I have a Clie handheld. I have been having trouble synching it to my computer. It comes up with a screen that it cannot make the connection to my computer and to check all connections. I have done so to no avail. I keep getting the same message. Please advise.
  • 12,061 Answers
Http://www.retrevo.com/support/Sony-PEG-SJ22-PDAs-and-Handhelds-manual/id/287ci152/t/2/ Above is your user manual, I thought that this will be handy. How to troubleshoot Palm™ HotSync® operation issues when using a USB connection to the Palm OS® 4.1 operating systemI have a Clie handheld. - mag-glass_10x10.gif and the Palm™ Desktop 4.0.1 software.
SOLUTION:
Follow this procedure to troubleshoot Palm™ HotSync® operation issues when using a USB connection to the Palm OS® 4.1 operating system and the Palm™ Desktop 4.0.1 software.
IMPORTANT:
Download and install all appropriate handheld updates from the Sony® CLIé® Handheld Support web site at http://www.sony.com/peg/support.
The Palm™ HotSync® operation is only supported when the user has administrator privileges on the computer. Restricted user accounts are not supported.
If a Palm™ HotSync® operation is successful when connected directly via the USB cable, but fails when using the USB cradle, then the issue is with the USB cradle and service may be necessary.
Ensure all previous Palm™ Desktop software versions have been properly uninstalled before the Palm™ Desktop for CLIé® software is installed.
IMPORTANT: To protect the user data when uninstalling previous Palm™ Desktop software, move or copy the user folder to another location.
Ensure the USB cradle or cable is connected directly to the computer.
NOTE: Ensure the handheld is not connected through a USB hub or another USB device.
Ensure the handheld is securely connected to the USB cradle or cable.
On the taskbar in the system tray, click the HotSync® Manager [FIG. 1] icon.
In the HotSync® Manager menu, ensure Local USB is selected.
Perform a Palm™ HotSync® operation.
If the issue still exists, connect the cradle or cable to a different USB port on the computer.
If the issue still exists, perform a soft reset on the handheld.
WARNING: There is a risk of data loss. Performing a hard reset will delete all added programs, updates and records stored on the handheld.
If the issue still exists, perform a hard reset on the handheld.
IMPORTANT: After the hard reset procedure returns the handheld to the factory default configuration, all of the appropriate updates will again need to be downloaded and installed from the Sony® CLIé® Handheld Support web site at http://www.sony.com/peg/support.
If the issue still exists, remove all unknown and conflicting USB devices in Device Manager of the computer operating system.
If the issue is still unresolved after completing all of the troubleshooting steps, service may be required.
Posted on Jun 03, 2010
  • 493 Answers
Xp cannot recognize my clie peg-n700c
You can find the intellisync software needed to connect the handheld to the computer here: http://esupport.sony.com/US/perl/swu-list.pl?mdl=PEGTJ27#div_pos_98
Mar 27, 2011 | Sony CLIE PEG-TJ27 Handheld
Sony clie pegt-615c
Try re-installing the drivers on your computer.
Nov 04, 2007 | Sony CLIE PEG-T615C Handheld
How do I CLEAR everything on my Clie
Hard Reset CLIE Sony Series
  1. Connect the CLIE handheld using the AC adapter and take out the stylus pin by twisting the upper part of the stylus.
  2. Push down and hold the power button of the unit and use the stylus to slowly press and release the reset button on the back.
  3. When the Palm screen will appear release the power button.
  4. At the “Erase all data?” prompt, push the upper part of the scroll button on the front of the device to confirm OK. The Sony pda is now reset and you have only to follow the SetUp steps as prompted.
Feb 01, 2009 | Sony CLIE PEG-SJ22 Handheld
I can't get the Clie PEG-SJ20 software loaded on my computer
 Word is out that OS 6.01 can be installed for SJ20 to work sync in Vista even though Sony hasn't listed it as compatible.
Dec 31, 2008 | Sony CLIE PEG-SJ20 Handheld
Sony Clie sj22
IN BIOS SCREEN SET ALL TO DEFAULTS, BEFORE TRING TO INSTALL RE-PARTION DRIVERS
Oct 14, 2008 | Sony CLIE PEG-SJ22 Handheld
Screen Calibration
Check for protective film/screen debris build-up around edges.
Check for loose cabling plugs into the back of the Screen
Unscrew the four little fascia screws & lift panel out.
I had same problem after unable to enter password.
Did Hard reset, encountered the stylus calibration cycling error.
One of my screen cables had come adrift slightly at one corner.
Jul 29, 2008 | Sony CLIE PEG-N760C Handheld
More applications than I should have
On your main screen touch the menu icon (bottom right in your graffiti box). This will open your drop down menu. Touch "delete" and a list of programs, etc will appear. Select one at a time and then press delete.
Hope this helps
May 21, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Sony CLIE PEG-N760C Handheld problems with connection windows vista
No. I don't thiok so.
To connect with windows, the first step you have to intstaled Palm. OS. 4.1. It's the operating sistem to operate your clie palm. I've perobelm laki this before, but it solved.
thk u..
Nov 19, 2007 | Sony CLIE PEG-N760C Handheld
Palm treo hot synch
try restarting the computer. it works for me
Aug 13, 2007 | Palm Treo 600 Handheld
Installing this PDA on Windows Vista Home Premium laptop
you shouldnt need a device driver for your pda to work along side with Vista, as Vista has it's own Windows mobile device centre which should run as soon as you connect your pda to a usb port. If it doesnt run, then open up windows mobile device centre in programmes and check the mobile device settings as to whether usb is set to connect to the centre.
Jul 03, 2007 | Sony CLIE PEG-T615C Handheld
Computers & Internet Logo
David Payne
David Payne
