It easy ! You need a
philips and flat screw driver,8" X 4" block of wood and a needle nose pliar.
Use flat screw driver and pry out the two or three dust covers for the arm rest screws then use philips and remove the screws. Next use the flat screw driver and pry out the black plastic mirror cover from the inside of the door. Pry out the switch panel ( aka master switch panel) with the flat screw driver and disconnect it. On the side of the door panel just above the striker is this plastic push pull typeof a hold in screw. Use flat screw driver to get it to move a little then pull it out with the needle nose. Depending on which door your doing if you have a map folder ( driver or front passenger door) in the door there are two more screw to remove on the bottom of the door.
Now the inside door handle is tricky it comes out in two pieces. Use philips and get the only hold down screw you see out.( you may have to pry out al ittle screw cover first) Now the handle cover is removed by placeing the flat screw driver on the rear of the outside of the cover top and on the outside rear bottom to release the tangs that are holding it onto the panel.Pry it out lightly you may have to place the screw driver over the top of the door release button and pry that way. Don't loose your cool its a pain but it will fall out. Once its removed unhook the panel.
Next lift the plastic cover and remove the six
gold bolts first(For motor and regulator) Then push the window down till you see the two bolts holding the window to the regulator .Remove them, BEFORE YOU PULL OUT THE MOTOR AND REGULATOR YOU WILL SEE TWO TANGS THAT HELP HOLD THE REGULATOR AND MOTOR TO THE DOOR MARK THE RELOCATION , NOW pull out the motor and regulator have an assistant hold up the glass while you place the two blocks of wood to hold up the window. Now order your regulator and installation is in reverse. Good luck kate. Keep me posted.
Comments:
