Question about LG LFC21760 Bottom Freezer French Door Refrigerator
Temp controls not working
Temp control are blank and not working.
Frigidaire model ffu2065fw1 light and alarm works but the control module is blank???
Good Morning Friend,
I understand that the light and alarm are working fine on your Frigidaire freezer, model# FFU2065FW1. I also see that you are receiving power to the control module, however it is blank. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try adjusting the temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire Freezers
GE gas range JGBP33WEH3WW totally dead after self clean
There may be an oven over temp thermal switch that has opened and needs to be replaced. Also you need to determine why the temp got so hot to cause this safety device to do its job. This might be a failed cooling fan
Nov 17, 2013 | GE JGBP33 Gas Kitchen Range
Oven stops working and display screen goes blank
Hello The control has developed faults in one or more of it's circuits. This clock/timer must be replaced to solve the problem. The Good news is that this is not one of the really expensive controls. Found this one for about 70$ at a website. Worth fixing- but beware the 'self-clean' function after repair, and this control should last a lot longer.  Please acknowledge this post if info helps- have more if needed- Thanks- Ed
Mar 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
GE Profile refrigerator, PSC23SGRCSS not working
I have the same problem with the same model. Did you ever find an answer?
Aug 30, 2009 | GE Refrigerators
Kebs208d THE DOOR WILL NOT UNLOCK
HI, this is a major control fault. you will need to replace the Oven control asap if possible. It has failed.
Possible causes--
*Power surge
*Failed logic(IC)
*Oven Temp Sensor failuer that has resulted in extreme temps that has overheated the board.
Jun 07, 2009 | KitchenAid KEBC207 Electric Double Oven
1999 Villager heater and a/c controls are dead and stuck on high
I am guessing your electronic control head is bad. You can buy a used one at car-part.com. Look for the page with the asterik for the cheapest prices and look for a warranty. New are @ $400 to $800. Used, under $100.
you have to remove center console for access to remove trim panel around control head ( heater controls). About a half hour job.
Dec 23, 2008 | 1999 Mercury Villager
05 X auto climate control panel, blank!
sounds like the climate control panal is dead.
Dec 18, 2008 | 2005 Ford Excursion
Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Feb 02, 2008 | Refrigerators
Oven Temp Display
if the oven doesnt work and the display is blank then you would have to get a control board for the unit.
Jan 22, 2007 | Samsung RGSF5330DT Gas Kitchen Range
LG LFC21760 Bottom Freezer French Door Refrigerator Logo
20 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
