Question about GE DCVH515GF Gas Dryer
Dcvh515: dryer does not heat. Replaced the ignitor. Still no good
I replaced the ignitor. Currently the flame will light and burn for about two minutes. In about another two minutes the ignitor begins to glow but the flame does not start.
  • GE Master
  • 43,501 Answers
Hi, If you have a gas dryerdcvh515: dryer does not heat. Replaced the ignitor - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
dcvh515: dryer does not heat. Replaced the ignitor - 2_bing.gifour dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bingdcvh515: dryer does not heat. Replaced the ignitor - 2_bing.gifs= Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 04, 2010
Gas dryer runs but no heat. Took it apart cleaned all ducts and lots of years worth of dirt out of entire machine, looks brand new. Tested all components.
You did quite a bit of work. One other thing that controls the ignitor is called the flame detector. Its the black box looking thing mounted on the side of the big pipe the flame shoots into. Should be 2 wires going to it. A quick test to see if the ignitor comes on is to tie the 2 wires together. If you see the ignitor come on thats the bad part,
Jun 29, 2015 | Dryers
Dryer will not heat up gas replaced ingertor
If you replaced the ignitor and it still will not light, check the thermocoupler or flame sensor. These allow the gas valve to open when there is a flame, but not open if it does not sense the ignitor or flame.
Jun 17, 2011 | Whirlpool Dryers
I have a 7yo Kenmore Elite gas dryer w/no heat. I tested all the possible culprits with my ohmmeter. I found the ignitor was not glowing so I replaced it. Now it glows but I still have no heat
The glowing if the ignitor indicates that the circuitry is good but the flame/radiant sensor is bad and/or one or both of the gas valve solenoid coils are not working. The flame/radiant sensor bypasses one the solenoid coils then when power is applied to the ignition circuit, the first coil opens the first valve, the ignitor glows and the flame/radiant sensor gets heated. It's contacts then opens when heated enough to unbypass the second coil and allow the gas to flow and be ignited.
Make sure the flame/radiant sensor is properly in place and aligned with the ignitor to allow proper heat sensing. You may check the continuity between the sensor's contact terminals as the ignitor glows. At first, the terminals should read close (zero resistance) and then open (infinite resistance) after about 30 seconds or so. If this is not the case, the sensor is not working and must be replaced.
The solenoid coils, one with 2 prongs and the other has 3, sitting on top of the gas valves must be both replaced if the flame/radiant sensor turns out good. But before doing so, make sure to run a test with the dryer completely assembled because sometimes the gas do not ignite when the dryer's cabinet is open. This is to prevent unnecessary replacement of the coils.
Feel free to update us about the result and if you need further advice.
Jun 17, 2011 | Kenmore Dryers
I have maytag dryer and it is blowing cold air. Everything else is working.
If there is no heat then the thermostat or heating element (for an electric dryer) is not working.
If a gas dryer with no heat: Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Nov 24, 2009 | Office Equipment & Supplies
Dryer drum is rotating but no heat is present
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Oct 23, 2009 | Dryers
FLAME ON SART UP NONE AFTER
Replace the gas valve coils if the ignitor glows but does not light. Replace the flame sensor if the ignitor does not glow.
Aug 29, 2009 | Kenmore 73952 Gas Dryer
Dryer Model DE306 has stopped heating
Aug 13, 2009 | Dryers
My dryr tumbles but does not dry
Gas dryer? First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Electric dryer? Temperature sensor has failed or heating element has burned out.
May 30, 2009 | Whirlpool Dryers
Gas dryer won't heat up
The ignitor can glow and still be defective.
Take a volt meter and check for power at the gas valve while calling for heat.
If you have voltage, replace the coils again.
No voltage, replace the ignitor and flame sensor.
Mar 08, 2009 | Frigidaire Dryers
No heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Jul 25, 2008 | Amana ALG331RAW Gas Dryer
Open Questions:
GE DCVH515GF Gas Dryer Logo
429 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
