Question about Intermatic Inc. ML121RT Malibu Low Voltage 121-Watt Power Pack with Timer
How do you wire a Ml 121 RT Malibu low voltage transformer for outdoor landscape lighting?
  • 3 Answers
SOURCE: Malibu ML200RT low voltage power pack is not working
First check to make sure that you do not have more watts pulling than is recommended. If this is ok then pull both the red and black plastic pin from the timer and replace them then try. If neither of these solutions work you may have a problem at power source.
Posted on May 10, 2009
protek480
  • 1714 Answers
SOURCE: ML 121 RT doesn't power all lights on the system
Go back to where the lights are working, Then inspect the cable leaving that point. You must have a bad spot somewhere after that point killing the voltage.
Posted on Jun 27, 2009
SOURCE: Have Malibu low voltage transformer. Need red and
Routinely vailable on eBay...sometimes listed as "Intermatic" (Malibu's parent company.).
Posted on Mar 12, 2010
  • 5160 Answers
SOURCE: I have an intermatic/malibu low voltage outdoor
I think you can add any Malibu 12V lights rated for the 300 W power pack. Make sure that the total output stays below the 300W limit.
http://www.malibulights.com/ and click on Products and the different available lights will be detailed with the voltage and wattage.
You just have to click on the category, then the specific light and Product details.
This tier light would be acceptable http://www.malibulights.com/Products/Detail.aspx?category=Low+Voltage+Lighting&subcategory=Tier+Lights&sku=8301-9200-01&series=TIR-2009-1&seriesname=Cast%20Metal%20Tier%20Light&id=195
This flood light can also be put on the system
http://www.malibulights.com/Products/Detail.aspx?category=Low+Voltage+Lighting&subcategory=Flood+Lights&sku=8301-9602-01&series=FLD-2009-2&seriesname=20W%20Cast%20Metal%20Flood&id=206
I hope this helps.
Posted on May 10, 2010
gotgeek2
  • 565 Answers
SOURCE: I have a two wire
Use "A" and "B" terminals. The "C" terminal is a "dummy" terminal - it isn't connected to anything inside the transformer. It is used as a splice point in the event you decide to connect a photo cell (dawn to dusk) controller.
Posted on Aug 22, 2010
Where can I buy a replacement photocell for my Malibu 300W low voltage landscape lighting transformer?
You can buy the Malibu Photocell Low Voltage sensor on eBay. Go to eBay and search "Malibu Photocell Sensor" and you should see it. Or search eBay item number 371829265599
Mar 26, 2016 | Intermatic Malibu 300W Power Pack...
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
I have (7) 20W bulbs on a newly wired line running on a brand new 200W Malibu transformer, worked fine for 2 days and now it's tripping the reset button - Any suggestions ??
1) Copy following link for malibu power pack tips for longer transformer life:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Two plug choices on each outlet, Plug power pack into other outlet on receptacle.
Inspect for damage on outdoor outlet.
Replace outdoor outlet, and do not use quick connects. Connect wire directly to screws on side of device.
Replace GFCI outlet.
Feb 01, 2013 | Malibu Intermatic Inc. ML121RT Low...
Power at 3 feet, not at 2 feet ???
You might need to check the power source for proper voltage, sometimes outdoor wiring is at the mercy of the elements. Rusty screws on recepticles and so forth. Another problem could be exposed wire in the line bleeding of to ground. Sometimes this happens if a fixture is removed and the wire not properly protected. If these are none of your problems just take up your fixtures and replace the wire. 16 guage underground feed will probably be less expensive than the transformer you bought.
Aug 08, 2009 | Malibu Intermatic Inc. ML121RT Low...
Jun 18, 2009 | Intermatic Malibu 121W Power Pack...
Intermatic Inc. ML121RT Malibu Low Voltage 121-Watt Power Pack with Timer Logo
272 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
