Question about Dryers
I have a whirlpool stacker model number LTE6234002. the dryer has power but will not come on. the washer is fine
  • stephen hughes Jun 03, 2010
    where did you test for power
SOURCE: i have a maytag washer/dryer
Start with resetting breaker dryer tumbles with 110 but needs 220 to turn on element. If still no heat might have a bad element.
Posted on Jul 09, 2008
  • 91 Answers
SOURCE: I have an Estate Whirlpool
motor needs to replaced
Posted on Jan 03, 2009
Sea Breeze
  • 4654 Answers
SOURCE: OVERHEATING DRYER
First make sure the vent is not blocked relieving air flow in back for examlpe remove exhaust hose and let it run with a window open for ventalation of course and let me know if this stops the problem
Posted on Feb 02, 2009
  • 512 Answers
SOURCE: whirlpool dryer model number lgr7648kq1 won't get
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Posted on Jun 14, 2009
tombs31
  • 13 Answers
SOURCE: whirlpool stacker washing machine works dryer doesn't
The problem is probably with the outlet. The washing machine motor is 120 v and the dryer is 220 v. If one pole of the two pole breaker is bad you could end up with the symptoms you have. I have seen this happen before. go to the circuit breaker and push it all the way to off (it may feel like you are crunching something inside...don't worry) then turn it back on and try the dryer. If this doesn't work, unplug the unit and test the outlet with a voltage tester. you should read 220-240 volts across the two slots and 120 volts from each slot to ground. If not, it is time to call an electrician.
Posted on Jun 22, 2009
Any particular problems with installing whirlpool stacker washer/dryer in RV
the main problem is how stable the foundation is for the laundry center when it goes into its spin cycle.
Sep 11, 2012 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
I have a Frigidaire Stacker washer dryer that has no model number anywhere and a tub seal with numbers that I have been unable to cross reference.
John, check out http://www.easyapplianceparts.com/ModelFrames.aspx?ModelID=1084015&ModelNum=FEX831CS0&mfgModelNum=&ManufactureID=4&Selected=OMQBC08N&Position=5&mfg=Frigidaire&Type=&Mark=5r
Jun 02, 2012 | Frigidaire FEX831CS Top Load Stacked...
Need to know the year model of a whirlpool washer & dryer that belonged to my mom? The dryer Model #LER6848AWO and the washer Model #LSR7233BWO?
Mar 2009 dryer model #LER6848AWO serial and the washer model is Aug 2010 ... Model Number: LSR7233BWO. Hope you find this useful.
Apr 19, 2011 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Changing dryer belt for lse7804ade washer dryer stacker
If the washing machine / tumble dryer / spin dryer seems to be making the right sort of noises, but the drum is not turning, unplug it, take the rear cover off and check to see if the drive belt is still intact and on the pulleys.
Mar 09, 2010 | Washing Machines
Water leaking from stacker unit
No parts are replaceable within the pump. Buy a new pump.
Jun 22, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
I have a maytag washer/dryer single unit stacker that works fine except the dryer does not give off any heat at all.
Jul 09, 2008 | Maytag Dryers
Whirlpool stacked washer and dryer
unplug unit then wait 1 minute and replug..if still lock out replace control board
Jun 27, 2008 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
173 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
