Question about KitchenAid Washing Machines
How do you take the top lid off of kitchenaid washing machine model # KAWS777EQUO and replace lid switch?
    Novelist:
  • 160 Answers
There are two clamps under the control console. About 1 inch from the edge on both sides. Use a putty knife and slide under to be able to lift console up and tilt back. UNPLUG washer and you will see 1 gold clamp on each side and use a screw driver and pop them out. You will also see a little white quick connect unplug it and til your entire cabinet forward. You can take the entire cabinet off and access the lid switch. When you put the cabinet back on make sure the sides align and u dont crimp the clear hose where the cabinet indents in. Make sure to reconnect your lid switch and put gold clamps back.
Posted on Jun 03, 2010
I am trying to replace the lid switch on a Kitchenaid Model KAW750JQ4. How do I get the top off to access the switch?
check this link: http://www.repairclinic.com/PartDetail/b121p11/Kitchenaid-Washing-Machine-Repair-Manual/4313896/1170635?ss=a11b121-x6b61773735306a7134&mr=0
Jan 21, 2015 | KitchenAid Washing Machines
Tip
How to fix your washer if it does not drain or spin
kenmore whirlpool,roper,kitchenaid,estate,inglis washer if it will not drain or spin,it's a bad lid switch,remove the 2 head screws,flip the top up,pop the 2 spring clip,unplug the lid switch,pull the cabinet off,remove the 2 screws under the lid,replace switch,put everything back together and your done,most times the model number is under the washer lid-mike
on Jan 31, 2010 | Washing Machines
Agitator won,t work tub will fill, and empty but won't spin and agitator won't work
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Dec 01, 2010 | KitchenAid Washing Machines
Kitchenaid washing machine model: KAWS50JQ4 Basket does not agitate. How do I determine what parts to replace
Does the washer make a noise when it SHOULD be agitating or is it completely silent? If it's completely silent then you should check the lid switch. When closing the lid, when the lid is less than 4 inches from being completely shut, you should head and/or feel a "click" when lowering the lid. If you don't hear or feel a click, your lid switch is broken. If the washer makes a noise when it should be agitating but isn't, then it's likely that your motor coupler is broken. This is part number 285753A and goes between the motor and the transmission. Should cost around $20. If the coupler is out, the machine will not spin either, leaving clothes drained, but still very soggy. If the bottom part of the agitator moves well but the top does not, i.e. "lazy agitator" then you need a part called dogs, part number 80040, in the top of the agitator. Should cost around $3-$5
May 24, 2010 | KitchenAid Washing Machines
Wont spin...
Try the video on replacing the lid switch. It's a different model but disassembly is the same. www.appliancehelponline.com/servicemanual.html this will walk you thru
Apr 07, 2010 | KitchenAid KAWS850L Top Load Washer
Replace lid switch assembly kaws850
The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
On the particular model you have listed, the lid switch should be located under the console near the right rear lid hinge.
You will need to use the steps in the link provided to remove the exterior case to access the switch to see how the actuator and lid hinge interface. You washer is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
This is a very simple repair, but if you have any questions along the way, please let me know. I hope this is helpful to you.
NOTE: If you have not pruchased a new lid switch yet, the part number is 8054980. It can be purchased at appliancepartspros.com for about $18.
Oct 30, 2009 | KitchenAid KAWS850L Top Load Washer
Replace lid switch
You will need to not only remove the control panel, but you will also need to remove the washer casing from the frame in order to acces the switch. It sounds intimidating, but really isn't that difficult to do. The following link explains how to replace a lid switch:
Your washer is manufactured by Whirpool, so these instructions will apply. Most commonly, the lid switch is located under the washer casing along the right hand side of the lid. If the model number you have this listed under is correct, your switch is under the washer casing near the right lid hinge. The mounting screw(s) and ground connector are under the operator console. For clarification, you can refer to pcappliancerepair.com for some excellent exploded view diagrams to assist you. The lid switch is located under the "Top and Cabinet Parts" heading.
If you have any questions about this repair, or need additional assistance, please let me know.
Sep 11, 2009 | KitchenAid KAWS850LE Top Load Washer
KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
May 12, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Washing Machines Logo
55 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
