Question about GE GSL25JFPBS Side by Side Refrigerator
Just wont get cold
Hello
I used the refridgerator for about 2 yrs and all of a sudden one day it just lost the cold air in it! I can turn it on and everything runs great except it just doesnt get cold anymore! I have tried taking off the back panels and blowing off the dust or seeing if anything looked wrong. But nothing looked wrong and it still doesnt work after assembleling again. The frigerator was located in a tight enclosed whole if that helps. Thanks for taking time to read this and help me out thanks!
  • 56 Answers
I would check the evaporator in the freezer to see if it is getting cold anywhere on it .if it doesnt then you need a sealed sytm repair compressor or lose of freon
Posted on Jun 03, 2010
Is a small amount of brown moisture coming out of A/C w/cold air & slightly squeaking fan upon yearly startup on kenmore model 253.70101 acceptable : should i run it longer than 1 minute.
Brown is rust.
Painted metal outside for 2 yrs eventually rusts (ergo: brown drips) The fan is exposed to heat/cold/wet and the sintered bronze bushings may have lost their lubrication and/or the shaft is corroded, causing squeaks. Take the case off and try to lube the shaft bearings with oil, not WD40.
May 13, 2014 | Heating & Cooling
RUUD AC cycles warm & cold 24/7
Hello Anna Sounds like the compressor is overheating and stoping on overload internally.Then it cools down restarts and runs into overload again.I would like to see the freon pressures when running.Could have a clog/restriction in piping.I dont like that you went thru a compressor already, the original installition is suspect.The original (1st) failure cause must be corrected.Check the TXV valve replace, filter/dryer look for a kinked pipe are ideas for overheating.Make sure condenser coil is free (ari flow)& clean also.
Jul 30, 2010 | Ruud UBHC Air Conditioner
Air condioner stopped getting cold
Run truck and turn on A/C check condensor and see if clutch is engaging, if it is that part is good, know how many times does it engage in 1 minute if more than 3 l'd say your refridgerant has escaped and an A/C service will be required.... along with other parts, hole worn seals....
Apr 27, 2010 | 2004 Ford F250
Air conditioner isn't blowing cold air
Could be a number of things...electrical connections causing the compressor not to run. Turn on AC and turn your thermostat all the way to cool...now visually check to see if compressor is engaged and not just free wheeling. Most likely you lost your refridgerant due to leak in the system...would need to find leak and repair then have your system re-charged with refridgerant. Best case scenario...your system just needs a charge of refridgerant due to not having enough.
Jul 25, 2009 | 1993 Mercedes-Benz E-Class
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
No cold air n at all in refridgerator or freezer oadmirall sideo
I believe i just posted part of your answer and mine, switch icemaker switch to off position and noise stops i'm assuming ice maker has had better days but hope it can be remidie
Jan 03, 2009 | Jenn-Air JCD2295HES Side by Side...
Refridgerator isn't keeping cold
its in the freezer when you open yhe door the compressor is in the back take the cover off and see if trhe compressor is running
Apr 03, 2008 | Refrigerators
GE GSL25JFPBS Side by Side Refrigerator Logo
318 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
