Question about Dometic RM2620 Refrigerator
Domestic RM3663 The LP burners will inginate and burn for short period of time and then go out and then you have to reset at control panel cant seem to get it to stay on.....Any sugestions as to what problem is.
  • bsuttle Jun 03, 2010
    The only thermocouple on this one is used as a heat sensor...
  • 4,793 Answers
Replace the thermocouple,its the only thing keeping the pilot alight.
Posted on Jun 03, 2010
  • geoff hunter Jun 03, 2010
    by the thermocouple i mean the little stick shaped sensor that the pilot light flame heats up to allow the gas to flow....
Why does Heat exchanger soots up?
check gas pressure if too low it soots up and overheats
Jun 09, 2014 | Jandy Legacy Lrz325mp Millivolt Ignition...
I have a Jandy XL 250 the exchanger was sooted up the burners were disfigured from overheating so ive cleaned the heat exchanger replaced the burners and the front panel still gets very hot after about 20...
flame should be blue, this sounds like a natural gas unit (orfice) running on LP. Lp is burns hotter than nat. and will burn orange. and use huge amounts of fuel.
Aug 10, 2013 | Hayward 250kbtu Ng Pool Heater - Inground
Buffalo 85 fan not blowing
sounds like the fan is not working, can you isolate the fan and run it by itself with out the burned, this will tell you if it's the fan motor or some sensor that's the trouble
Apr 28, 2013 | Heating & Cooling
Can i convert my cadac safari chef from hp to lp
Vinnie, first lets take a look at what HP gas is, as opposed to regular LP Gas.
HP Gas is a Propane / Butane mixture liquefied under normal ambient temperature and moderate pressures. It is a safe, clean burning, reliable, high calrofic value fuel. In addition to it use as a domestic fuel, it is also widely used in industries, where there is a requirement of low sulphur content fuel and fine temperature controls. HP Gas conforms to IS:4576-1999 specifications.
Converting your grill to HP Gas may be possible, but there would need to be some adjustments to the burner's venturi valve. As the air to gas mixture may be different. Also, you would need to check with your HP Gas Provider, to see if a different pressure regulator would be necessary.
Hope this helps you and Happy Grilling!!.
Jun 27, 2011 | CADAC Safari Chef Portable Grill
Jenn-Air Model 720-0061-LP. Burners will not
burner is blocked needs cleaning out remove burner and clean it or put it in clr , or buy new one
May 18, 2010 | Grilling
Top burners are propane. we are used to propane heating really fast. this stove seems really slow. 5minutes to boil litre of water. burners are having hard time lighting.
If it is new fromt the factory, you many have the natural gas (methane) jets in the burners. You will need to check your bag of parts to find the propane parts (LP parts). LP jets allow a different fuel/air mixture to burn at the right heat. Check the owner's manual for details how to make the change.
Please rate me - Good luck.
Nov 20, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Replacement of burners charmglow 810-6320B
The only way I was able to get the screws out was to use a 5/16" cobalt drill bit to drill through the center of each screw. Then, and only then, was the GrabIT screw extraction tool able to grip and remove each screw. Of course, I had to break off what was left of the burned out burners first to get easy access to the screws. To replace the burners, remove 3 screws (in an L shaped pattern) from the left side of the burner control panel. I did NOT have to remove the utility shelf to get to these screws. The control panel can then be moved forward about an inch, thereby enabling the new burner tubes to fit into their gas spouts. TIPS: It was easier for me to attach the back of the new burners before trying to attach the fronts. I used new 6-32 machine screws to attach them. You'll need to look from the bottom of the burner control panel when attaching the front of the new burners -- to see better.
Jul 13, 2008 | Brinkmann Charmglow Stainless Steel LP...
Oven burnout
replace the oven control
Apr 25, 2008 | Kitchen Ranges
My baby q is sick
Since 1995 all regulators (the part that attaches to the gas tank to regulate the flow of gas) have included a safety device that restricts the flow of gas in the event of a gas leak. This safety device can be inadvertently activated in two ways, putting the grill into what is commonly called “bypass”. The first way for the device to be activated is to leave one or more burner control knobs in the “ON” position when the LP cylinder valve is opened. The second is not to wait long enough to “start” the grill after opening the LP cylinder valve. The safety device in the regulator is activated each time that the LP cylinder valve is opened. The device resets itself when the gas pressure equalizes between the closed burner control valve and the regulator, through the hose. If a burner control knob is turned on before the gas pressure can equalize, the device will remain in “bypass”. The length of time necessary to wait to “start” the grill after turning on the LP cylinder valve is dependent on the length of the hose and outside air temperature. It is always good practice to wait a few seconds after opening the LP cylinder valve before turning on the burner control knob to start the grill.
Keep in mind that the safety device reacts to a gas leak. If a grill is in bypass, the gas connections and hose should be tested for leaks with a soap and water solution.
If the grill is in bypass, after checking for gas leaks do the following to get the grill out of bypass:
To reset the gas safety device:
Open the barbecue lid.
1. Close the LP tank valve.
2. Turn your burner control knob to the OFF position.
3. Wait at least 5 minutes if the barbecue had been lit, then
4. Disconnect the hose from the LP tank.
5. Turn your burner control knob to the HIGH position.
6. Wait at least 2 minutes, and then turn the burner control knob to the OFF position.
7. Re-connect the hose to the LP tank.
Re-lighting the barbecue:
1. Open the barbecue lid.
2. SLOWLY open the LP tank valve all the way and wait 1 minute.
3. With the lid open, turn the burner control knob to the HIGH position.
4. Ignite the grill by pushing the crossover ignition button.
5. Close the barbecue lid.
6. The barbecue should reach 500 to 550 degrees in 10-15 minutes.
When you are done grilling:
1. Turn all burner control knobs to the OFF position
2. Turn off the LP tank valve last.
* Always follow the re-lighting instructions whenever you use the adapter hose and larger tank.
Feb 16, 2008 | Weber Q Grill
Dometic RM2620 Refrigerator Logo
203 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
