Question about 3M Garden
Has anyone got a users manual for the Baumr-AG SX-62 my husband just purchased one but he is unable to read the instruction manual as the diagrams are so small and he is unable to fit the side cover ?
We just got this model and put it together tonight. You have to use a fair bit of force to "click" the brake on the side cover to off, before you can attach it. Hope this helps. PS. Did you find a small round plastic piece in the tool bag? Any idea what its for? Cheers.
Posted on Aug 12, 2010
  • bob_gill Aug 27, 2010
    To minno253 - sometimes there are two plastic goizmos in the the kit. One is the starter dog which is easily recognisable by the four teeth, The other is the drive unit for the oil pump which is only accessible by removing the chain, bar, and clutch assembly.
    Bob.
Oil Pump & Worm gear drive for Baumr-ag SX 72 72cc Chainsaw
Cant find much on your machine as its an obscure make and model. This brings with it the ease of sourcing parts, sometimes its better to stick with known brands for this reason.
I managed to find this, it might be worth comparing it to the one on your machine. Hope it helps.
http://www.chainsawspares.com.au/oil-pump-and-worm-drive-for-baumr-ag-sx25-25cc-cha
Mar 30, 2016 | Garden
How do you adjust the idle settings on a Baumr-AG SX 25 chainsaw
T is most likely the throttle or idle .
H is for high speed. that is adjusted first, only if adjusting carb.
L is low speed , it would be second, again only if adjusting carb.
Then the T which can be safely adjusted anytime.
May 18, 2015 | Garden
Baumr ag User Manual Needed
http://baumr-ag.com.au/where-buy-baumr-ag
  • There should if available for your model type a maintenance kit neccesary for your model or all the used o-rings and sometimes special tools because there are special buna-n or nbr o-rings used sometimes braun or green colored on some parts and gaskets, seals and rings used and allways if your tool is leaking then replace the impact bold in front of the spindle if you have find the right drawing for your model type
  • The right lubrication is very important in combination of the o-rings because of the heat building release by rotating and hammering and a leaking tool has oft made all o-rings hardenet because of the failed pneumatic working loose of lubrication dried out principal it becomes very dry internal on some places and much to hot .
Sep 05, 2014 | Drills
I need a service centre for my Baumr SX 72 chainsaw in the Geelong?
Try reading
http://www.productreview.com.au/r/baumr-ag-62cc-professional/549822.html
Where I have a bit of a problem is that this question about a chainsaw is headed 'Problem with Video Cameras'. Maybe Fixya's fault.
May 29, 2014 | Video Cameras
My baumr ag sx 82 chainsaw cuts out like its choking and does not rev that well
check the spark arrestor screen in the muffler. if its plugged up then the saw can't exhaust and will bog down
Sep 22, 2013 | Garden
Need spare part for baumr-ag professional pole pruner saw
Need a new pull starter mechanism/kit for Baumr - AG PNHT 4500 Professional Pole Pruner Saw
Feb 05, 2013 | Garden
Hi There, we've bought a SX62 Baumr-AG chain saw. On page 8 of the instruction manual - Point 3: "Install the attached spike to the power unit" - there is no diagram that refers to this...
I have just bought one and the manual is hopeless but finally I figured it out. If you have installed the chain and guide you will need to remove them, then with the saw lying on the side and chain cover off you will see two holes on opposite side of the oil tank/engine casing
Nov 05, 2010 | Garden
Where do i find pull start parts for the baumr-ag 62
Email agrmachinery@gmail.com This is the main seller of Baumer-AG machinery on ebay .. I know that he has a fair assortment of parts as I had to change my startr when it fell to bits.
Regards, Bob.
Aug 09, 2010 | Garden
Where can i get parts [coil] for a BAUMR SX 72 CHAINSAW REGARDS R
Should you wish to purchase the part, simply make a purchase by logging in to our website www.agrmachinery.com.au (www dot agrmachinery dot com dot au) to get it dispatched asap.
- Click on the *Parts Finder* drop down menu box on the upper right area on the page.
- Select your item from the list displayed
- Select your model if prompted
- Examine the Exploded Parts Diagram to identify which part number you need
- Match the part number up with the list below to find the product code for the part you need
Apr 24, 2010 | Garden
Garden Logo
1,283 people viewed this question
Top 3M Garden Experts
Dennis Key
Dennis Key
john h
Are you a 3M Garden Expert? Answer questions, earn points and help others
