Question about Kenmore 22642 Top Load Washer
Machine vibarating found spring broken have new one were dose it go long spring
Https://www.youtube.com/watch?v=pgjir05aBp0
Posted on Jan 29, 2015
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
You should be able to tell where the spring that you have connects.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the following Whirlpool Service Manuals for top load washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Posted on Jun 03, 2010
How do i replace 2 3" springs on stratford recliner.
Get Recliner-Handles Sofa Spring Repair Kit for La-Z-Boy ...
? 1:37
www.youtube.com/watch?v=_hHUNVAQsk0
May 28, 2015 - Uploaded by Faith Rogers
Recliner-Handles Brand Replacement Sofa, Sectional, Couch, Love Seat, Recliner, ... This sofa seat spring ...
Replacement Recliner Release Handle For Stratford and ...
www.recliner-handles.com/replacement-recliner-release-handle-for-stratf...
This flapper handle will fit Stratford and Stratolounger recliners and others that ... 3 3/4 X 3 INCH INEXPENSIVE EASY WAY TO REPAIR YOUR RECLINING ...
Oct 31, 2015 | Washing Machines
Frigidaire fwtr647ghso
defiantly it can be fix
Oct 21, 2013 | Washing Machines
Why is my washing machine making a loud banging noise when spinnig?
wip the top off and have a look at the big stabilizer springs that hold the drum up if one is missing or broken off replace it,,,,if these springs brake or fall off the washer dose a grate dance around the floor done it?
Nov 24, 2010 | Indesit W 123 Front Load Washer
Washer is moving and vibarating badly when spins
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 25, 2010 | Frigidaire Washing Machines
Is there a stendard (or specification) that address te vibaration on light posts on the Side of the road.
I found some specification on web from a company that sells light poles.
Jan 05, 2010 | 2000 Ford Focus
Grinder grinds but when I try to dose it won't turn inside to dose.
Doser lever failed. I diassembled the doser housing (three screws in the base) and found the return spring had fractured. I did not have any spring steel (such as a piece of clock spring) so I found it possible to cut a piece out of an old feeler gauge (38 thou) using tinsnips. I cut to the correct length and glued into the plastic housing as originally -just saved myself $100 and more importantly to me, all the pain of getting the grind setting correct on a replacement grinder
Nov 24, 2009 | Mazzer Coffee Makers & Espresso Machines
Kenmore 80 series
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 11, 2009 | Kenmore 24032\24036 Top Load Washer
Replacing a broken spring on Roper washing machine
The other end connects to the rear wall.
Mar 22, 2009 | Roper RAS8244LQ Washer
Kenmore washer tup wobbles easily
there is a little hole on the back panel where it goes,it most likey rust out,put it in the hole right next to it on the wall,this spring keeps the water from leaking out the top back when filling and rinsing
Mar 16, 2009 | Kenmore Washing Machines
Kenmore 22642 Top Load Washer Logo
106 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
