Question about HP Photosmart C6180 All-In-One InkJet Printer
Led lite on power module turns on but when you plug the module into printer it goes off and printer won't tunr on hp c6180
  • 100 Answers
Check the logic board for failed capacitors. My C6180 started showing ink system failure messages and eventually would power on and off every 20 seconds or so. This was caused by a few failed capacitors on the logic board. i the attached picture of my C6180 logic board you can see the bulging tops of 2 capacitors (indicating failure). I replaced 4 capacitors (cost ~ 60cents) and the pinter is working great. If you are not comfortable doing a little soldering, you will have to find some help (took my 25 minutes).
Posted on Sep 17, 2010
  • minpdx Jan 28, 2011
    This info has been so helpful along with this group of pictures:http://picasaweb.google.com/109215435720... The pictures show how to get to the logic board. Thank you for helping me fix my printer instead of turning it into a boat anchor!
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Does this video solve your problem?
I am an HP employee. I do not represent HP on this site.
Posted on Jun 03, 2010
How do I reset displaylanguage to english HP C6180
You can do a reset on your printer.Unplug the power cord of the printer.Press and hold the # and 6 buttons together and then plug the power cord back into the outlet.Keep holding the 2 buttons until the display goes blank or RESET is displayed.If the printer automatically turns off, turn on the printer.The printer should start up and you will be able to select language code.
Oct 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
While installing the HP Photosmart Full Feature Software and Drivers from the HP website, power went out for a few seconds. When power returned the printer was off and will not turn on when the power...
Theres nothing in the drivers that would cause this unless the software was doing an update to the printers internal software
you could try a hard reset
1. Remove all cables, including:
2. Unplug the printer power.
3. Hold down # and 6 on the keyboard.
4. Plug the power cord back in. .
Mar 18, 2011 | HP Photosmart C6180 All-In-One InkJet...
Printer goes on & off not staying on but a couple seconds
Follow these steps to make sure that all the power systems work correctly.
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif Illustration: Power module c00057913.jpg Illustration: Power cord
    NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power supply for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power supply to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn on the product.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
    • If the product still does not turn on , continue with the next solution.
Solution three: Make sure that other devices are not causing the issue Follow these steps to make sure that devices plugged into the HP product are not causing the problem
  1. If the parallel and universal serial bus (USB) ports of the HP product have other devices plugged into them, unplug those devices.
  2. Press the Power button (c00636182.gif ) to turn on the HP product.
  3. Monitor the HP product to see if it turns off again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
Photosmart c6180 repeatedly turns off about every 10 seconds
Solution one: Press and quickly release the Power button Follow these steps to turn on the product correctly.
  1. Remove any memory cards or USB drives from the HP product.
  2. Press, and then quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power button c01941590.gif Illustration of pressing and releasing the power button
c01733891.gif If you press and hold the Power button too long, the product might turn on and then turn off without restarting. The product might also appear to be turned off in Powersave mode. In either case, press, and then quickly release the Power button (c01602202.gif ) to turn on the product. Solution two: Check the electrical connections and outlet Follow these steps to make sure that all the power systems work correctly.
Nov 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
If I open and close the printer it starts as if it is doing printer prepeartation, but nothing comes on. The screen will not turn on.
  • SOLUTION 1 If the HP All-in-One is turned off, press the On button to turn the unit on.
  • Unplug the power cord from the back of the HP All-in-One.
  • Wait 15 seconds.
  • Plug the power cord back into the HP All-in-One.
  • Turn on the HP All-in-One by pressing the On button.SOLUTION 2: Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
    1. Unplug the power supply from the rear of the product.
    2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
    3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
    4. Wait 15 seconds.
    5. Reconnect the power cord to the power module.
    6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
    7. Check to see if the power module has an LED.
      • If the power module does not have an LED, continue to the next step.
      • If the power module has an LED, check to see if the LED lights up.
        • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
        • If the LED lights up, continue to the next step.
    Step two: Test the power on the All-in-OneFollow these steps to test the power on the product.
    1. Reconnect the power supply to the rear of the product.
    2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down.
  • Apr 07, 2010 | HP Photosmart C6180 All-In-One InkJet...
    NO power to HP 6180
    check that the light on the power module(black box) its binking or not.. is it getting hot or not.. if it neither of these two happens then power cable is faulty.. replace it
    Oct 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Model c6180 printer gives improper shutdown error
    The printer is not getting enough power. When you get this error message it means the printer is being turned off by unplugging the power cord. In this case it maybe that the printer is not getting enough power due to being in a surge protector or perhaps the power module is no longer holding power correctly.
    First step is to disconnect printer from any power strip, surge protector, or extension cords and plug in so directly to the wall. If printer still will not stop looping cycle you may need to contact hp for a new power module.
    Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
    HP C6180 boot - init loop / power on-off loop
    The Formatter board (main logic board) is faulty. You need to take the printer in for repairs to HP, in my experience though it usually works out better to replace the printer.
    Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
    The printer only stays on for one minute then shuts off
    Check the following weblink and if issue persists replace the power module and power cord.
    http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00865701&dlc=en
    Regards,
    Sagarjd
    Nov 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
    HP Photosmart C6180 All-In-One InkJet Printer Logo
    1,229 people viewed this question
    Seeker5211
    Seeker5211
