Question about Amana DRS2462B Side by Side Refrigerator
Amana refrigerator model drx2462bw the water dispenser pours water without me doing anything??I replaced water filter today. My orginal problem was the ice maker was not making very much ice so I disconnected water lines and tried to flush them out when I hooked everything back up the water dispenser started pouring about a glass of water every 20 minutes and won't stop
  • tomtfd27 Jun 03, 2010
    what can be the problem why the water dispenser keeps pouring out about a glass of water every 20 minutes without me touching anything? It started today when I was trying to fix the ice machine from not making enough ice cubes but I hooked everything back up. could I have hooked up wrong water tubes to the water inlet??
  • 2,841 Answers
First turn it on and let about 5 gallons of water flow out. If it does not shut off after doing that then the valve on the back of the refrigerator is defective or the micro switch is bad. If you can do without the water dispenser then look on the back of the refrigerator and you will find a dual water valve. One is for the ice maker and the other is for the ice maker. Unplug the 2 wires for the water valve side. You will have to determine which is which. You can purchase a replacement dual valve at any appliance store. It is not likely the micro switch but it is possible. This is a time bomb just waiting to flood your kitchen so get this repaired ASAP and turn the water off until you do.
Posted on Jun 03, 2010
    Brigadier General:
  • 3,513 Answers
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve
let us know if you want somethin more else please accept the suggestion.
Thank You for contacting Fixya.com
    My water dispenser keeps pouring out water every 20 minutes without me doing anything
Why is my refrigerator leaking water after changing water filter?
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
May 27, 2012 | Amana Refrigerators
We never received a manual and now need to replace the water filter. model no. ASD2522WRW03 - ser. no. S01831393. also how do we order a replacement manual
The direct link to the manual from Amana is http://www.kitchenaid.ca/assets/pdfs/literature/User%20Instructions%20-%20W10237701A.pdf . If the direct link doesn't work, start here: http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ASD2522WRW03&siteCd=AMA&userType=Consumer . The manual is also available at Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17324/AMANA-Side-by-Side-Refrigerator-L1002225?brand_name_search=ASD2522WRB03+AMANA .
The filter you need is T2RFWG2 and P2RFWG2 (part number 4396841) . The filter is in the base grill on the freezer side of the side by side. There is a cap over the filter. You need to push the release button on the cap to remove the cap and filter. Save the cap and put it on the new filter before replacing the filter. If you replace the cap, you can use the water and ice dispenser without the filter.
If you want a printed copy of the manual, you can order it from Sears Parts Direct. They also have the filter. See http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ASD2522WRW03/1268/0165000/W1009009/00001?blt=06&prst=&shdMod= . The manual is part 1 ($5.99) and the filter is part 30 ($54.98). The filter is also available from Partstore.com http://www.partstore.com/Model/Maytag/Maytag/ASD2522WRW03.aspx for $37. Amana sells the filter here: http://www.amana.com/accessories/refrigerators/water_filters/refrigerator_water_filter___in_the_grille_fast_fill_push_button_4396841.pro?scr=category for $40. If you go here: http://www.amana.com/accessories/refrigerators/water_filters.cat , you can order several filters at once.
I hope this helps.
May 22, 2011 | Amana Refrigerators
Where is the water filter on the amana #scd25tw
The Amana with model number SCD25TW does not have a water filter. You would have to install an in-line filter on the water supply line if you want to filter the water. If your talking about the model number ARS266ZBS, then open the refrigerator door and look at the top right hand side. You should see a filter housing with a tab to release. Once released you have to remove the filter from the housing to replace it. When finished be sure to run about a gallon through the dispenser, to flush any air out of the system.
Mar 23, 2011 | Amana ARS266ZBS Side by Side Refrigerator
The inside water spout on this refrigerator stopped dispensing water
Checckwater pressure.The 1/4" water supply line should deliver at least 9 ounces of water in 5 seconds. If not, the water pressure is low. Make sure the dispenser is notlocked. Some models have a lock feature that deactivates the dispenser andcontrol buttons. The lock button is located on the dispenser front cover.This feature controls unintentional dispensing. Press the"Unlock" or "Locked" button to reactivate the dispenser andallow dispenser function. You may need to hold the button for2 to 3 seconds. A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced. Thanks.
Feb 03, 2011 | Amana ARB2259CS Bottom Freezer...
Water does not dispense
need to replace your water inlet valve on rear of refrigerator.
Jun 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Mar 15, 2009 | Amana ARB8057CSL Bottom Freezer...
Water dispenser not working
The filter you installed was empty, You will need to purge the air from the system. Simply hold a glass in the dispenser with water selected until water flows.
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Amana ARS2464B Side by Side Refrigerator
Replaced selenoid water just keeps pouring out
Water dispenser seal in the door needs replaced.
Jan 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana refrigerator water dispenser
could be carbon particles from a broken carbon filter cartridge. replace the filter and flush about 5 gallons of water before checking the water again that comes out of the dispenser.
Feb 19, 2008 | Refrigerators
No ice or water from dispenser
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
Nov 12, 2006 | Amana ARS9265B Side by Side Refrigerator
Amana DRS2462B Side by Side Refrigerator Logo
35 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
