Question about Cub Cadet Street Sign- tractor lawn riding mower parts
23 hp tank - starts up great ,but will not start back after it warms up.
  • 177 Answers
Get the manual
Posted on Jun 07, 2010
I have just bought a hp envy 23-k210na23 touch screen.how do zinger started?
To setup, follow these instructions found on HP's site:
HP Support
If you are migrating from another machine you can search 'Migrate' on you older machine to give you some instructions on how to do this.
Mar 06, 2015 | HP Computers & Internet
23 hp engine will start great when cold, but after it run a short it will not start Brfiggs&Stratton vanguard V-Twin Vertical Ohv Engine start.
it sounds like a fuel starvation problem it is very possible theres a blocked vent in the carb. the carb will probably will need rebuilding not very difficult
Apr 09, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Running a Vanguard 23 Hp on my Mud Motor.\r\nQ1: developing a hard starting problem, seems like starting on 1 cylinder, after the first tank of fuel this fall. Fuel filter, spark, and plug OK. Looking at...
It sounds like your valves are out of adjustment. Your starter will bog down if it is out of adjustment and stop at the compression release.
So just take your valve covers off and set your valve lash to
.006 intake
.008 exhaust
Oct 04, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 1983 cb550sc honda that has a starting problem. when it's cold it only runs on no.1 cyl and all other exh pipes are cold. i have checked all systems and can't find the problem. compression is...
I certainly wouldn't rule out a fuel restriction, either in tank where fuel drains to line, or line(s) to carburetors. When cold, more fuel required, plus once engine starts to run, vacuum from carbs may overcome restriction, as well as less fuel required. My guess is that heavy acceleration is a problem even when warm as well. Doesn't take long to check in tank to see if filter/screen in tank is plugged at all, as well as remove fuel line for carbs and use compressed air (carefully) to clean out line(s) as well as blow back into tank to dislodge debris at screen in tank, but if there is debris, remove tank and flush good. Any in-line filters should be replaced as well.
Aug 26, 2010 | 1983 Honda vt 500 ft ascot
Won't stay running
Check the gas cap vent. A partial vacuum in the tank will cause these symptoms.
Sep 06, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Need carburetor adjustment
I had a similar problem with my 23 hp briggs. While cleaning the carb I found that the great gas we get today had eaten the seal around one of the jets in the throttle body causing it to fall out. Replaced the jet and now runs like a champ. Hope this helps.
May 05, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Is IS250 bad on gas?
Try installing a K & N Air filter. Any good Parts store Carries them. Changed the HP and Milaeage on my 425 HP Chevrolet Truck. Added 35 to 45 HP and increased My Mileage to 23 Per Gallon!
Jan 12, 2009 | 2007 Lexus IS 250
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
121 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
