Question about RTO Pelican Monaco Pedal Boat
Repair of small crack/cut in the hull bottom...3 " long..1/64" or less wide...
  • 59 Answers
It depends on the material of the hull. If it is Fiberglass then buy a small auto or boat repair fibreglass kit and follow instructions in the kit.
. If it is one of the engineering thermoplastics like High density Polyethylene ABS or Polypropylene I would try and find somone who can weld it with the appropriate material. This would be done by carefully shaping the plastic away from the crack to form a "V" shaped recess and then filling the gap with the appropriate filler rod usually using a hot air blower designed for the job.
Posted on Jun 03, 2010
A lot of the pedal boats now are made of plastic, I found the best thing to repair them is JB Weld, a 2 part glue that can be found in any hardware store. When mixed it almost like a putty, so it will cover up small holes. I used the one for metal but I think they have one designed for plastic. Anyways it worked great to patch up 2 holes I had on my boat. It's been over a year and stil holding.
Posted on Nov 23, 2014
The basket is cracked
On the bottom of the 'TOP PART WITH THE MOTOR AND BLADES" is a SAFETY SWITCH that must fit onto a small piece on the inside of the basket for the unit to run. If the basket is cracked and the small plastic piece does not match up the machine will not start.
Your options are:
1) Try to repair the basket to get the switch to line up
2) Go to the manufacture's web site to purchase a replacement basket.
3) Trash it all and buy a new unit.
Jul 11, 2014 | Fellowes DM8C Cross-Cut Shredder
Deep Hull gouge on bottom of plastic kayak
Some people talk about getting very careful with a small torch and sticks of poly and melting them into holes like that, but I have not done that kind of repair. Whatever you do, if anything, be sure not to damage the hull - which is still OK - and to smooth out any edges when you are finished.
Jul 06, 2014 | Wilderness Systems Aspire 105
Water in hull of bass tender pro
Find the leak and patch it. Use a good marine epoxy system with a sheet or two of fiberglass cloth laid-across the crack. Be sure to sandpaper the area thoroughly with rough paper. If you can't find a leak or crack, fill the hull with water and inspect for leak. Repair after.
May 20, 2014 | KL Industries Basstender 10.2 Fishing Boat
Jackson kayak hull repair
Crosslink = good luck
Linear plastic is simple: cut a sliver from your cockpit and try to weld it back with a heat gun, soldering iron or old skiwax iron, do not use open flame as this will produce soot.
There are many sources of linear plastic, use the above system to ensure compatibility of plastics.
When welding try to melt the two plastics together, I normally spin the plastic "welding rod" thereby mixing old and new material into a good composite of both.
Video is my son's Rockstar, we welded a bow protector because Jackson linear plastics cannot compare to any other boats I have paddled in thirty years. Jackson's paddle well and my son loves his boat, but as his technician it sucks.
Google "keelguard" this product may help someone.
https://www.keelguard.com/keelguard.html
BTW an old iron works great on linears to smooth out cuts or nicks. Boiling hot water will help pop dents out!
May 13, 2012 | Boating
Re: transducer installation should the transducer on a Elite 5 be in line with the bottom of an aluminimum hull or the bottom of the ribs running along the hull thanks
try and mount the transducer at the lowest point on the hull and on the flatest part,, with the direction arrow facing forward.
c...
Jan 04, 2011 | Sport & Outdoor - Others
Torn bow
Repair any cracks or damage to the hull with fiberglass repair kits, available at most hardware stores. Use an overlay prior to the fiberglass if the area is bigger than a quarter so you don't develop a soft spot.
May 10, 2010 | Advanced Elements Advancedframe...
My 1997 polaris jet ski keeps taking in water? what could this be??
Unplugged water tube, cracked water tube, bad drive shaft hull seal, hole/crack in the hull, cracked water box, broken exhaust jacket water seal, water tubes plugged in incorrectly, no cap on flush kit, broken fitting on motor,etc. Dry out the boat take off the seat and place it in the water and look to see where the water is coming into the hull.
Sep 07, 2009 | Polaris ATV
Crack in clear blue hawaii molokini hull
Use a fiberglass repair kit, available at most hardware stores. Use an overlay prior to patching so you don't develop a soft spot in the hull.
Jun 15, 2009 | Clear Blue Hawaii Molokini Kayak Cbh57702
Split hull
V out the cracks with a grinder, cut fiberglass matting with an overlap of about half an inch. pre-cut 6 more pieces gradually stepping overlap to 1 1/2 inch starting with smallest piece soak in resin and place over v'd out crack, once all pieces are in place press out any air bubbles. takes a while to dry. once dry sand flat with 36 grit then 80 and 150. place a gelcoat on top
Jun 01, 2009 | Boating
Scanoe, Ram-X, Split in hull near gunwhales- Repair, How?
I found a Scanoe like this on craigslist that was being given away because of several splits ins the hull. I was ready to buy that patch kit on line when I stumbled on a solution that worked great! I was in Home Depot looking in their pond department and saw some self adhesive patches for poly ponds. I bought on for less than $7.00 and gave it a try. I sanded the inside of the hull around the split. cleaned it well and applied the patch. It worked like a charm!
Oct 20, 2008 | Coleman Sport & Outdoor - Others
RTO Pelican Monaco Pedal Boat Logo
1,549 people viewed this question
Top RTO Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a RTO Boating Expert? Answer questions, earn points and help others
