Question about Desa International Remington 12 Electric Chain Saw
I have a 16 inch chain saw and want to buy a new chain saw blade does anyone know what other manufacturer's blade will fit
    Brigadier General:
  • 4,088 Answers
Oregon mfg. makes a full line of replacement chains and bars (blade). Check with home centers, hardware stores, and saw dealers. Bring full details of the saw with you, or the saw itself. Good luck!
Posted on Jun 05, 2010
I have MS 290 chain saw I need replacement chain number 3003 812 6817 far boss blade looking for chain fit chain saw0.063 18 inch could you direct me other brands that will fit please
I would take the saw to a lawn and garden shop that works on chain saws. A chain can fit more than one type of saw and they will be able to match one up for you.
Feb 23, 2015 | Garden
No problem at all. Just need to make sure the two studs attaching the bar to the motor head fit correctly. Of course, the former chain is now too long. Either have a saw shop make you a 'loop' to fit, usually $1/inch of bar=$16 for your new setup, or try a prepackaged chain labelled for the 16 inch bar. I recommend the former, because then you get an expert to look over your new setup for you. Shop chains are usually better quality, always fit correctly, and cost no more, often less, than department store chains
Nov 14, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
16 inch poulan chainsaw got hot and started to smoke and now the recoil no longer works. I took the cover off and there is two springs that seem sprung. should I toss it and forget it or this something I...
how old is the polan 16 inch is it a solid body saw or does it have anti vibration handles, so your hands dont go numb after cutting for 15 minutes.reason i asked is: you can buy a brand new reconditioned homelite with anti vibration handle for 85.00&shiping.
at the very least,your polan needs the recoil starter fixed
and that does not address why the poulan got hot & started to smoke.
For the problems you described , at least $100.00 labor plus parts to fix at a chain saw shop
It might barely be worth it if you were a do it yourselfer and wanted to try to fix it.
if you dont want to be a diy chain saw mechanic, sell your polan for parts for $20.00 on ebay and buy a new homelite
16 inch 38 cc with anti vibration handle ,so you can cut for 6 hours straight, if need be. You get a reconditioned saw that is ready to go and a 90 day warranty. or buy the saw brand new for $110.00 and free shipping@ amazon.com
Oct 07, 2013 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
The chain keeps falling off my brand new Poulan sixteen inch blade chain saw
It is possible they gave you the wrong chain for the saw. I would take check the manufacture to see which chain you need then check the numbers on your chain. Other thing it could be is the washer on the clutch may be missing. Either way, it is a new saw, I would take it back.
Apr 01, 2013 | Poulan Garden
21 cm saw blade
21 cm is 8-1/4 inches. You could use an 8 inch blade or 7-1/4. But the diameter of the blade is not the critical thing. You must have a correctly fitting hole in the blade to mount on the saw shaft. Standard English size of the hole is 5/8 inch. Just take your saw with you to the store and try a blade on it. If the hole is a nice fit, your are good! (You posted this under circular saws, so I assume your saw is portable.)
Feb 26, 2013 | Saws
Chain oil keeps leaking out..how can I stop it ???
First, make sure you're using bar & chain oil, it's very thick and won't leak out like motor oils will. When you're done using the saw, store it with the blade side of the saw up. Not always convienent, but the oil will run away from the blade oil channels and not leak out.
Oct 22, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a McCulloch Mac 110 mini-Chain saw that needs a new chain blade. I believe it's a 12 inch... anything else I need to know to go buy a new bade?
Hello Kip;
If the new bar is not the same size as the old chains will not fit. Count the drive links on your chain.
If your 44 your bar is 12", if your 49 your bar is 14", if your 54 your bar is 16" and finally if your 60 your bar is 18". If not of the following your chains will need to be professionally resized to fit (select 110 not Mac110 please).
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
I seriously doubt you saw needs an "Intenz" bar.
The Oregon part number you choose can easily be converted to a different bar manufacturer's part number.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 25, 2010 | McCulloch Garden
Craftman,36cc, 18" Gas Power Saw Blade
Go to a home improvement store and buy a new chain, they are cheap!
Jul 29, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I NEEN A OWER MANUAL for a poulan chain saw 2150
its pretty easy to do with a file. first make sure you buy the right size file to fit right in the tooth. look closley at the chain and figure how to place the file on it. the point is to sharpen the side and top of the cutting part of the tooth .always file one way away from yourself. hold the file at an 45 DEGREE angle, and push forward. the trick is to push forward and up at the same time, and always go one direction. start on one side and mark your starting point with tape, go down one side then flip the saw and down the other. you dont have to push hard just enough to were you can see tiny metal fall off. lemme know if you have a problem
Mar 21, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Desa International Remington 12 Electric Chain Saw Logo
168 people viewed this question
Top Desa International Garden Experts
Roland W VanLue
Roland W VanLue
ray gallant
Tim Whalen
Are you a Desa International Garden Expert? Answer questions, earn points and help others
