloaded the drivers on-line. The problem is that after I print a document it will not print another unless I turn the printer off and then on again. When I check the printer status after printing a doc it indicates that it is deleting the last printed file but it hangs up with that and never finishes deleting it. The off/on action clears the spool and the next document will print but as soon as that is finished printing the problem begins again. HELP!
  • 655 Answers
See your Spool settings, Set Print directly option and try.
Posted on Apr 09, 2008
I have vista and my x6100 lexmark printer not responding please help. i when on the lexmark website no help
It looks like the X6100 series of printers are supported on Vista starting with model # 6150 through 6190 Pro.
Based on the above information, I would say that the X6100 is not supported on Vista.
Jun 14, 2009 | Lexmark X6100 Flatbed Scanner
Lexmark X8350 can't delete from Print spool
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X4270 All-in-One Multifunction...
Download problem
Are you using the correct drivers for Vista? You can d/l the right ones direct from Lexmark at
Please repost if this helps,
Jul 27, 2008 | Lexmark X6150 All-In-One InkJet Printer
Problems deleting printed files from the spool
Start-> Control Panel -> Printer
Right click on printer icon and select properties
Find out Advance settings. See Spooling, Select Print Directly and try.
Although your driver looks like incompatible but above will fix your problem.
Apr 09, 2008 | Lexmark X6100 Flatbed Scanner
Installation x6100 scanner
Download The drivers from the lexmark website
Mar 24, 2008 | Lexmark X6100 Flatbed Scanner
Installing Lexmark 6100 series all-in-one to new hp computer
There are some compatiblity problems between Vista and your printer. Check this web page to download a driver that may provide limited printing capability for your'll need to use Windows Scanners and Cameras or Photo Gallery for scanning.
Jan 18, 2008 | HP Pavilion Media Center a1330n - AMD...
Hi Iwant to add a printer
Go to and click on Drivers & Downloads then Driver Finder. I did not see the X6100, but I saw the X6150 and X6170, hopefully that's what you have. You need to download the correct driver depending on what operating system you have. In other words, do you have Windows XP or Vista?
Here's a link on the Lexmark site that gives you step-by-step instructions on how to download and install a driver:
Good luck.
Nov 27, 2007 | Lexmark X6100 Flatbed Scanner
Lexmark X1150 only prints first page
I have an x4550, running windows vista basic on an hp dv6000t notebook. i had the same problem. i contacted online lexmark tech and here's the solution that worked for me, thanks to help from lexmark (transcript of chat):
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. It should be set to the default to "LEMF." Change it to "Lexmark." Under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
Nov 19, 2007 | Lexmark X1150 All-In-One InkJet Printer
Deleting - Printed
I've also had this problem with an HP LaserJet 4650dtn printer. I've solved this by: - Stop the "Print Spooler" service. - Delete all the existing print spool files. (Stored in "C:\WINDOWS\system32\spool\PRINTERS" by default). - Start the "Print Spooler" service. - Right-click the printer's icon in the Printers and Faxes folder and choose Properties. - Click the Advanced tab. - Click the Print Processor... button. - Make a note of the existing "Print processor" selection on the left (in case you need to revert it.). Then change it to "WinPrint". Click OK. - Click OK on the printer's properties window. - Try sending a print job to see whether it persists in the print queue.
May 07, 2007 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X6100 Flatbed Scanner Logo
178 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
