Question about Maytag M7X05F2B Air Conditioner
How do you clean mold/dirt on the inside of the unit? does the front or back come off?
  • 420 Answers
If the machine is really nasty then the best way is to take them out of the window and remove the outer metal covering which is usually held on by screws. I've stripped them down to wash them out a couple times but its no easy task.
Posted on Jun 03, 2010
How to clean the mold of the rubber
If you have mold on the rubber gasket of your Duet front loader, I can almost assure you that you have lots of mold in other places in the machine. Front loading washing machine are almost hermetically sealed and if the door is left closed, the inside just never dries out. This is just a perfect environment for the growth of mold and other fungi. Once mold gets established in materials such as rubber gaskets, it can be very difficult if not impossible to eradicate because mold grows "roots" deep into the pores of the material, making it very difficult to remove. Eradicating the mold may result in damage to the gasket since my "cure" is to paint on full strength bleach on the moldy surfaces with a brush or sponge (wear gloves). Repeat if necessary. You may wind up having to replace the front door gasket to get all of it. It will probably take more than one application to fully eradicate the mold from the VISIBLE surfaces of the rubber gasket. If you remove the detergent dispenser and peer inside the opening, you may see a lot more mold inside the cavity. If you see mold inside the detergent dispenser cavity, imagine what the rest of the inside of your machine must look like. Do you run a periodic cleaning cycle as advised in the operating manual? Have you read the operating manual? Do you use the absolute minimum amount of HE (non foaming) detergent? Factory instructions for cleaning the door gasket call for mixing 3/4 cup of bleach into 1 gallon of warm water and applying this mixture to the affected gasket area, let stand 5 minutes and wipe the area down with a dry cloth. My experience has shown that this is a grossly inadequate concentration to deal with a deeply seated mold problem in the door gasket. To run the cleaning cycle, the factory calls for 2/3 cup of bleach to be added to the bleach dispenser. "Use of more than 2/3 cup of bleach will cause product damage OVER TIME". Initially, I would definitely consider using a whole lot more bleach than recommended and run two or more consecutive cleaning cycles. Then EVERY USE OF THE MACHINE: wipe the door gasket and all the creases and folds dry with a sponge, remove the detergent dispenser and wipe the cavity dry, leave the drawer out to dry on a clean towel, leave the door open, buy a cheapy plastic box fan and place it inside the machine and let it blow air around the inside of the machine for an hour or so to dry it off quickly, run a cleaning cycle at least once a month. If this sounds too involved or difficult, I would suggest switching to a top loading washer that is much less prone to develop mold growth as air can circulate in these types of machines to a much greater extent than the front loaders.
Sep 12, 2014 | Whirlpool duet Washing Machines
How do I fix leaking dehumidifier?
units that leak some times are a total loss but not allways , sometimes its just not being used on level surface (water seeks level allways) , there are lots of ports inside that need to be kept clean for all the units water to drain out , look inside with a flashlight to see if any buildup is obvious that might be cleaned off ? if not a last effort is to remove cover to see 1st hand what cause is(remove power plug 1st) , rust /mold/dust are all common things to find inside that affect units operation
Jun 29, 2014 | Kenmore 50 pint Dehumidifier w/Electronic...
I am having mold and mildew smells, and when I pull back the rubber ring it is full of slim-like dirt. My clothes are now coming out smelling! How do I clean this, what products should I use??
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | LG WM-2277HW Front Load Washer
The styrofoam inside the unit is covered in black mold. I was wondering what i should do if anything.
Any mold in any part of the unit is not good, especially if its in the Styrofoam, Styrofoam has pores and hides the mold spores well, it would be dangerous to actually run the unit with mold spores as it can travel inside the house. Unfortunately companies that make these units don't make these units mold proof, why should they? that's how they make their money. I have three units, one has always given me problems with mold. It always comes back. The other two are always clean. My best advice, get rid of the unit and get another one or get a free estimate on Central air and heat. Mold is very dangerous and is not worth the risk, it can cause a number of medical issues.
Aug 16, 2011 | Haier HWR08XC7 Air Conditioner
Mold spots on the inside of the rubber seal of the washer... how do i clean remove it/
two ways to remove the mold one you can either get some vinegar and water or bleach and water and sit with a bucket and a spong and scrub away on the mold areas or you can goto your local home depot and look for a product they sell called AFFRESH which is a product that not only cleans a front load washer it also prevents this mold occurance in the future you may need to use more then one tablet in order to clean you unit if you have never used AFFRESH before if you have any further questions message me back Thanks again Rick
Feb 13, 2011 | GE WSXH208A Front Load Washer
Have possible mold in window unit a/c with 10500 BTU. Model # AEW10AMG1. Mfg. 01/09. Can I remove/snap off front vent to clean unit with bleach?
You should be able to clean the mold from the coils with a bleach and water solution without any concern for damage to the unit. However.. there are products designed for this job. If you insist on using bleach I strongly suggest that you remove the unit from the window and perform the cleaning in an area where the bleach solution can drain out of the unit without dripping on and ruining carpeting, etc. inside or killing plants outdoors.
Below is a reply I gave to someone asking about cleaning coils. You might want to do this too, and these cleaners are designed for the task - and will remove the bleach smell at the same time.
Both the evaporator and condenser coils (inside and outside) can be safely cleaned with products specifically made for the job. Clean evaporator and condenser coils mean more efficient cooling - which means lower operating costs. Cleaning the coils can remove stale or other less desirable odors that originate from your air conditioner. An example of such a cleaner is made by Thermwell which is available at Lowes and other hardware and home improvement stores. There are many different manufacturers of the cleaners - so if this particular brand isn't available at the store you shop, another will do. Different brands and types have different application methods - so you should read and follow the directions on the can. Many of the canned foaming / spray type cleaners are "rinse free" - meaning it is not required to rinse the foam off - as running the unit will allow the condensation that forms of the coils to do the rinsing for you. If you remove the unit an clean outdoors - or driveway, etc. then go ahead and gently rinse with a garden hose. Keep the water from the inside electrical and electronic controls. It should be noted that window / thru the wall types and other non-central air conditioning units should be tilted so that the condensation and chemicals drain outside - not into the house. If your AC hasn't been dripping water inside, it should be fine. Usually all that is needed is to remove the front grill and filter to access the coil. With the unit off (preferably unplugged) spray the foaming cleaner into the coil and let it sit to work on the dirt, grime, mold, nicotine, etc. that has collected on the coil. When the last step of the can's printed directions are complete - the job is done. You can find some helpful videos on Youtube to show how the cleaning is done on the larger, central air type units.
Please rate this reply if it was helpful to you - good luck!
Aug 12, 2010 | GE Heating & Cooling
Had camera in damp basement. Mold got between lens
the best thing to do it drop this camara into a shop for them to fully service it you will never get all the mold spors out of it now
Mar 29, 2010 | Bronica ETR-Si Medium Format Camera
Black particles coming out of the room air conditioner
dirt, dust, or mold. could also be the tubing insulation flaking off. either way, open it up and clean it out. the dirt, dust, and flaking insulation can restrict air flow through the coils and cause the ac to not function properly. if it is mold, it's can cause sickness (legionaire's disease). do not use chemicals on the coils. it might be best to replace the ac alltogether. to prevent mold: when installing the ac, make sure the unit is slightly tipped towards the outside. any condensation that collects on the coils will drain out. failure to do so will result in water pooling inside, and this can cause mold.
Jul 30, 2009 | Kenmore 73259 Air Conditioner
Why does our duet whirlpol washer smell like mold. Our washer are
Your washer smells moldy because there is mold growing in it somewhere. To kill the mold and clean the inside of your washer do a hot water wash using no clothes but adding two cups of bleach to the machine. It will also smell better then.
Jul 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Mold inside unit
There is a product on the market that will prevent mold from growing in your air conditioner.You should be able to find it at a refrigeration supply house.Just take the product and place it in the area where the water collects.There is also a product to help you clean your unit of contaminants on the heat exchanger surfaces.It simply sprays on,and can be later rinsed off.Its usually a straight forward matter to remove the cover from an air conditioner.Usually no more than 4 screws.Some units will slide out of their covers,after removing the screws that keep them locked in place,and some covers simply lift off from the rest of the unit once the screws are removed.In either case the rest of the unit minus the cover will remain intact,and can be cleaned.Cleaning the unit will almost always make it work better too,so your killing two birds with one stone.
Jun 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Maytag M7X05F2B Air Conditioner Logo
71 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
