Question about Dell Inspiron 1521 Notebook
My daughter in law's Dell Inspiron 1521 won't power up. I've tried pulling the battery and power. Holding down the power key for 10 seconds and then plugging in the power. It doesn't help. I also tried blowing out any dust, still no help. What it does is the power led lights up for abojut 3 or 4 seconds then it goes out. I here a click, which I think is the drive shutting down. The power adapter has a green light and is putting out almost 20 Volts. A big question I have is that after the power light goes out the batter status led lights and then shuts down. Shouldn't the Inspiron battery status led stay lit? It is still connected to the power supply.
  • clflyer Jun 03, 2010
    Expert #1 says it is the motherboard. I'm wondering why the battery status led doesn't stay lit. Could it be as simple as the power adapter isn't getting to the computer?
    Bill
  • 493 Answers
Would you please try this:
-Take out the battery,
-Disconnect power (main supply),
-Hold the power button down for 30 seconds (to clear RAM,
-Reconnect power, do not put battery in
-Turn laptop on.
(If it works then put the battery in.)
Hope this helps.
Waiting your comments.
NOTE: The power and charge lights flashing are a BIOS function. Windows will detect the battery discharging, but the battery will be absent on recharge (power light will stop flashing, but charge light will remain flashing).
Posted on Jun 03, 2010
  • clflyer Jun 04, 2010
    I tried that, no success.
    Power led lights up for 4 seconds then goes off, battery led goes on and then goes off right away. No leds are lit, even though it is plugged in.
    Bill
  • Ibrahim OKTAY
    Ibrahim OKTAY Jun 04, 2010
    Hi Bill,
    Sometimes one of the two memory slots or memory card goes bad. You may try removing one MEM stick, if that doesn't work, put it back in and remove the second stick.
    Brigadier General:
  • 3,513 Answers
Most probably the problem is your motherboard,which you need to replace.If your laptop is under warrenty,kindly contact the company for this serious issue.
let us know if you want somethin more else please accept the suggestion.
Thank You for contacting Fixya.com
    Should the battery statuslight go out? All other laptops I've had or used that led stays on when plugged in.
    This laptop is not on warrenty.
Have a black screen on dell 1521
try taking the battery out, pull out the power cord, and push and hold down the power button for 10-15 seconds. Then put everything back and try to start normally. If the problem still continues, try turning it off and pulling the memory out of the laptop and then reseat it...sometimes this may cause the problem but without any sorts of beeping or display occurring, it's very hard to help you on this one. I'm wishing you the best though. :-)
Feb 26, 2014 | Dell Inspiron 1521 Notebook
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Inspiron 1521 will not power up
I'd say that you have exhausted your options. You can try to isolate the power on problem by removing your your memory modules, hard disk drive and see if it at least stays powered on. Here is a link from Dell for your laptop's manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1521_Owner%27s%20Manual_en-us.pdf
Feb 09, 2013 | Dell Inspiron 1521 Notebook
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
I can't get my dell inspiron to power on. I will charge the battery using the wall charger but will not come on. What can I try?
Try this if will help.
Remove battery and unplug the ac adapter from laptop.
Without the power sources hold down the power button for 10 seconds.
Check the ac adapter from wall power socket if ac adapter LED is ON.
Plug back in the ac adapter to laptop then check the LED from the ac adapter if it stayed on.
If ac adapter LED turned off right after you plug in the ac adapter to laptop then you need to replace the ac adapter, motherboard and power daughter board.
Hold down the D key then Press Power Button once. Check if color display will appear in the screen.
if the ac adapter stays on you and still no power indicator from the laptop you need to replace motherboard and power daughter board.
Hope this helps.
Jun 02, 2011 | Dell Inspiron 6000 Notebook
My daughters 1525 dell laptop will not work properly.You can turn it on the dell name appears and that is it all lights are working fan is working I hope you can help with out me she has all her photo;s...
If the power LED is ON and you can sense the fan as well problem might be on the LCD or Motherboard.
Could you please try this one and give me feedback what had happened.
Remove ac adapter and battery from laptop.
Press and hold down power button on the laptop for 10 seconds.
Plug in the ac adapter.
Hold down the Fn key then press power button once, then just keep holding down the Fn key.
You might not see anything on the screen but please do take note of the error code or beep codes.
Thanks!
Apr 29, 2011 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1521 has had a battery problem for a couple of weeks but just taking the battery out and only using the adapter worked just fine. One night the computer shut itself down twice. The next...
Try running the diagnostics on the computer. You may need to repeat some of the steps that you have already done to initiate the same.
1. Remove the battery and the Ac adapter from the system
2. Press the power button for 10 seconds
3. Reinsert the battery and connect the Ac adapter
4. While holding down the FN key on the keyboard press the power button.
If the system beeps in a series on 3-3-3 or 3-3-4 the system is ok and there could be a problem with the screen.
If the system beeps in some other code . revert to the post and we would let you know where the problem is .
Thanks for using fixya
proton
May 11, 2010 | Dell Inspiron 1521 Notebook
I've a dell inspiron 1521 battery problem
The battery has an internal failure (Most likely a bad cell) While the battery works, the resolution for the LED indication is to replace the battery. Batteries are a consumable item and generally, batteries have a life of 300 to 500 recharge/discharge cycles before replacement is necessary.
Oct 17, 2009 | Dell Computers & Internet
Switching on the laptop
Try holding the power button down for about 10 seconds. Then try turning it on.
Next remove the battery and try to start with just mains power.
Next replace the battery in the computer and let it charge.
If this does not work you will probably have to contact Dell
Nov 15, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 1521 Notebook Logo
402 people viewed this question
Alun Cox
