Question about Kenmore 13672 / 13679 Built-in Dishwasher
Lights on front panel do not work and dishwasher will not start
Door close, light on. dishwasher. do not work.
Posted on Aug 25, 2010
My dishwasher will not work
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Jun 29, 2014 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore Elite Dishwasher will not start
Consider examine inside there is maybe fuse busted on the panel or in the circuit through the control panel of the machine.
Feb 05, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Whirlpool DU1100XTPS9 dishwasher will not start. Lights on panel go on, but unit won't start. Recently, the screws on the inside of the door were all loose so possibly water got inside the front panel, but...
Hi, there. While we cannot assist with repairs I can offer links to our troubleshooting, use and care guides, replacment parts, parts lists, and service line should that be necessary. We hope this helps.
http://bit.ly/zkfnZd
http://bit.ly/112Lu7q
http://bit.ly/LrNZiS
http://bit.ly/yLv4Z5
Oct 18, 2013 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher lights turn on but doesn't start
it will most likely be a door switch issue, to test it you need to remove the front door panel and bridge out the switch, if it works then you need to replace the switch,
Mar 10, 2012 | KitchenAid KUDE40FXPA Builtin Dishwasher
Dishwasher will not start andthe green lights on control panel on front of dishwasher door blinking. I have look for obstructions and the door seems to shut good.
I have had this problem with a different make of dishwasher. The light came on but then it did not work.
It turned out to be the water had been turned off to the dishwasher.
Check your water supply is on!
Sep 01, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Control panel lights but won't start
the front control panel fries out.. We had to have ours replaced after 7 months ... after that was replaced it only lasted 2 months... WE ARE VERY disappointed and will be calling once again tomorrow. The dishwasher is not even a year old yet!
Aug 16, 2009 | Maytag MDC4650AW Built-in Dishwasher
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Start light is blinking
It appears that your door switch is intermittently working. Make sure that the switch clicks on and off when you gently press on the release door lever. It you don't here a distinct click sound then you'll have to go into the door switch and do a little filing on the plastic bar so it does not bind with the depressing of the switch. It is very simple to take apart and put back together.
Aug 31, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Maytag dishwasher MDB5601AWS won't turn on
ok under the bottom kick-plate you will find a tech sheet first id start with where my power comes in under the kick plate second remove the front panel and check the door switches third check the control for a fuse or burned wires resistors etc refer to the tech sheet but it sounds to me like a power problem
Jan 25, 2008 | Dishwashers
Kenmore 13672 / 13679 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
