Question about Protron PLTV3250 32 in. LCD Television
Invalid mode is on a blue VGA input screen with laptop plugged in, why?
  • 11,361 Answers
It is becuase your PC video resoliton is too high for this TV to display, max resolution for the PLTV3250 is 1366 x 768 @ 60 Hz.
Also watch out for this TV power supply to go out due to bad caps and it will take out the transistor and Diode with it.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jun 04, 2010
Sanyo 55" flat screen keeps going off out of the blue???
Change your Sanyo input to proper input mode (HDMI, PC input, VGA)
Feb 23, 2014 | Computers & Internet
How to hook a laptop to my tv. What materials do I need.
your tv has to have a vga input and you will need a vga cable connect the blue vga cable the vga output from your laptop then go to the menue on tv screen then select vga on you tv screen and that should do it
Feb 09, 2011 | Magnavox 42MF439BF7 42 in. TV
I get a blue screen on my misubishi sl1 projector lamp and no signal appears on the screen
Hi
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have).
There are also known known hot-key combinations used to switch the laptop to its external VGA mode. If you are using a laptop.
Check the cables as well if properly connected both on computer and projectors end.
Hope this helps
Apr 02, 2010 | Mitsubishi SL1 projector lamp Projector...
HDMI from laptop to Mitsubishi TV worked once and stopped
Sounds like you set HDMI as your primary display device. Try reconnecting to HDMI and use the Mitsubish to make your changes while the laptop is connected. You will need to click the LCD Icon when it shows you the 2 monitors then turn off the HDMI device in that menu. Then select the VGA screen as your primary display device. This can be done with either the displays manager or the optional software supplied with your laptops display. remember to always switch back to your primary video device (LCD) before switching off your PC or laptop since the display resolutions on Hi-Def are completely different than a VGA device as well as the display frequency.
Windows, as well as Bios will prevent your PC from displaying resolutions and frequencies that may damage your Video card.
Mar 14, 2010 | HP Pavilion dv7-1130us laptop
How can I connect my pc to tv
The DV6000 has all the drivers needed to connect to a TV as long as the TV has either a s-video connection or a pc vga input. The vga input is usually blue in color on the tv but on the laptop it may appear dark tan or brown and does not have screws to hold it into place, the plug just fits in and tension holds it in place. Once you connect the cables, change the input on the TV to the type of cable you are using. The laptop should automatically pick up the signal from the device and load the driver for it. The desktop should appear on the tv if the output signal and input are matched. The icons may appear different on the TV if the resolution is not close to a match but that should not be a concern unless it is cutting some of the picture off, in that case all you have to do is change the resolution to one that is easier for the tv to show. The dv6000 allows you to toggle through the video output settings by holding down the Fn key and tapping the F4 key, this will change the display to both laptop lcd and tv, just tv, just laptop lcd etc. It will even let you extend the desktop from the laptop to the tv or from the tv to the laptop, making one long display side to side.
Nov 28, 2009 | HP Pavilion dv6000z Notebook
Hooking up to the tv, aspire one acer notebook???
hi there, try a 15 pin male vga to vga cable ...select vga mode on monitor
May 17, 2009 | Acer Aspire One PC Notebook
Any idea if I can hook my laptop up to my EDTV?
Yes, if your laptop has a VGA out port (that is the external display port - usually blue with 15 pins).
The NEC display has a VGA input on the right-hand side.
You just need a VGA cable that you plug in both connectors.
Then, read your laptop manual to determine how to activate the external display (usually the FN key with an other key that has a display icon on it).
On the NEC display, make sure it is using the RGB1 input (use the remote to activate this input).
That should do it.
NOTE: Make sure your laptop is using a reasonable screen resolution (that is 640x480 or 800x600).
Apr 17, 2009 | NEC Plasmasync PX-42VM5A 42 in. EDTV-Ready...
Jvc 56dlp connect computer
If you are getting an invalid input its because the resolution setting on your computer is probably set too high. The JVC only accepts 2 resolutions one is like 600x400 and the other is 1280x768. I had this problem all the time with vista. It can't seem to remember what resolution to use. The exact setting are also listed in owners manual.
Apr 08, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Analog power save mode
Are you connect via Analog (Blue VGA connection) or DVI (White Digital connection?
If you are connected via DVI, then you have to change the input select button to DVI
If you are Connected VGA, make sure the system doesn't have 2 VGA ports. If it does, connect to the other port.
May 02, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Protron PLTV3250 32 in. LCD Television Logo
510 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
