Question about Microsoft Windows XP Professional SP3 Full Version OEM for PC
Bsod 0x1000008e caused by usbscan.sys; intermittent
    Problem Solver:
  • 13 Answers
Insert your XP CD, press any key to boot and then repair
"hope it helps"
Posted on Jun 10, 2010
BSOD involving Tunnel.sys and ntoskrnl.exe
Deoending on your OS you can find repair disk on-line. Do a Google search of your OS and repair disk iso. Take a look at this for a general idea, at the bottom of the page:http://maximumpcguides.com/windows-7/create-a-windows-7-system-repair-disc/ OR http://maximumpcguides.com/windows-7/create-a-windows-7-system-repair-disc/
Dec 09, 2012 | ASUS Computers & Internet
Bsod 0x1000008e with windows xp and at&t lightning connect
If you are using the ATT software, that's your problem. The Sierra Wireless 'Watcher' software is much better and can be downloaded at the following link.USB Connect Lightning for AT&T
All the best
Ben
May 25, 2011 | Sierra Wireless ATT Lightning USB Aircard...
I'm building an new system and get a BSOD (Attempt to reset the display driver and recover from timeout failed.)with STOP 116(hex) and a warning about atikmpag.sys. When I first load the OS (Win 7 Pro,...
make sure all the power connectors are connected to the card ,then run the ati driver cleaner,or any driver cleaner of your choice will work,then install the catalyst 11.2 and see if that works,worked for mine.
Apr 27, 2011 | Computers & Internet
M2nmxse board
new IDE or SATA Leads or hard drive
Jul 25, 2010 | ASUS M2N-MX Motherboard
Initially a gateway pentium 4 with XP got a boot sequence failure with BSOD 0x000024a. left it plugged in for a couple of hours, now the boot sequence fails with a BSOD 0x000021. What next?
STOP error 0x24 means a problem occurred in ntfs.sys, the driver file that allows the system to read and write to NTFS drives. STOP code 0x00000024 may also display "NTFS_FILE_SYSTEM" on the same STOP message.
Seems your hard drive is experiencing problems causing this error to occur.
Feb 16, 2010 | Gateway 400VTX-3501335 Notebook
Scanning
Hi saly_60,
You can try the following steps to resolve the issue:
1. Connect the USB cable directly to a USB port on the computer Ifyou are connecting the device through a USB hub* or other USB device,disconnect it and try connecting directly to a USB port on thecomputer. If successful, the problem may have been with the device.
*Somescanners are powered by the USB connection. This is why connecting thescanner through another device, such as a USB hub, may prevent thescanner from communicating properly with the computer.
Connecting the cable to the your device.
usbtoprtr.gif Connecting the cable to your computer.
2. Check USB Connections Youshould disconnect and reconnect the USB cable at both ends to ensurethere is a secure connection on the device side as well as the computerside. It may also be necessary to try a different USB port on thecomputer. Additionally, you may need to disconnect other USB devices,temporarily, in order to determine if a conflict exists. .
  1. Disconnectone end of the cable and then reseat it ensuring the cable is firmlyseated into the USB port. If the USB cable is plugged into a hubinstead of directly into the computer, try connecting the USB cabledirectly into the computer.
  2. Repeat step one to reseat the cable on the other end.
  3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
  4. Make sure the correct USB cable type is being used.
  5. Incorrect (A to A) USB Cable
    Correct (A to B) USB Cable
3. A device attached to the computer is blocking communication If you have more than one device connected to your computer, thenit is possible that some other device is blocking proper communication.
  1. Check to see if there are any devices (other than USB keyboards or mice) connected to the computer.
  2. Disconnect the device(s) and restart the computer.
  3. Once the computer has restarted, attempt your process again.
4. Press the ON/OFF button to power on the device. The device has an <ON/OFF> button.
  1. Connect the power cord from the device to the electrical source.
  2. Press the <ON/OFF> button.
  3. Wait until the device has completed its cycling process before submitting a job request or completing installation.
5. USBSCAN.SYS USBSCAN.SYS is a Windows system fileand required by the scan driver. If the system file is missing, anerror message will appear while installing the scan driver or willappear when attempting to scan. Search for this file and direct theinstallation to the appropriate path.
Search USBSCAN.SYS file on Windows XP:
  1. Click 'Start', 'Search' and select 'For Files or Folders'.
  2. At 'Search Results' window, type usbscan.sys in 'Search for files or folders named' field.
  3. At 'Look in' drop-down menu, confirm your computer's hard drive is selected. In most cases, C: is the computer's hard drive.
  4. Click 'More advanced options' link.
  5. Confirm checkmarks appear beside 'Search system folders', 'Search hidden files and folders and 'Search folders'.
  6. Click 'Search' button.
  7. Once search has completed and if the file does not exist, download a copy of usbscan.sys from here (Right click and select ‘Save Target As’).
    1. Ifthe file exists and a message appears while installing the scan driver,direct the installer to the appropriate path. For example,C:WINDOWSsystem32drivers.
  8. Close the 'Search Results' window.
Search USBSCAN.SYS file on Windows Vista:
  1. Click the Start button.
  2. Inthe Start Search box of the Start menu, type 'usbscan.sys' (without thesingle quotes) and then press 'Enter' on the keyboard.
  3. Once search has completed and if the file does not exist, consult the computer manufacturer.
Uninstall and Reinstall the Driver If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them. Caution:Uninstalling means deleting software, such as MP drivers, from thecomputer. Once the software has been deleted the unit cannot be usedthrough the computer until the software has been reinstalled.
Note:Login as a user with Administrator privileges to uninstall onWindowsXP/2000. Turn off any programs running in the background, suchas antivirus programs and firewalls before begining.
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
6. Reinstall the Drivers
Use the CD-ROM that came with your printer or download from canon website.
Sep 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Bsod during windows installation
Try doing this as suugested, you might not need reformatting.
http://www.pcreview.co.uk/forums/thread-94921.php
Oct 22, 2008 | Gateway M350 Notebook
What say you?
Hi beester,
The file you specified is a driver for a logitech webcam and there is a possibility that it's corrupted, try to boot you computer into Safe Mode(if your running windows of course press F8) and try to uninstall or upate the driver for your webcam and check if you will still receive a BSOD(blue screen of death) on your computer. hope this solution fixes your computer problem.
You can also check this link and see if this will solve your problem if the above solution fails; http://www.runscanner.net/files/sys/lv321av/lv321av.sys.aspx
Regards
May 12, 2008 | Computers & Internet
Logitech drivers causes system error using XP. LVckap.sys
View this site for possible solutions http://forums.logitech.com/logitech/board/message?board.id=quickcam_software&message.id=518
Jan 19, 2007 | Logitech QuickCam Orbit Personal Web...
Open Questions:
See all Microsoft Windows XP Professional SP3 Full Version Questions
Microsoft Windows XP Professional SP3 Full Version OEM for PC  Logo
237 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
