Question about Dryers
Have a whirlpool dryer about 2 years old. Had dryer vent cleaned. (had small blockage not total). Now I did two big towls and two hand towls. I set it to auto dry (very dry, high heat) and after the timer went off they were all damp. Got any ideas?
  • davidgalb721 Jun 03, 2010
    Thank You!
    Sounds great I will give it a try!
    President:
  • 949 Answers
It sounds like the sensor is not working right. If you have the same type of load (all towels) you should get a very even full dry on auto dry.
If your filter is on the top of the dryer the sensor is on the back wall near the bottom right, if your filter is just inside the door the sensor is on the front wall just below the door opening.
The sensor is a set of 2 metal bars each about the size of a pencil in a black plastic housing. As the wet clothes brush across these, the dryer stays in the drying mode, as the clothes get dryer the bars do not make electrical contact with each other as the dry clothes do not conduct current like wet clothes.
Saying that, there are a couple things that could cause it not to dry. If the dryer is not level and the clothes (towels) are settling to the opposite side of the dryer that the sensor they will not dry right. Level the dryer by adjusting the 4 legs.
If the sensor bars get a coating of softener they will not sense right. Take a cloth and alcohol and clean the metal strips so they can sense again.
Doing these to adjustments along with a clean filter and vent will make your towels dry again
Posted on Jun 02, 2010
Why would check vent light go on after replacing sensor and computer
Is the dryer vent blocked with lint? If there is a restriction in air flow in the vent system, the dryer will stop. Make sure the vent path is completely clean even in the wall where the vent hose connects.
Oct 07, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool duet electric dryer leaking water
Check and clean your venting from the dryer to the outside. If it is plugged it will trap the moisture in the machine. Remember heat doesn't dry the clothes without air flow to push the moisture out.
Mar 04, 2013 | Whirlpool Dryers
No heat in dryer. Vents are clear and clean. Just purchased this dryer 2nd hand. Unti is 3 years old. Could I have wired the plug wrong?
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpgCheck the continutity on the thermal fuses and replace the one that has no contiunity.
Feb 12, 2011 | Whirlpool Dryers
I have a Frigidaire stackable full-size washer/dryer. I don't have the model number, but it is about eight years old. The dryer does not get hot enough to dry even a small load well.
When was the last time you cleaned out your vent? It should be done every 1-2 years to prevent build-up of lint and possible blockage. Also make sure your outside dryer vent flap is not stuck closed or clogged. I use a plumbers snake to twist inside the vent and clean out the lint. It makes a huge difference in drying time. Also disconnect the vent from behind the dryer and check for lint build-up inside the back of the dryer itself. (Be sure to unplug the dryer before you do this!) When you push the dryer back, be careful not to squish or pinch the dryer vent if it is a flexible foil or plastic tube. These are the easy fix-it's. Try them first before resorting to more expensive trouble shooting. Douglas
Sep 06, 2010 | Frigidaire Dryers
It takes forever to dry a load of clothes. Drum
Have you checked your vent for blockage? Over time, lint build-up in the vent and in the back of the dryer makes your drying time longer and longer. Unplug the dryer, pull it out and disconnect the vent. Using a flashlight and a vacuum, clean out the back of the dryer that connects to the vent and the vent itself. If you have a long vent line, you'll need to find a away to clean it out to clear any blockage. I use a hand-held plumbers snake that rolls up and pulls out as much length as needed. Then spin it around in the vent to knock off lint attached inside the vent tube walls. It may be easier to do this from the outside, but you can do it from the inside too. Check your outside vent cap for blockage and make sure the vent flap outside is not stuck closed. Also make sure when you push the dryer back into place, that you don't squish the vent tube, if it is made of plastic or foil. After reconnecting the vent, turn on the dryer. The air flow may blow out the lint you have dislodged with the snake. Clean out as necessary at the outside vent. I have a long vent line on my dryer, so I have do this annually. This has helped shorten my dry time every time I do it. Of course, cleaning out the filter regularly, does help too. The more often you clean the filter, the less lint that will build up in the vent . Hope this helps. Douglas
Jul 17, 2010 | Maytag MED5600TQ Electric Dryer
My Dryer not that old, takes all day to dry a small load.
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 31, 2009 | Whirlpool LER5636P Electric Dryer
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
Whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Mar 03, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool gas dryer runs but won't heat
hi stella. yes the problem is with the thermal fuse. when you were cleaning the vent at the left. the thermal fuse is right there, on the air duct, a small piece of plastic with 2 blue wires to it . replace the thermal fuse . thanks the appliance doc
Oct 06, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
