Question about Carrier Cycling
I need 4 Barrecrafters mounting brackets that attach to existing rails on my station wagon. I have cross bars and bike carriers etc, but changed cars. Any ideas? Thanks in advance. Jeff from Colorado
  • 330 Answers
SOURCE: Mounting Th-42PX75U
1/2"
Posted on Jul 10, 2008
fyrebyrd1
  • 121 Answers
SOURCE: Does a left-rear shock absorber
The hole that you refer to would have held the upper strut mount. This piece is part of the strut assembly which includes the coil spring. If you attempt the replacement of this mount yourself, it will require the use of a coil spring compressor (clamshell type which you can rent from certain auto parts stores or tool rental centers). You will have to remove the complete strut assembly from the car. In your case, what's left is the lower retaining bolt. You'll have to use great caution when compressing the spring in order to remove the nut that holds the upper mount in place. The spring is under a great deal of preloaded pressure, that if released can cause bodily damage. Once you remove the upper nut, you can replace the mount, or mounting plate itself. If you don't want to tackle this job yourself. I can tell you that the typical shop will charge you around 2 hrs labor to replace this part. (hourly rates vary) The cost of parts is extra naturally. Most shops I've worked for won't install parts other than those purchased through the shop. You may get lucky though. Buying your own parts is always cheaper, because you don't have to pay for the mark up. I hope this helps.
Posted on Nov 12, 2008
SOURCE: Need instructions for Barrecrafters ski rack
We figured this one out today, after pounding, twisting, sliding, gerunding, etc.
It will not slide backward (as a safety mechanism, of course) unless your latches (the ones that connect / clamp onto the car) are completely loose. That means, that looking at the rack from the end, you'll see this oblong deal that you'll use to tighten the rack to a car. As you turn it clockwise the rack will tighten, right?
Ok. Just make sure that that guy is as loose as he gets, and your piece will slide back just fine.
Posted on Jun 07, 2009
  • 7 Answers
SOURCE: need to get new gear assembly where to get one.bike name slazeng
go to a mountain bike store & there u find them.
Posted on Jun 16, 2009
cursealoud
  • 42 Answers
SOURCE: 1998 chrysler town & country 3.8l- how do i get
you dont have to take it off. remove the 2 15mm bolts and pry the bracket sideways w/ a prybar. This shortens your time. You most likely have a 90amp alternator so it should be small enough to slide through.
Posted on Jul 11, 2009
How do you replace the upper shock absorber tower on a fj62 ?
You will need to grind the rivets out and remove the old mount, you can use one of 3 methods to attach a replacement.
1. Drill out the holes, get captive nuts welded into the chassis rail and use high tensile bolts to attach the mount.
2. Find someone with the correct equipment to re-rivet the mount
3. Weld the mount on, This may or may not be possible depending on the vehicle regulations in your area.
Mar 07, 2012 | Toyota Land Cruiser Cars & Trucks
Am looking at your 4 bike hitch rack. Need to kow if it will hold a woman's style bike? One that does not have the top cross bar.
WE don't see what you're disussing and WE don't market anything. We advise.
To your question: they make adapters for non-standard bike frames like the so-called women's style to provide a 'top tube' for hanging on a bike carrier.
Google "bicycle adapter bar" or look on eBay.
For example... http://cgi.ebay.com/Allen-Tension-Bar-Bicycle-Cross-Bar-Adaptor-BLACK-900B-/220782155858?pt=Cycling_Parts_Accessories&hash=item3367a45852
May 22, 2011 | Cycling
Tourqe specs for 2.8 liter motor.
Camshaft Sprocket: 15-20ftlbs
Camshaft Rear Cover: 6-9ftlbs
Torsional Dampener: 67-85ftlbs
Exhaust Manifold: 15-23ftlbs
Water Pump: 6-9ftlbs
Thermostat Housing: 15-23ftlbs
Intake Manifold: 23ftlbs
Timing Chain Dampener: 14-19ftlbs
Rocker Arm Cover: 6-9ftlbs
Rock Arm Nuts: 15-20ftlbs
Oil Pan: 15-23ftlbs(M8 Bolts) 6-9ftlbs(M6 Bolts)
Main Bearing Caps: 63-83ftlbs
Connecting Rod Main Cap: 34-40ftlbs
Cylinder Heads: 33ftlbs(+ an additional 1/4 Turn)
Engine Mounts: 34ftlbs
Oil Filter Adapter to Engine: 34ftlbs
Oil Filter Adapter Bolt: 63ftlbs
Oil Pressure Switch: 10ftlbs
Oil Pump Drive Bolt: 25ftlbs
Oil Pump Mounting Bolts: 30ftlbs
EGR Valve: 19ftlbs
EGR Tube Nut: 19ftlbs
Fuel Line Nuts: 17ftlbs
Fuel Rail Attaching Bolts: 88in.lbs
Fuel Rail Inlet Fitting: 35ftlbs
Fuel Rail Mounting Bracket: 28in.lbs
Fuel Rail Outlet Fitting: 30ftlbs
Fuel Pressure Connector: 88in.lbs
Fuel Pressure Regulator Bracket: 28in.lbs
Idle Air Control Valve: 30in.lbs
Idle Air/Vacuum Signal Housing: 30in.lbs
Intake Air Plenum Bolts: 16ftlbs
Thorottle Body Attaching Bolts: 18ftlbs
Throttle Position Sensor: 18in.lbs
Crankshaft Sensor: 71in.lbs
DIS Assembly to Block: 15-22ftlbs
Knock Sensor: 14ftlbs
Dec 15, 2010 | 1989 Chevrolet Celebrity
My Front left tire is tilted inward and underneath the truck i found one of the support bars that run's across is broken off on the left side. I looked around the wheel and found that no metal was bent so...
General Description
The front suspension allows each wheel to compensate for changes in the road surface without affecting the opposite wheel. Each wheel independently connects to the frame with a steering knuckle, ball joint assemblies, and upper and lower control arms.
The control arms specifically allow the steering knuckles to move in a three-dimensional arc. Two tie rods connect to steering arms on the knuckles and an intermediate rod. These operate the front wheels.
The two-wheel drive vehicles have coil chassis springs. These springs are mounted between the spring housings on the frame and the lower control arms. Double, direct acting shock absorbers are inside the coil springs. The coil springs attach to the lower control arms and offer ride control.
The upper part of each shock absorber extends through the upper control arm frame bracket. This bracket has two grommets, two grommet retainers, and a nut.
A spring stabilizer shaft controls the side roll of the front suspension. This shaft is mounted in rubber bushings that are held by brackets to the frame side rails. The ends of the stabilizer shaft connect to the lower control arms with link bolts. Rubber grommets isolate these link bolts. Rubber bushings attach the upper control arm to a cross shaft. Frame brackets bolt the cross shaft.
A ball joint assembly is riveted to the outer end of the upper control arm. A rubber spring in the control arm assures that the ball seats properly in the socket. A castellated nut and a cotter pin join the steering knuckle to the upper ball joint.
The inner ends of the lower control arm have pressed-in bushings. The bolts pass through the bushings and join the arm to the frame. The lower ball joint assembly is a press fit in the lower control arm and attaches to the steering knuckle with a castellated nut and a cotter pin.
Ball socket assemblies have rubber grease seals. These seals prevent entry of moisture and dirt and damage to the bearing surfaces.
Four-wheel drive models have a front suspension that consists of the control arms, a stabilizer bar, a shock absorber, and right and left torsion bars. The torsion bars replace the conventional coil springs. The lower control arm attaches to the front end of the torsion bar. The rear end of the torsion bar mounts on an adjustable arm at the crossmember. This arm adjustment controls the vehicle trim height.
Two-wheel drive vehicles have tapered roller sheel bearings. These bearings are adjustible and need lubrication.
Four-wheel drive models and RWD Utilities have sealed front-wheel bearings. These bearings are pre-adjusted and need no lubrication.
Heat treatment may create darkened areas on the bearing assembly. This discoloration does not signal a need for replacement.
Hope this helps?
Jun 27, 2017 | 1999 Chevrolet S-10 Pickup
How do we add cargo rails? We have a 2006 pacifica and we would like to attach some extra cargo on top in a car top carrier but we dont know how to do that
check with a few auto parts stores they might have a carrier than can be put on when you need it.That might save you alot of work by installing a perminate one
Dec 06, 2010 | 2006 Chrysler Pacifica
I am trying to replace the starter in my 86 nissan stanza but cant see it
NISSAN STANZA WAGON - Manual Transmission
Q. Where is the starter on a 1986 nissan stanza station wagon and how do you get to it ?
Due to limited access to the starter, it is recommended that the transaxle be removed when servicing the starter.
REMOVAL:
1. Cold vehicle.
Remove 2 mounting bracket bolts, 10 & 12 mm (Figure 1).
Remove top starter motor bolt 14 mm with universal & long extensions.
Raise vehicle on hoist.
Remove front splash pans 10 mm.
Automatic transmission: Drain 2 qts out.
Remove rt-ft wheel 21 mm., & tie rod (Figure 3), axle cap, cotter pin, adj-nut & rubber washer.
Remove ball joint nuts 17 mm., left lower control arm 19mm. & swaybar bracket 14 mm. (Fig 2).
Remove axle nut 36mm (Figure 4), the front tube, catalytic converter heat insulators 10mm, ctr ex-tube 17 mm., and front tube from exhaust system (Figure 5).
Remove long bolt from ft engine mount (next to radiator), 17mm socket (Figure 6, Item A).
Remove tension rod mount 14 mm. Has adj-bracket with rubber insulators (Fig 6, Items B, C).
Remove right side drive shaft bolts that hold shaft to bracket mounted on engine (Fig7) 12mm.
Remove rt-driveshaft.
CAUTION: Transaxle side seals are cut by spline teeth.
Install hoist type transmission jack and wooden block under the transmission/engine. Be certain the transmission is safely balanced on the hoist.
Remove 5 engine crossmember mounts (3 bolts, 2 nuts) 14mm.
Remove nut that attaches crossmember to engine mount.
Loosen stabilizer bar mounts to allow adequate clearance for crossmember to be removed.
Remove following brackets to allow starter assembly to pass through bottom:
tubular support bracket - engine to transaxle
angled support bracket - driveshaft bracket to engine mount
manifold collector stay - (bottom bolts)
Loosen top bolts, remove bracket above driveshaft-holding bracket 14mm.
NOTE: This bracket is slotted to allow it to slide out without completely removing the bolts.
Remove bottom starter motor mounting bolt.
Separate starter assembly from bellhousing, DC all cables/connectors, remove starter motor.
When installing starter, connect cable, install/torque starter bolts.
Nov 03, 2010 | 1986 Nissan Stanza
Wheres the fuel pump located
the fuel pump is located inside the fuel tank, the tank must be pulled to replace the pump.
Mar 05, 2010 | 1996 Ford Crown Victoria
Where is the fuel pump located on 1988 Chrysler Conquest?
v
Fig. 1 Fuel pump mounting on sedan and hardtop models
Fig. 2 Fuel pump mounting on station wagon models
Some early models and all turbocharged or fuel injected cars are equipped with an electric fuel pump. On the early models the fuel pump is mounted in the trunk on sedans and hardtops and in the left rear wheel housing on station wagons. On the turbocharged Colt and fuel injected Vista, the fuel pump is in the gas tank. On the Conquest, it is on the frame rail, behind the left rear wheel, and on later models is located on the fuel tank.
Fig. 4 Electric fuel pump used on Conquest models
On late Conquest models, the fuel pump is tank mounted. It is necessary to remove the fuel tank for fuel pump service. Refer to the Colt/Vista procedure.
Hope helped.
Mar 03, 2010 | 1988 Chrysler Conquest
Cycling Logo
41 people viewed this question
Top Carrier Cycling Experts
Michial Gueffroy
Bill Boyd
Are you a Carrier Cycling Expert? Answer questions, earn points and help others
